Old 10-30-2011, 01:49 PM   #1
calamity_jane
Member#: 264745
1997 IMPREZA GC8
WHITE-BLACK
Default Change the ej205 with ej257
Yes, friends. I need help for swap the 2004 wrx (ej205), with an ej257. The main problem is; we need a power around 500whp. I know that its difficult with ej205. near this the best will be done with ej207 but I have an ej257.
so I need to make a part list for my project. Please help, tahnks.Project is open to all minds..
(Before this project we have put them a sti transmission and put a 18g)
calamity_jane is offline   Reply With Quote
Old 10-30-2011, 11:44 PM   #2
207STi
Member#: 197062
1998 Swapped Impreza
black
It is PAINFULLY obvious that you have done little to no research on your own part. 500 whp is a tall order, especially when you don't take half a second to read one of the 80 build threads going on in proven power bragging and the built motor sub forums.
207STi is offline   Reply With Quote
Old 10-31-2011, 01:16 AM   #3
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
ur tranny will break faster than if she was on the jerrry springer show.
DHRDAN is offline   Reply With Quote
Old 10-31-2011, 05:46 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
^^^This, read those threads to find out what problems they had, so you don't run into them. 500 WHP is nothing to take lightly, that's 200 hp/ liter on an EJ257.
To get that you need a large-ish turbo and a rev-range to go with it. This isn't going to be cheap, and not thinking this through could be very bad for your wallet.
~Josh~
Old 11-01-2011, 09:31 AM   #5
calamity_jane
Member#: 264745
1997 IMPREZA GC8
WHITE-BLACK
uppss.. !! it is not a comedian..
of course i read many threads and many projects.. as i know this forum i just want to ask if someone dones such a project (healty ones) i want to hear that.. and i actually know to calculate the 500 hp /2.5 L = 200 hp proliter.. i want to learn that for ej257 which parts should be change with which brand.. for instance..cranck shaft ,VF43 turbo with GT35R , camshaft degree and brand Pauter??
shortly, for this project what you should advice me for the parts and brands..
Old 11-01-2011, 02:30 PM   #6
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
You must be new here.
i_c_the_light is offline   Reply With Quote
Old 11-01-2011, 03:34 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
FS : STM 1999 Subaru Impreza 2.5RS Coupe with EJ257 STi / EJ205 WRX Swap Danny Boy NESIC Private Classifieds 15 12-22-2010 11:00 AM
Clutch dilema - EJ207 the same with EJ257 ? ElSpa Transmission (AT/MT) & Driveline 3 02-08-2009 11:36 PM
Check Engine Light After EJ205 - EJ257 Conversion While Keeping The EJ205 ECU SchultzE Subaru Conversions 11 08-01-2008 11:56 PM
Ways to change the resolution with a batch file? jcl Off-Topic 14 12-08-2006 02:33 PM
synthetic oil and changing the filter with out draining the oil warpspeedwrx Service & Maintenance 16 07-21-2003 12:16 PM
