Old 10-30-2011, 03:40 PM   #1
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
Default Accessport maxing out my injectors?
2005 Stage 2 WRX Wagon. Turboback exhaust and intake. No cats. After some data logging, we saw I'm maxing out my stock injectors on a off the shelf stage 2 tune.
Is this correct?
Also, do I actually have a wideband sensor? Or is the accesport logger just a sham when it comes to reading my air/fuel ratio?
I'm getting injectors and a fuel pump next week. Getting some 800cc's for cheap, and I'm just going to mod mine and sell the others. Just wondering if anyone else had the same problems.
I did a little searching, but most others had more mods than me.
Thanks.
Zach Bitzer is offline   Reply With Quote
Old 10-30-2011, 10:36 PM   #2
I8ls1
Member#: 299496
2005 wrx
be careful with the cheap injectors you can mod you stock ones to get you plenty of flow. i have 05 2.0 with 16g and running the accessport 16g tune and it doesnt matter if i set my boost to 14 or 19 psi it will say my injectors are 100%. as far as the wideband no you dont have one and the accesport a/f reading isnt very accurate at low readings
I8ls1 is offline   Reply With Quote
Old 10-31-2011, 11:21 AM   #3
Cobb Tuning
Member#: 4803
Is this correct?
Thanks.
You can look at injector duty cycle to see where you sit, but keep in mind that approaching 100% (or tad over) is not unusual for stage 2 Subarus with a conservative OTS fuel map. Anything above stage 2 (or stage 1/2 or above with E85) will require larger aftermarket injectors. You do not need aftermarket injectors for stage 2 running E0-E10 gas.
The AccessPORT uses the front o2 sensor to read AFR. On the 02-05 WRX it is a narrowband sensor and it is generally only accurate in closed loop (idle/cruise). Even if it were a wideband (like the 2.5L cars), its placement in the exhaust doesn't make it very accurate under boost and the ECU limits the reading to 11:1. Regardless of the Subaru, you need a wideband o2 sensor to accurately determine fueling in open loop.
Bill
Old 10-31-2011, 01:17 PM   #4
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
Thanks for response
maxing out my injectors vf39 wrx.. Dizzuque Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 11-26-2007 07:50 PM
Maxing out stock injectors on stock turbo OCD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2005 08:25 PM
Maxing out stock injectors Santo Domingo 2.5 RS Normally Aspirated with bolt-on Forced Induction Powertrain 12 05-01-2003 03:09 PM
TD05 or TD06 max out my injectors @ 10psi? BLCK DVL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-03-2002 03:32 AM
Yikes, I'm maxing out my fuel injectors Revision Mid West Subaru Owners Club Forum -- MWSOC 32 12-11-2001 03:13 PM
