Old 11-03-2011, 11:12 AM   #1
benit0
Member#: 202204
02 WRX
Default PhatBotti Tuned - 205k Mile 02 WRX Wagon - 12.4 @ 111
Event: Dyno Day @ Mile
Location: Speed Industry, Troy MI & Milan Dragway, Milan MI
Ambient Temp: 50-60 throughout the day
Elevation: 600-700ft above sea level
Weather: cloudy/dark(night)
Track and Conditions: decently prepped track. Cooler out, was gripping pretty good for my self. Dry out. Slightly up hill
Tires: Dunlop Direzza Sport Z1 Star Spec – 205/55/16
Car: 02 WRX wagon
Tuner: PhatBotti – Remote tuned.
Dyno Info: Mustang Load Dyno
Transmission: 5spd stock gearset
Gear: 3rd/4th gear pulls
Peak HP at RPM: 279
Peak Torque at RPM: 282
Baseline hp/tq for a stock on same dyno: Recently a stock '11 WRX put down 210 whp on the same dyno, and other stock 04-07 do 200-210 regularly
Target Boost: 22 psi tapering to 18psi
Target AFR: 11.3:1
Fuel: e85
Engine/Power Modifications: 100% original long block @ 205k miles.
Invidia V2 3” Downpipe
RSR GT2 3” 3” Exhaust
Ebay Up-pipe
IHI VF-22
Walbro 255
Power Enterprise 800cc Injectors
Grimmspeed 3mm Phenolic Spacers
TGV Deletes
APS 3” Hard Inlet
Injen Short Ram w/ an AMR filter
APS DR525 FMIC
TiAL 50mm BOV
Grimmspeed EBCS
Driveline Modifications: 100% Original 02 5 speed trans w/ an OEM Exedy replacement Clutch
Revshift Motor Mounts
Revshift Trans Mount
Shifter Bushings
Suspension Modifications: Original springs/struts
Front Control Arm Bushings
Whiteline Front Sway Bar (19mm I think?)
Whiteline low roll center ball joints and tie rod ends
I purchased this car last year in June @ 164k. I've since put 40k on it in just over a year. When i purchased it, it was 100% stock.
Did the whole Stage2 setup within the first two weeks of owning the car and ran a 13.7 @ 101 at Ubly in Ubly, MI last year.
coming into spring of this year when the vf22+e85 setup came to play and i couldn't be more happy with the results.
The Dyno below is actually a layover of my car PRE and POST FMIC/3" Inlet and Intake w/ a retune. The oscillation you see only happens on the dyno for some reason. it was having issues staying @ 22psi on the dyno. But on the street it has no issues what so ever. we did a 4th gear pull (second dyno sheet) over layed with the other two and you can see the oscillation is not there.
Dyno w/ Old vs New overlay (both tuned by PhatBotti)
Second Dyno Sheet w/ all 3 of my pulls.
Video of my car on the dyno
My Timeslips - Please note, the date on the systems @ Milan are always wrong. they never fix them. I scanned these last night. If needed, i can take pictures of all 12 of my slips laid out on a table with a tag. The last sheet i have on there is the 12.6 run. I rolled slightly after the light went and it cut me a bad 60'... but i still ran a 12.6. the car has a 12.2 in it, and maybe an 11 if i push it hard enough. but im done for the year with this setup and im extremely happy with the outcome.
Big thanks to PhatBotti for the awesome support and tune!
benit0 is offline   Reply With Quote
Old 11-03-2011, 11:41 AM   #2
URABUS07WRX
Member#: 262367
2007 WRX
nice run. are you down on woodward at all?
URABUS07WRX is offline   Reply With Quote
Old 11-03-2011, 11:44 AM   #3
benit0
Member#: 202204
02 WRX
Yep! during the summer im out every friday/saturday generally!
