#1 |
Member#: 236464
E. Canada
Vehicle:2005 WRX STi Rally Blue |
Using my phone, I tried to research, or find a good comparison between these two turbos.
With a 350whp goal, what would you choose? -B
#2 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
#3 |
Member#: 191491
NESIC
Vehicle:2006 Subaru STI Aspen White |
I would chose the Blouch. They have better customer service, and you can get a 10cm turbine housing if you want. A lot of people love the green, however a lot of people also hate FP's customer service. I would take a regular 20g-xt over the xt-r. The 20g-xt will get you to 350whp with less boost, and I hear they spool pretty well. If it breaks it will be a lot cheaper to repair too.
#4 |
Member#: 236464
E. Canada
I guess I was looking for flow charts, and what not.
My Tuner also said Blouch 20G. Said they spool very quick, for a 20G. My friend just got an FP Green, 350+whp. But from my reading they have a 7 or 8cm housing. My friend said his 5 and 6th gear suck. We both have 2.5L but the JDM transmission. I think I would like a 3" Inlet with 10cm housing for a bit more top end. I read on the FP site, the green was like a 59 for flow, while the biggest Blouch doesn't come close to that. So I thought there was some sort of confusion. FP Green Link Quote: "The new for 2008 HTA update for the FP GREEN HTA™ for Subaru STI/WRX delivers an increase in maximum flow rate from 49lb/min to over 56lb/min without an increase in turbo lag, while also decreasing compressor outlet temperatures with better compressor efficiency than previous models. " Blouch 20G XT-R Quote: " 47lbs per min " -B |
#5 | |
Member#: 250152
Also by comparing the Green and the 20g, your are comparing apples to oranges. The Green is a 30r based turbo. The 20g is much smaller in comparison. The equivalent to a green would be the Dom 3 (55lb/min 30r based). Last edited by 2Fast4U1DAY; 11-05-2011 at 07:26 PM. |
#6 |
Member#: 191491
NESIC
I would just listen to your tuner. Tons of people are running 20g setups making around 350whp.
#7 |
Member#: 236464
E. Canada
1. No question about listening to my tuner.
2. I'm not mistaken, I was quoting directly from their website(s). I agree, I am begining to see my apples and orange comparison. Thanks! Why 20G XT or 20G XT-R? -B Last edited by fbi; 11-05-2011 at 11:58 PM. |
#8 | |
Member#: 250152
#9 |
Member#: 236464
E. Canada
you're right, I thought I deleted that comment. will do so now.
#10 |
Member#: 120461
BAIC
Vehicle:2004 WRX STi JBP |
i think the main difference between the xt-r and xt is that the xt-r is ball bearing where as the xt is a journal bearing..
the xt might also have a slightly larger compressor wheel - it is quoted on the blouch site as putting out a bit more hp than the xt-r... |
#11 |
Member#: 243616
Vehicle:2010 wrx gh stage 2 DGM |
bumping this... looking at the xt-r for a DD... blouch is having a sale today... X_x
#12 |
Member#: 220114
NWIC
Vehicle:07 2.5i EJ257 6MT FP Green on E85! |
My 7cm 2.4" OG green made 333/325 at the wheels on 91 octane. Not sure what kind of fuel you have.
http://http://forums.nasioc.com/forums/showthread.php?t=2177879 |
#13 |
Top Scoob 022
Member#: 129894
SCIC
Vehicle:FSTI '04 4EAT Sierra Gold Metallic 20G-XT, EWG |
I have no info on FP, but Blouch has been nothing but helpful in the local community. Some say the new 20g is a cheater 30...
![]() Cherries to berries comparo... My friends 05 fxt 4eat, and my 04 fxt 4eat were tuned on same dyno, different days....tuner was intrigued that I made more power (5 hp?), as he used his baseline map to get me going...b/c we have similar mods. Him: built shortblock, blouch polka pickle 2.5 xtr 10cm,torque converter, spearco tmic. 75 degrees Me: stock block, blouch td06 20g-xt 8cm, ewg, sti tmic, 95 degrees. Not huge numbers on paper, but just some food for thought when choosing turbos. We are both tuned on 91 and pushing 21psi...I wish there was some 1/4 mile options here in so-cal so we could get to flexxing emuscles. ![]() |
#14 |
Member#: 298231
Vehicle:2011 Subaru WRX WRB |
i had been looking at the blouch 20g after hearing about the customer service they have compaired to FP... yet a few local shops/tunners have tried pushing me towards the FP green over the blouch 20g. said it is a better turbo and would better for my goals. my goals would be 400 to 450awhp with a built block. big difference there but i would be willing to accept 380awhp too. so take out of that what you will.
#15 | |
Member#: 152685
NESIC
Vehicle:2005 VF34 WRX Wagon WRB |
#16 |
Member#: 128022
Vehicle:2009 WRB STi 2007 Nissan Altima |
| Thread Tools | |
| Display Modes | |
| FP Green vs. FP Green HTA vs. HTA 68 vs. MAPerformance "New Age 20G" | KenSekiguchi | Factory 2.0L Turbo Powertrain | 45 | 06-22-2011 04:09 PM |
| WTT : My Blouch Dom3 for your FP GREEN, APT3071, Blouch polkapickle 2.5r etc | rexworx | Private 'Wanted' Classifieds | 10 | 01-26-2011 08:26 PM |
| TD06 20g VS. FP GREEN VS. DOM | BlackFighter | Factory 2.5L Turbo Powertrain | 19 | 03-01-2010 04:15 PM |
| Fp Green VS Fp Green HTA | 06BluePearl | Factory 2.5L Turbo Powertrain | 5 | 06-27-2008 06:32 PM |
| FP Green vs Deadbolt 20G | STI spec D | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 05-17-2005 10:34 AM |
