Old 11-04-2011, 10:41 AM   #1
STIll inspired
Member#: 248431
Default turbo crossmember fitment?
hey all i am in need of some help. i am going to be swapping my 2000 legacy gt soon and i don't want to notch my crossmember for the up pipe fitment. i was curious what crossmembers are a direct swap in and what other parts should i get with that crossmember. i was curious if a wrx crossmember would fit and would i need the front sway bar and any other parts. thanks
STIll inspired is offline   Reply With Quote
Old 11-05-2011, 12:21 AM   #2
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
I'm not exactly sure if there is a direct swap?
U will have to match the steering rack w/ the crossmember most likely & possibly the slip joint
sense of nature is offline   Reply With Quote
Old 11-05-2011, 09:40 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
baja turbo comes to mind
Old 11-05-2011, 06:41 PM   #4
STIll inspired
Member#: 248431
Baja turbo FTW thanks that is perfect for what I need
Old 11-06-2011, 12:28 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
you will also need a turbo front sway bar. the NA bar hits the crossmember where the up pipe goes...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 11-06-2011, 09:17 AM   #6
STIll inspired
Member#: 248431
thanks again this was my this is something i imagined was needed. i also wondwer if the sway bars match from the wrx i might as well upgrade these things while i have it all apart when the time comes
Old 11-06-2011, 11:02 AM   #7
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
If you use the baja turbo crossmember I think you still have to shim the front control arm mount, just like if you used any WRX front crossmember. Did the baja turbo crossmember have a thinner control arm bushing?
For a direct swap, I know the old Legacy turbo '91 though '94 crossmembers work.
speedyHAM is offline   Reply With Quote
Old 11-07-2011, 07:32 PM   #8
STIll inspired
Member#: 248431
^good info would i need the steering rack from the 91-94 legacy?
turbo crossmember in a non turbo car? Mauricio Subaru Conversions 4 06-06-2013 11:16 AM
Crossmember fitment RllyGC Subaru Conversions 9 04-16-2009 09:50 AM
Turbo Legacy Turbo CROSSMEMBER 150. serious Engine/Power/Exhaust 5 04-07-2009 03:57 PM
02 Vs 04 Rear suspension crossmember fitment flyinghighlm Newbies & FAQs 0 03-28-2009 05:51 PM
wtb: legacy turbo crossmember, or wrx crossmember, new england area hopefully legacy2003 Private 'Wanted' Classifieds 0 06-21-2005 03:35 AM
