Welcome to the North American Subaru Impreza Owners Club Wednesday April 22, 2015
Old 10-31-2011, 12:10 PM   #1
doughboy118
Member#: 263465
2002 Impreza WRX
Default Ap V1 Won't Unmarry Help!!
Hey folks,
So i'm working on selling my COBB AP V1 from my 02 wrx. ..only problem is that when i try to "Revert to stock" the tuner gives me an error message and won't unmarry.
Heres how it goes:
It prompts me to "turn the car fully off and then back on and press: ok" When i do this it says: "ERROR Please try operation again" I can turn the car off and on as much as i want, but it still always gives the same error.
I Have the Initialization connector plugged in, the green test mode connectors are together and it still does the same thing. Is my AP just dysfunctional? i don't understand. I've switched between maps before and everything goes fluidly without a hiccup. Can somebody please help??
Thanks, -Doug
doughboy118 is offline   Reply With Quote
Old 10-31-2011, 12:39 PM   #2
Cobb Tuning
Member#: 4803
Originally Posted by doughboy118 View Post
Hey folks,
Heres how it goes:
Thanks, -Doug
An uninstall require that the green test mode connectors are connected (and the initialization connector). You can verify that you are in "test mode" by turning the ignition on without the AP connected. The radiator fans should cycle after a few seconds.
If that does happen, then it may be your timing when you are starting the process. Try it again and make sure you are turning the ignition to ON. When you turn the ingition to ON you need to immediately hit the button to start the process (keep your finger over it so you are ready).
Bill
Old 10-31-2011, 02:48 PM   #3
doughboy118
Member#: 263465
2002 Impreza WRX
Bill,
Yes, the fans are cycling and the CEL flashes, so the car is definitely in test mode. Is there any chance maybe i mixed up the init connectors, or are they year specific? and should i get any recognition from the AP when i plug it in about the car being in test mode or intitializing or anything? It just goes straight to the main menu screen when i plug it in.
Thanks a lot,
-Doug
Old 10-31-2011, 04:44 PM   #4
Cobb Tuning
Member#: 4803
Bill,
Thanks a lot,
-Doug
No, you won't get any indication that the car is in test mode from the AP. Does the AP's boost monitoring work? I would make sure there are no bent pins on the OBD connector and that it is secure when go to try. Keep the ignition off right before it goes to unmarry and then try to work on your timing. You should start the process as fast as you can after turning the ignition on. If that doesn't work try different timing - slight pause, for example. If the radiator fans cycle, you've waited way too long (or the process failed).
You should be using the blue initialization connector - you might want to check it to make sure the connector is good.
Bill
Old 10-31-2011, 07:59 PM   #5
doughboy118
Member#: 263465
2002 Impreza WRX
Bill
Okay, that makes sense to me. And yes the boost monitoring seems to work perfectly. I'll give that new idea a shot. Thanks for all the help. I'll check back in when i have results.
Old 11-02-2011, 10:18 AM   #6
doughboy118
Member#: 263465
2002 Impreza WRX
Bill,
I tried messing around with my timing a little bit and there's no change in the result. I still get the error when i press okay. I don't know what to do besides keep trying it over and over and over. The car is going into test mode and the fans will cycle, CEL flashes etc. The AP seems to be acting as if its not even connected IMO. When i select the ok button, it goes directly to the error screen. It does the same thing if its not even connected to the car. There's no stutter or pause or anything before it goes to that screen, which seems fishy to me (but then again i'm quite the opposite of a technology-savvy person). Could something be wrong internally? but then why do all of the other functions perform normally? Very confused.
Thanks for the help,
-Doug
Update, just looked at the plug on my AP connector and the wires (where the cable enters the back of the OBD2 connector) are pulled out and visible. i see 9 wires in total. 1-green, 1-purple, 1-black} all of which are clipped short as if never plugged into anything. Grey, yellow, red, blue, orange}all seem to be firmly connected and then brown} looks as if it pulled away from its solder possibly? is this my problem?
Also, the car does not exit test mode when i select either revert to stock or change base map.
Thanks, -Doug
Old 11-02-2011, 12:30 PM   #7
Cobb Tuning
Member#: 4803
Bill,
-Doug
Thanks, -Doug
Yeah, sounds like you have a problem with the cable. I talked to our tech support guys and it sounds like you may have been in contact with them already. They are going to give you some more info of your options.
Bill
Old 11-02-2011, 12:52 PM   #8
doughboy118
Member#: 263465
2002 Impreza WRX
Yeah i got in contact with Ian over there i believe. Thanks so much for all the help. It's greatly appreciated.
A+ for COBB Tuning's Customer support
FS: Cobb AP V1 - Unmarried - 04 WRX blitzGDB Engine/Power/Exhaust 9 02-04-2010 05:01 PM
Help with unmarrying the AP V1 or not unmarrying it! DJS_02_WRX Newbies & FAQs 12 10-18-2009 09:53 AM
AP v1 won't sync!! HELP!!! Snailspeed AccessPort 17 04-25-2009 04:59 PM
FS: 04 STi AP v1 - Unmarried with two protunes! alee86 Engine/Power/Exhaust 6 01-22-2008 06:07 PM
FS-NY Cobb AP v1 2002-3 unmarried amelnikov Engine/Power/Exhaust 6 03-29-2007 10:12 PM
