Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-30-2011, 11:46 PM   #1
kleedzine
Member#: 273531
02 frankenSTI
white
Default Target Afr setting
I am trying to set target afr to 11.5
first, I logged 3rd gear pull and I get 11.1 afr. while pulling.
So I have set the open loop fueling table.
@ 2.9~3.1 engine load
11.2ish at peak torque range(3.2k~3.6k rpm) 11.5 to the redline (6.5k)
And I logged 3rd gear pull and got only 11.14 afr.
I am using Accesstuner race.
Can anyone tell me what to do? to set the target AFR?
kleedzine is offline   Reply With Quote
Old 10-30-2011, 11:56 PM   #2
sorrowfulkiller
Member#: 170439
I <3 Lamp
Easiest way? Set your target afr's in the open loop fueling map to whatever you want them to be. Change afr in the software to lambda, change your wideband to lambda.
Datalog and make sure you are datalogging commanded fuel, actual fueling and rpm as well as the maf load.
From there use maf load and rpm to determine where you need to adjust your fueling.
So for instance your commanded fuel is .81 lambda and you are at .79 lamda, multiply that cell by 1.02 which will add 2% of fuel to that cell. Which should get to to your desired afr. If your commanded fueling is .81 and you're at .89 multiply by .92 which will take out 8%. Get it?
sorrowfulkiller is offline   Reply With Quote
Old 10-31-2011, 12:19 AM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
Are you logging wideband O2 or the factory O2 sensor? Factory O2 will read 11.1 for anything below about 12:1
Airboy is offline   Reply With Quote
Old 10-31-2011, 01:27 PM   #4
kleedzine
Member#: 273531
02 frankenSTI
white
Thanks for the input.
It is from AP dataloging, and it is from factory O2 sensor.
I think I should get a wideband first to tune AFR.
Old 11-03-2011, 04:36 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^ Correct, you need a wideband. The stock front 02 sensor will just peg at 11.14. This is not the real AFR reading, just a limitation of the stock sensor. And just like airboy said, it wont "unstick" from 11.14 until you get up into the 12:1 range.
Closed loop target AFR versus Low det/hi det fuel surfs TMessick Commercial ECU Reflashes 22 12-27-2007 07:47 PM
Yay! 17psi peak, 10.9-11:1 Target AFR no more knocks! bpwatts UTEC 5 11-27-2006 09:39 AM
target afr wrxtremeWGN Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-22-2006 08:37 PM
Target AFR with water/alchy injection vica153 Engine Management & Tuning 18 04-10-2006 06:25 PM
Big vacuum target AFRs jblaine Engine Management & Tuning 8 04-08-2005 08:23 AM
