Old 11-06-2011, 01:46 PM   #1
Subachouli
Member#: 98777
Default 98 Legacy EJ205 - engine tilted back?
I'm in the process of swapping the EJ205 into my 98 Legacy. I'm using the first generation Legacy turbo crossmember, and the stock WRX engine mounts.
I've dropped the engine in, and it appears that the engine is tilted back. The dogbone transmission mount is about an inch off. I can get the hood closed, but the engine position looks very awkward and the top of the intake manifold is very close to making contact with the underhood shield.
Any thoughts?
Subachouli is offline   Reply With Quote
Old 11-06-2011, 09:46 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Are you sure you have the engine bolted into the mounts correctly and the mounts fully engaged in the crossmember?
Are all the tranny bolts on tight?
speedyHAM is offline   Reply With Quote
Old 11-09-2011, 04:13 PM   #3
AREA1320
Member#: 112508
ummmmm put the engine mount studs into the slots on the crossmember.. or are you sure you have the mounts on correctly?
AREA1320 is offline   Reply With Quote
Old 11-09-2011, 04:19 PM   #4
Subachouli
Member#: 98777
Thanks guys. Had a brainfart. The lower transmission bolts were not fully tightened. Once they snugged up, the engine sat a little more level. I was expecting the engine to sit low in the bay like it does in my WRX, but everything fits and looks fine now.
98 legacy outback - engine options Box This Subaru Conversions 11 08-30-2011 01:39 AM
FS : 98 Legacy 2.2L Engine SubaruJawn Engine/Power/Exhaust 8 09-22-2010 07:43 AM
98 legacy l - radio install tothaneck Legacy Forum 3 10-12-2007 06:52 PM
Should a 98 Legacy have an engine undertray? Snowphun Legacy Forum 3 03-21-2004 07:21 PM
('93-'01) Is a 98 legacy 2.5 engine same as a 99 RS Jimmy Impreza Forum 4 05-21-2001 12:10 PM
