Old 05-16-2001, 08:14 PM   #1
auricom
Member#: 3088
'01 2.5 RS
Post weird engine shakes....02 perhaps??
when the engine is cold i get mad shakes, the whole car. very aggresive shakes and yes i did a search and only came up with shakes dealing with the suspension, no engine stuff. im wondering if my 02 sensors ready to poop.
auricom is offline   Reply With Quote
Old 05-16-2001, 08:24 PM   #2
THETINTMASTER
Member#: 5996
Exclamation
auricom , My car has the same shakes when cold . Has done this from day one . I now have 1300 miles , and no C.E.L. yet . Anyone else ?
Thetintmaster
THETINTMASTER is offline   Reply With Quote
Old 05-16-2001, 10:06 PM   #3
auricom
Member#: 3088
'01 2.5 RS
Post
i got my 2.5RS about 5 months ago, i noticed it awhile back but its doing it more often now.
Old 05-16-2001, 10:16 PM   #4
GeAtReddY
Member#: 6602
01 GC8
BRP
Post
When does it happens? does it happen when your car is moving or ?? because sometimes my car does that when it is stopped... its like it was gonna stall on itself...
GeAtReddY is offline   Reply With Quote
Old 05-17-2001, 01:50 PM   #5
auricom
Member#: 3088
'01 2.5 RS
Post
it mostly happens when the engine is cold. seems like hesitation but it literally shakes the hell out of the car. it's a manual tranny and yes i know how to drive a clutch.
Old 05-17-2001, 01:53 PM   #6
2Point5RS
Member#: 3639
Post
I have the same problem, no matter how much of an effort you put in to make the shift "easier"..nothing helps. I've noticed it's the worst when going in to 1st gear.
2Point5RS is offline   Reply With Quote
Old 05-17-2001, 02:50 PM   #7
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Post
Do you mean sitting at idle, driving at low speed/rpm, or high speed/rpm?
My 01RS shudders a little bit at idle as the ECU constantly adjusts the amount of fuel delivered, trying to ride the perfect line between lean/rich.
Shaking at low speed/rpm (ie. bucking car effect when crawling in rush hour traffic) is normal too in most MT car, because just a little gas is enough to create a large percentage change in RPM. The trick here is to be very smooth and gentle with the gas pedal.
Shaking at higher speeds (20mph+) or rpms may be a tire out-of-round or something like that. Take a good look at each tire and make sure there are no "bubbles" or "bumps" in the tread or sidewall. Also check your suspension to make sure nothing is broken.
Xio is offline   Reply With Quote
02 wrx weird engine noise killa996 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-14-2006 01:40 AM
Upon WOT in 2nd and 3rd, engine shakes codemunky Normally Aspirated Powertrain 3 09-15-2002 01:14 PM
engine shaking vdv Normally Aspirated Powertrain 1 07-08-2002 09:13 AM
Engine shake samuraiRS Forester Forum 9 04-06-2002 04:13 PM
Engine shake Sobelizard109 Normally Aspirated Powertrain 1 03-17-2002 04:54 AM
