Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-06-2011, 05:42 PM   #1
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Default HELP car wont start 2.0 jdm block with Usdm heads
Well after doing this build, my wrx wont start,ok some details,02 wrx 5 speed 118000 was on the motor before I pull it out the car and the was a running motor with RomRaider tune Up pipe, headers,turbo inlet,down pipe and more on the car also.
The 97 jdm ej20k automatic motor came complete and I only used it cause Tiger did not want to take it back cause its not what I wanted
Any way I decided to used the block only and reuse all the Usdm parts onto it and I have never did this before but I went in.
So now that's its all complete it would turn over but not start,no check lights also also I can hear the starter hitting the Act flywheel on turn over
I have swapped the crank sensor ,checked for fuel and I can hear the fuel pump, timing belt looks good,starter was checked at Auto Zone but I to I will do these steps next , make sure the battery has good cranking amps, change cam sensor,check for spark and do a compression test .
I think its electric but what you guys think and also the starter to hitting the flywheel ,you can email me at [email protected] if you wish I just need some HELP Please.
Here are some pics
Usdm motor and the Clutch was shot.
Jdm block with everything else Usdm ,here is the timing blet pic
Act fly
Clutch done.
Starter with a noticeable marks to the front of it
t.
trinistyles is offline   Reply With Quote
Old 11-06-2011, 07:55 PM   #2
theonlygreat
Member#: 65916
1996 Impreza WRX
You needed to swap the crank shaft timing gear to the phase 2 style.
theonlygreat is offline   Reply With Quote
Old 11-06-2011, 07:56 PM   #3
theonlygreat
Member#: 65916
1996 Impreza WRX
Old 11-06-2011, 08:47 PM   #4
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Thanks for your help theonlygreat ,looking at my Usdm motor I can see the differace ,o well at lease I have the crank shaft gear at hand I will start on it tomorrow and will you know how it turns out,thanks again
Old 11-06-2011, 10:40 PM   #5
theonlygreat
Member#: 65916
1996 Impreza WRX
Did you use the thicker 1.37mm head gaskets for this build? I see you didn't use the tiny idler gear, so I hope that means yes. If you went with stock 02 WRX head gasket, your quench is going to be a bit tight and you may end up with some piston to head contact. The thicker gasket + usdm heads also lowers the compression to around 7.8:1 so you can turn up the boost
Old 11-07-2011, 01:27 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
A few remarks:
- there is no such thing as an EJ20K automatic, if it was automatic it must be EJ20G.
- you have to use 1.4 mm head gaskets and not the 0.8 mm USDM WRX gaskets, pistons WILL hit the head
You've got the wrong crank shaft sprocket on there, use the one from your USDM engine and it will start up fine (after you've changed the head gaskets, obviously or you could ruin the engine instantly).
Marnix is offline   Reply With Quote
Old 11-07-2011, 07:23 AM   #7
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Gasket uses was .051 and I can't use the idler cause the Jdm block don't have a bolt hole for it as for the motor I am guessing I have one of these wrx gf8d58p Or gf8e58p ej20g 240 auto motor not a K as I posted on top,under the oil cap has 97 but that could be wrong also,but its a g.
Thank for the input and if I missed some thing let me know.
Old 11-07-2011, 07:32 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Sounds like just changing the crank sprocket and drive it - good luck!
Old 11-08-2011, 08:52 PM   #9
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
After replacing the Jdm crank gear with the Usdm it started right up,thanks again guys ,now its the breaking on the clutch, flywheel and motor,will keep you posted.
Old 11-09-2011, 10:03 AM   #10
ToneWrx02
Member#: 239095
2002 Wrx
Hey just checking up on you and making sure the parts I sold you came in handy. Lucky for you man! Coongrsts on your engine
ToneWrx02 is offline   Reply With Quote
Old 11-12-2011, 08:50 AM   #11
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Thanks man,I did not use them cause I took apart my heads,I will post up all the pics of what I did on getting this swap up and running to aid those like my self who ask the same question ,can it be done and the answer is Yes.
Old 11-19-2011, 01:02 AM   #12
luka
Member#: 194742
1993 Impreza WRX JDM
what's the difference between the two sprockets?
luka is offline   Reply With Quote
Old 11-20-2011, 04:40 PM   #13
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Look close B,look at the back ,its not the same is it.
Old 11-21-2011, 09:03 PM   #14
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
The reason you need (at least on paper) the extra tiny idler is because the thinner headgasket (all phase 2 engines) introduces extra play in the timing belt. thats why the phase 1 engines (EJ20G, EJ20K, usdm EJ25D) with 1.3mm-ish headgasket does not use the extra idler.
examine not the belt surface but the very outer edge, there are different notches which is how the crank sensor determines position. it changed in phase 2 engines
elislider is online now   Reply With Quote
Old 12-21-2011, 06:18 AM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
It doesn't bolt into the block. It bolts into the bracket that the tensioner is attached to. Swap those brackets if you want the small idler.
Old 12-24-2011, 10:40 PM   #16
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
If there was a bracket for the idler I would use it but there is no bolt hole on the block look very close at the pics and where the red arrow is at.
Jdm block
Now look at the Usdm block
HELP!!!! Car wont start with FULL battery?!?!?! harrymaneuvers Electrical & Lighting 3 10-21-2011 01:32 PM
Need help!! Car wont start!! 1997 subaru legacy 2.5 GT BallzToTheWallz Normally Aspirated Powertrain 1 02-16-2010 11:20 AM
jdm 2.0 wrx block with usdm wrx heads? YFZ450CHUCK Built Motor Discussion 6 03-01-2008 10:02 PM
Help, Car wont start... friday the 13th, coincidence? biggreen96 Legacy Forum 15 12-15-2002 03:34 PM
Car WOnt Start, 2 weeks old emprezadent General Forum Archive 3 02-03-2001 06:27 AM
