Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 11-04-2011, 03:40 AM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Lightbulb Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone?
I posted this thread on the FT86 forums, but figured I'd start one here too in order to get more info out of the more knowledgeable Subaru folks...
The basic idea is this: Take the shortblock from an FB25 and use it with with the proposed FA20 motor, which SUPPOSEDLY is a FB20 with heavily modified heads to use the Direct Injection system.
Quick comparo pick from what we've seen so far:
At this point we have NO idea whether or not this will work, or how much the FA20 is different from the FB motors. But from what I can tell so far, they are pretty darn close.
I'm presuming the bolt pattern is the same and nothing on the shortblock side (other than the crank/rod/pistons of course) is different. There might be issues with accessory locations and bolt holes, but again, no idea.
The bigger concerns I have are about the coolant channels and such and hopefully it isn't TOO different, but anyway the idea is pretty simple and has been done a billion times here on NASIOC....
Increase the displacement and compression ratio easily.
Thoughts, opinions, more info???
Old 11-04-2011, 10:24 AM   #2
UKscooby
Member#: 33287
RIP Nik
I will always miss you
I thought that the FB heads have the blank castings for the DI injectors?
UKscooby is offline   Reply With Quote
Old 11-04-2011, 12:02 PM   #3
Wagon Of Fury
Member#: 47982
You sound alot like that guy in OT who has been restoring this 1970's Subaru for like the last six years and hes always mixing and matching parts and all this crazy shi...
(looks at username)
OH, You !
Wagon Of Fury is offline   Reply With Quote
Old 11-04-2011, 12:15 PM   #4
V3rtigo
Member#: 262020
2013 STi-Limited
PBP
Isnt the FA supposed to be a higher reving motor? I would think this would lead to some changes in the bottom end.
V3rtigo is offline   Reply With Quote
Old 11-04-2011, 09:25 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
You mean the spots are on the head already?
The FB20 revs pretty high already.
The FA20 is supposedly a 86 bore by 86 stroke block.
Old 11-09-2011, 10:15 PM   #6
RallyColtTurbo
Member#: 16819
Is the HP fuel pump drive off the heads or the block? That will likely be your answer to a "simple" head swap. If the fuel pump is off the block somehow, the block will need to be retained and bored/sleeved.
However, if all the DI stuff is contained to the heads, I'd lay real money it will be almost as easy as an "old school" hybrid. Subaru always seems to design with the Lego mentality.
RallyColtTurbo is offline   Reply With Quote
Old 11-16-2011, 01:14 PM   #7
Keshav
Member#: 1654
1998 GC8 Unicorn
MV Agusta Brutale S
hard to argue with more displacement if it doesn't hurt your redline at all. The Japanese regulations favoring 2.0 ltr engines need to diaf.
Keshav is offline   Reply With Quote
CAR AND DRIVER: 2010 Mazda 3 s 5-door Sport; More Displacement, More Power Tea cups Non-Subaru News & Rumors 13 06-16-2009 02:14 PM
CA - 03 WRX with 2.5L shortblock and more! blueaway Private Vehicle 'For Sale' Classifieds 5 04-17-2008 06:10 PM
what i am doing with my new 2.5l sti shortblock sonic rx Built Motor Discussion 3 03-31-2006 06:48 AM
more displacement/stroker kit = how much less lag with big turbo? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-05-2002 12:30 AM
stroking the EJ engine for more displacement chyisan Technical Forum Archive 31 09-06-2000 01:53 PM
