Old 11-02-2011, 08:21 PM   #1
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Default JDM Gentlemen agreement: true or not?
Hey guys,
Apparently there was a gentlemen agreement in Japan some years ago to limit production cars to 276 HP... But even if different automakers claimed their cars were limited to that power, car apparently made more than that under stock conditions...
Does anybody know if that's true or not? If true, how much was the real HP on our cars (claimed to having 280 HP for instance in the case of the STI)
wrxstijdm is offline   Reply With Quote
Old 11-02-2011, 10:34 PM   #2
blessthekellen
Member#: 273859
MY98
WRX
yes. it is true. however the ecu's were typically detuned to a lower boost level from factory to keep this rule in effect. didnt take much for a simple boost controller to break the agreement after the fact
blessthekellen is offline   Reply With Quote
Old 11-03-2011, 12:07 AM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
Do you really think an RB26 only had 276bhp, or roughly 200whp?
eg33GC is offline   Reply With Quote
Old 11-03-2011, 03:34 AM   #4
RallyColtTurbo
Member#: 16819
I always thought that it was -advertized- HP, and the car itself wasn't as governed.
I also thought it was more insurance or tax driven than a supposed 'gentleman's' agreement.
RallyColtTurbo is offline   Reply With Quote
Old 11-03-2011, 08:43 AM   #5
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
There was an agreement. You have to look at the advertised HP of the JDM Spec C in a V7, V8 and V9. There were changes but the real power was not advertised untill 2007, I think.
Also, this agreement did not include limited edition cars, like the S202, 203, 204 and those were over 276HP advertised. The factory tuning is different on these.
There is a second agreement or maybe a regulation. The maximum speed cannot be over 180 Km/h.
This is reflected more than one would think. In a JDM car, even if this limitation is removed from the ECU (which is possible), there is no boost control over 180km/h and I don't know how that would be changed.
Old 11-03-2011, 11:53 AM   #6
bisonjr
Member#: 102714
Wasn't it 300 kmh (186~mph)?. That was also the case for bikes.
bisonjr is offline   Reply With Quote
Old 11-03-2011, 11:58 AM   #7
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
No, look at the jdm Sti clusters, they are marked 180 km/h. People are buying these, buying from IAP the mph conversion module and then covering the K in km/h with black marker.
Old 11-03-2011, 12:07 PM   #8
bisonjr
Member#: 102714
Ah, yes. I'm getting my random facts confused... lol.
Old 11-03-2011, 02:58 PM   #9
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Agreed, JDM clusters get only up to 180 km/h...
However, I didn't know that there's no boost control if you remove the limitation from the ECU??
So, is the real HP over the advertised 280? Or cars were really "downgraded" or "detuned" to match the 280?
Old 11-03-2011, 03:33 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Real horsepower over advertised. About 7 or 8 years ago there was an operation out of AZ that was importing STi clips into the States. They put a v5 STi on an engine dyno. It made 340bhp in stock trim. Stock ECU. No chip. Just an engine dyno run of the longblock with turbo...
Old 11-03-2011, 04:21 PM   #11
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Hmmmm that's exactly the kind of information I wanted to know... so probably most of the V3/V4/V5/V6 STIs might be producing around 340 bhp under stock conditions....
Old 11-03-2011, 04:28 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
If you want to get a more concrete idea of particular models, go look in proven power bragging forum for results people have had with vf22 and vf23 and vf24 and vf29 turbos over the years. Look for USDM cars with boost pressure numbers similar to stock from the factory on the STi models in question.
Old 11-03-2011, 04:30 PM   #13
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Stock boost on STIs is around 0.9 bar right?
Old 11-03-2011, 04:47 PM   #14
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
The peak boost is higher to increase torque then tappers down to as low as 0.8 bar at peak horse power depending on model year and engine.
When you use a HKS SLD to remove/bypass the speed limiter boost control is still intact throughout the rev range in all gears, also above 180 kph.
Marnix is offline   Reply With Quote
Old 11-03-2011, 04:52 PM   #15
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
How about if using the Pivot one? Would that also control boost above 180 km/h?
http://www.pivotracing.com/product/SML
Old 11-03-2011, 07:53 PM   #16
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Sorry, my information is from ROM and that has to do with cars which are newer than 2002. I'm not in this forum that often.
Old 11-03-2011, 07:57 PM   #17
ChestyPuller
Member#: 293281
you sure about that?
ChestyPuller is offline   Reply With Quote
Old 11-03-2011, 08:10 PM   #18
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
This forum is for cars before 2002. Within this forum, the information which I have (which applies to cars newer than 2002) does not apply.
So, no, I am not sure that for JDM Sti older than 2002, like V4,5,6, what I said applies, it probably does not.
Old 11-03-2011, 08:12 PM   #19
ChestyPuller
Member#: 293281
I mean for v7+
Old 11-03-2011, 08:27 PM   #20
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
V7 has a speed limiting wastegate. I have tried to increase it in the software at it and it can be lifted upto 158MPH. I had thought that it's maxed stock.
On my V9 it has to do with the boost compensation per gear.
Old 11-03-2011, 08:30 PM   #21
ChestyPuller
Member#: 293281
interesting. I wouldn't think a 16bit ecu would have the ability to control boost at speed.
Old 11-03-2011, 11:49 PM   #22
thatsoobguy
Member#: 284562
interesting
thatsoobguy is offline   Reply With Quote
True or Not True :) wrx_dad Texas Impreza Club Forum -- TXIC 12 04-23-2008 07:18 PM
Not sure if this is true or not, but.... I AWD I Off-Topic 8 03-01-2005 03:01 AM
true or not true?? wRxbeater11 Member's Car Gallery 2 12-20-2002 11:49 AM
OT:Monday Humor -- [don't know if it's true or not] SilverSuby General Forum Archive 2 08-30-2000 06:12 PM
