Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 11-06-2011, 05:26 PM   #1
JShort
Member#: 258543
2005 STI Black
RIP 2006 STI :(
Default Can you use a boost controller
I have an 05 STI. I installed an hks boost controller prior to getting an access port. I am running a stage 2 on my access port. Is it ok to leave the boost controller on? Is there anyone in the Delaware county area that I could meet up with that is knoledgable with access port and subies? Would be a great help.
JShort is offline   Reply With Quote
Old 11-07-2011, 09:37 AM   #2
Cobb Tuning
Member#: 4803
Hi there. A boost controller is not compatible with our off-the-shelf (OTS) maps. If you wish to run a boost controller you'll need to get a custom tune. However, there is no need to run one at the stage 2 level. The factory boost control is more than sufficient. I would recommend that you remove the boost controller and put everything related back to stock:
http://www.cobbtuning.com/info/?ID=3482
Bill
Cobb Tuning is online now   Reply With Quote
Can I use this Boost Control Solenoid in place of my stock one? emsmap Factory 2.0L Turbo Powertrain 8 01-28-2011 06:28 AM
What are you guys using for boost control? and EM integration ? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 3 06-29-2008 12:32 AM
can you use rays lug nuts where a typical "tunner lug" is used? (enkei) skingfreak Tire & Wheel 11 03-10-2008 08:31 PM
Can you test a boost controler to see if its working? Jager_Addict Factory 2.5L Turbo Powertrain 7 03-08-2008 10:41 PM
Can you use a lightened crank pulley and LTW flywheel can you use them together? M3toWRXin3seconds Newbies & FAQs 4 03-12-2003 08:10 PM
