Old 08-18-2013, 07:51 PM   #1
mcmuscle3
Member#: 361546
Default Need help now!!
hey guys, here is my log: i quit the rpm range early because my car was acting dumb and i didnt want to take a chance running the rpms any higher. It misses during boost and feels weak. I changed the plugs and that fixed the problem for a few days but now its back to where it was. I think the plugs may be fouling because a too lean/rich condition possibly?
https://docs.google.com/file/d/0B_XA...it?usp=sharing
mcmuscle3 is offline   Reply With Quote
Old 08-18-2013, 08:05 PM   #2
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Omg the knock you have!!! Why log so many parameters?
cosseywrx is offline   Reply With Quote
Old 08-18-2013, 08:08 PM   #3
mcmuscle3
Member#: 361546
Idk: this is what my tuner recomends for his tuning so I used it. What's wrong with my car!!!! Lol
Old 08-18-2013, 09:57 PM   #4
mcmuscle3
Member#: 361546
Where are you techs at? I have no mechanics around here that I would trust wry my car so I do nearly everything myself with the help of this forum.
Old 08-18-2013, 10:09 PM   #5
BluewaterAWD
Member#: 262210
Your logs have way too irrelevant much information.
Secondly, you are not logging boost/target boost so there is zero opportunity for anyone to diagnose boosting issues that you may have.
You are not logging your throttle position ; We cannot diagnose the problem without that.
The long and short of it - You are knocking well beyond excessive levels and have an issue. I don't think your plugs are fouling ; I believe your engine is screaming for mercy.
Reset the log parameters & run a proper log. Details are in the forum. You also need to seek a local tuner. Don't trust the internet.
BluewaterAWD is offline   Reply With Quote
Old 08-18-2013, 10:19 PM   #6
BluewaterAWD
Member#: 262210
You also have two threads open for the same log & question. Information is already in your other thread.
Old 08-18-2013, 10:36 PM   #7
mcmuscle3
Member#: 361546
How come when I put the new plugs in it ran better for a few days, and now it runs like it use to? It was a very big difference once I changed the plugs.
Old 08-18-2013, 11:28 PM   #8
BluewaterAWD
Member#: 262210
Without seeing a proper log, we are picking at straws here. Think of it for a second ; You replace a component that was causing an issue, it functions as normal for a few days, and the symptoms return. Obviously something is causing an issue. Until you produce a suitable log, we will continue to pick at straws.
The fact that remains true is you have excessive, serious levels of fine knock. Knock is bad. Knock kills engines. Knock is not good. The knock you see results in the destruction of your plugs, from detonation, etc.
Unless you are willing to get the information people need to gain insight into your issue, You will never figure it out unless you find a local tuner.
Old 08-19-2013, 05:17 AM   #9
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
I have seen this before. His motor was blown up hella bad.
renosubby is offline   Reply With Quote
Old 08-19-2013, 05:54 AM   #10
mcmuscle3
Member#: 361546
Il try to get a good log today. Btw: this was 3rd gear pull at wot. The car runs normal as long as it's not high boost
Old 08-19-2013, 07:59 AM   #11
BluewaterAWD
Member#: 262210
According to what you have posted so far, your car is not running normal at all.
We will see shortly
Old 08-19-2013, 08:39 AM   #12
mcmuscle3
Member#: 361546
Well i should clarify and say it feels like it runs normal at low rpm,/ no boost
Old 08-19-2013, 10:13 AM   #13
mcmuscle3
Member#: 361546
Here is the new log. I added a lot more parameters so hopefully this will be more helpful.:
(3rd gear wot)
(normal driving/pulling out)
Old 08-19-2013, 10:53 AM   #14
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Try these parameters when you log:
A/F Correction 1(%)[RR]
A/F Learning 1(%)[RR]
A/F Sensor #1(AFR)
Engine Speed (RPM)
Engine Load (1 byte) (g/rev)
Fine Learning Knock Correction (degrees)
Feedback Knock Correction(degrees)
IAM
Ignition Total Timing
Injector Duty Cycle(%)
Manifold Relative Pressure(corrected)(PSI)
Mass Airflow (g/s)
Primary Wastegate Duty Cycle(%)
Throttle Opening Angle(%)
Vehicle Speed (mph)
Old 08-19-2013, 01:32 PM   #15
mcmuscle3
Member#: 361546
Il try that sometime. Let me know how this last log looks.
Old 08-19-2013, 01:50 PM   #16
nmlittlebigman
Member#: 321409
2003 Big Effing Van
You definitely have some lean spots in that tune. Lots of questions :What car is this? What are the mods? Who tuned you? Do you have any aftermarket parts on there not supported by the tune????????
Better off to find a tuner that will spend some time on this car. my 2 cents
Old 08-19-2013, 01:56 PM   #17
mcmuscle3
Member#: 361546
It's a 05 wrx 2.0z greddy 518 turbo, injen coi, dw650 injectors( that's what my tuner told me I had) 3" catless exhaust, downpipe, and idk who tuned it. But Steve from pulzon tuning will be my man when it comes to tuning. Just put new plugs in it, I run 93 she'll v power,
Old 08-19-2013, 01:59 PM   #18
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Well now is the time to get Steve to send you a base map. Don't do anymore pulls on your car.
Old 08-19-2013, 02:01 PM   #19
mcmuscle3
Member#: 361546
05 wrx 2.0,greddy 518,(Steve at pulzon tuning told me I had dw650cc injectors), injen coi, larger top mount intercooler, new plugs, gfb bov, 3" turbo back exhaust catless,
Steve will be tuning my car . I bought the car like this so idk what all internal work has been done but they said it was built for the bigger turbo. Both engine and tranny
Old 08-19-2013, 02:02 PM   #20
mcmuscle3
Member#: 361546
Yeah, I didn't mean to send duplicate messages. My bad
Old 08-19-2013, 02:36 PM   #21
BluewaterAWD
Member#: 262210
See!! You have problems my man. Don't make an uneducated decision, unless you have deep pockets!
Old 08-19-2013, 03:26 PM   #22
1wrxtra
Member#: 316364
2012 WRX
Everyone above has expressed concern with your car... I'm going to echo that. Get a base map from Steve as soon as possible and don't do anymore pulls on your current map. Your injectors are hitting 40 IDC, but your fuel pump is max'ed at 100% even after you let off the gas during your run.
It also looks like you're looking at knock in .5* intervals, instead of the typical .35*, which is strange. Your load tops out just under 1.2, which is extremely strange for a FI application.
Your AFR is ****ed. You are running DANGEROUSLY lean throughout your entire run. Either you have the world's worst tune, or something is mechanically wrong with your car.
No more pulls. Get a base map from Steve. If your numbers are still out of whack, something is mechanically wrong.
1wrxtra is offline   Reply With Quote
Old 08-19-2013, 04:20 PM   #23
mcmuscle3
Member#: 361546
So my fuel pump is maxed out then il need a higher flow pump. Would that fix the lean condition you recon? Thanks for the info, I'm talking to Steve now about it
Old 08-19-2013, 06:13 PM   #24
mcmuscle3
Member#: 361546
haha i just noticed i used "recon" You can tell im from the rural VA area
Old 08-19-2013, 09:55 PM   #25
dux10
Member#: 235338
2002 Faggin Wagon
srp
Working on this basemap at the moment. The OP is still missing a wideband and fuel pump so it'll be on wastegate pressure until both components are installed.
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