Old 11-03-2011, 11:54 AM   #4
stu
Member#: 25768
35R bugeye
Slowbaru
with a good 60ft you will shave quite a bit off your time. possably an 11.xx
stu is offline   Reply With Quote
Old 11-03-2011, 12:27 PM   #5
URABUS07WRX
Member#: 262367
2007 WRX
same here. i usally park at Pasquale's since royal oak 5-0 always seems to kick us out thanks to those who burnout every time they leave the lot. maybe ill see you done there next summer
Old 11-03-2011, 02:05 PM   #6
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
nice runs!
FCmaniac is offline   Reply With Quote
Old 11-03-2011, 04:06 PM   #7
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
this thread makes me miss my vf22'd 02 wagon gluck w/ her and nice driving!
wrxtremeWGN is offline   Reply With Quote
Old 11-03-2011, 04:15 PM   #8
treystoys
Member#: 97436
05 Legacy GT
white
Awesome numbers man I love seeing the vf22 runs. I've often considered going back to a set up like this and getting rid of the rotated set up, just seems like a fun daily use car! Also big thumbs up on the 200k+ miles near 300whp and still going...very cool!
Trey
treystoys is offline   Reply With Quote
Old 11-03-2011, 04:46 PM   #9
benit0
Member#: 202204
02 WRX
thanks guys!
yeah, the car is a blast. I'm pretty anal as far as maintenance goes so fluids get changed out constantly. It doesn't feel like 200k. it actually feels better then a good friends 60k car.
Depending on what happens next year, I really wanna try for 11's on a stock block VF22 wagon w/ full interior. Then it'll be big boy numbers after.
Old 11-03-2011, 05:02 PM   #10
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
thanks guys!
I approve this message.
Subian is offline   Reply With Quote
Old 11-03-2011, 08:42 PM   #11
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
Nice runs - were you using launch control or anything? What rpm were you launching at?
langsbr is offline   Reply With Quote
Old 11-03-2011, 11:30 PM   #12
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Lets see 300k!! Hahaha, Car has a 12.0-12.1 pass in it. Awesome numbers for such a high milage block!
-Mikey
STi Mikey is offline   Reply With Quote
Old 11-03-2011, 11:57 PM   #13
benit0
Member#: 202204
02 WRX
Actually, using launch control yielded me with worse 60's.
Generally i hold it around 5-6k and slip it in for a split second then full throttle and pull off the clutch. does me really well. if my clutch wasn't slipping as bad i could have easily hit a 1.7
Mikey, to be honest. I think a clutch, ewg, and pushing it a bit more i could hit 11's..... When i have the next block and trans ready to go, i'll bring a truck and trailer with me to the track and push it to the limit one last time before i swap everything.
Old 11-04-2011, 12:29 AM   #14
ErrDayToday
Member#: 299941
where is this?
ErrDayToday is offline   Reply With Quote
Old 11-04-2011, 09:06 AM   #15
benit0
Member#: 202204
02 WRX
Originally Posted by ErrDayToday View Post
where is this?
Southeast Michigan. Or were you wondering about where i dyno'd and 1/4'd it? If so, its in the content in my first post.
PHOENIX - Beautiful stock 02 WRX Wagon - CLEAN and great price - $8300 SRuzhyo Private Vehicle 'For Sale' Classifieds 11 05-12-2009 05:34 AM
IL: 02 WRX Wagon - 44k miles gremy60 Private Vehicle 'For Sale' Classifieds 1 04-02-2006 06:42 AM
02 WRX Wagon - Jax Fl - low miles RedTRex Private Vehicle 'For Sale' Classifieds 5 11-03-2005 09:16 PM
02 WRX Wagon - Vishnu Stg. 1 - NorCal DamonL Private Vehicle 'For Sale' Classifieds 0 03-21-2005 03:32 AM
WRX Wagon 4EAT 12.156 @ 111.36 MPH No NO2 Saposat Proven Power Bragging 51 09-10-2003 02:41 PM
