Old 11-06-2011, 04:50 PM   #1
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Default new to accessport help please
ok i have played with utec for years, and well i went to play with the ap, whole different world. so i get a few questions.
1. after you set up the ap with the car do you have to connect the green connectors ever time you change a map, or when the ap is connecter to car?
2. how do you transfer a map for ap to laptop so you can change the map yourself (self-tune)?
3. when you connect the laptop ap and car all together to datalog all you have to do is hit datalog on ap or is there a "start datalog" button on laptop?
any other info would be helpful thanks
spoolinred is offline   Reply With Quote
Old 11-07-2011, 09:47 AM   #2
Cobb Tuning
Member#: 4803
Hi there.
1. You'll need to do the same procedure with the green connectors (i.e. test mode) each time you reflash a map. However, the AP has real-time maps that do not require you to be in test mode. You can flash these real-time maps at any time and the green connectors do not have to be connected. The difference is that the real-time maps contain only 10 table changes. They are 10 of the most tuned tables for boost, fuel, timing, etc. So, you would use them to temporarily make a change such as an economy map, anti-theft, valet, etc. The real-time map will be reset to the reflashed map values when you disconnect the car's battery, reflash another map, or reset the ECU (via AP). You would reflash a map (i.e. with green connectors) when you are making major changes (such as going from a stage 1 to stage 2 map). Note: not sure what vehicle this is for, but later model Subarus (generally 07+ or 08+) do not require the green connectors to reflash.
2. You would use the AccessPORT Manager software and connect your AP v2 to your computer with the software running. It will list all the maps you have on the device and then you can drag and drop map files from your computer to the device. If you are self tuning and have an AP v2, you will be able to request a free copy of the AccessTUNER Race (ATR) software. With this, you can create new maps (and even open and modify our OTS maps). You can also real-time tune the ECU (the 10 or so tables I talked about in #1) by running ATR and connecting the car.
3. Check out our data logging video for the AP v2 below.
Bill
New to AccessPORT and need some help with looking at all this knock... ScoobyDude2002 AccessPort 6 07-26-2011 09:00 AM
i need a new clutch, i have no idea what to buy, help please! litowrx Transmission (AT/MT) & Driveline 9 02-27-2011 08:57 PM
accessport not connecting to desktop. Help Please! ALEwrX AccessPort 4 01-20-2010 07:11 AM
New Here: accessport help... Project Blackhawk Newbies & FAQs 12 09-11-2008 09:11 PM
Just got my accessport... help please... I need to put maps on... NewShockerGuy AccessPort 1 07-28-2006 03:31 PM
