Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 11-04-2011, 09:44 AM   #1
99imprezd
Member#: 198964
2004 WRX wgn, built!
Default Retuning Question?
Ive got an '04 EJ20 WRX I just did a fresh stock rebuild with ACL Main & Rod Bearings. The car runs frkn awesome and has about 2000 miles on it so far. I got the car with (a rod knock which is why I rebuilt) Had an ebay catless Up pipe and 3" Catless Bellmouth downpipe. HKS Seq BOV, Stock turbo and inlet. Stock airbox with a K&N filter, stock mid pipe back to a stock axleback. It also has a Stage 2 Cobb Tune.
Both the up-pipe and downpipe were rusty from the heat wrap around it and cracked. I replaced the up-pipe with a Perrin catless and the Downpipe with an Invidia V2 catless. When the exhaust was leaking it actually sounded pretty good suprisingly but now you can barely even hear it running until you boost it up. My question is do I need to recalibrate the tune when the same parts are replaced with better ones? I havent played with the Cobb tuner yet but will this effect the way the car performs?
99imprezd is offline   Reply With Quote
Old 11-04-2011, 10:28 AM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
What do your Cobb map notes say about this?
Old 11-04-2011, 10:31 AM   #3
99imprezd
Member#: 198964
Havent got that in depth into it.. Just curious how sensative different parts may effect what the car is tuned for. After work Im gonna dive into it!
Old 11-04-2011, 01:06 PM   #4
Cobb Tuning
Member#: 4803
I would go ahead and reset the ECU via the AccessPORT, but you are good to go with the stage 2 OTS map since you fit the minimum requirements (stock intake, aftermarket downpipe).
Bill
Old 11-04-2011, 01:28 PM   #5
99imprezd
Member#: 198964
Okay, does this reset the ecu to the base tune and then the computer relearns based on my particular setup or something along those lines?
Another question.. Are there any upgrades that I should stay away from with a Stage 2 (93) tune? As far as a short ram intake, Silicone Turbo Inlet Hose or perhaps even a 16g turbo?
Thanks for your input!
Bill
Old 11-04-2011, 02:36 PM   #6
Cobb Tuning
Member#: 4803
Resetting the ECU just resets the learned parameters - it does not change the tune. Unless you were running a real-time map different than your "reflash" map. In that case, the real-time map would simply be reset to the reflash map.
The only intakes that are compatible with our 02-05 WRX OTS maps are the stock and Cobb SF intakes. Do not use any other intake with these maps. Also, stock turbo and injectors are required for all our stage 1 and stage 2 OTS maps. An aftermarket turbo inlet is, however, acceptable for these maps.
For the 02-05 WRX, we do have some stage 3 maps for specific turbos and injectors. You can check these out in our map repository:
http://www.cobbtuning.com/info/?ID=3061
Bill
Old 11-04-2011, 02:47 PM   #7
99imprezd
Member#: 198964
Okay sweet.. Ive got some reading and re-flashing to do. Cobb makes excellent products... You guys Rock!
Question about retune pauldriscoll123 Newbies & FAQs 8 09-22-2011 09:17 PM
Retune question! AWESOME Newbies & FAQs 15 07-15-2011 01:31 AM
Question about geting retuned Nettalp Newbies & FAQs 1 02-10-2008 08:47 PM
Rebuild and retune question Splinter Pre-2002 Factory Turbo Powertrain 13 02-08-2008 07:17 PM
TurboXS DTEC BC question... Ok to turn boost WAY down without retune? cah Newbies & FAQs 0 01-02-2007 06:26 PM
