Old 11-06-2011, 09:19 PM   #1
JDMdrifter
Member#: 218144
99 Impreza 2.5RS
WRX blue
Default EJ20K speedometer help
I swapped my 99rs with a V3 EJ20K JDM, unfortunately the speedometer cable is too short, i am using the JDM cluster. and the cable is mounted on the RHS of the tranny, is there an extended cable that will longer or using the USDM cable?
but i figure the cables are the same length just positioned on either side, JDM or USDM
I dont want to change clusters, and also where is the VSS located for the V3?
Please help !
JDMdrifter is offline   Reply With Quote
Old 11-06-2011, 10:49 PM   #2
theonlygreat
Member#: 65916
1996 Impreza WRX
You just need a USDM cable. The VSS is part of the instrument cluster. The ECU gets the speed signal from the cluster.
theonlygreat is offline   Reply With Quote
Old 11-06-2011, 10:55 PM   #3
JDMdrifter
Member#: 218144
99 Impreza 2.5RS
WRX blue
Great thanks, 97-down impreza speedocables would fine?
Old 11-07-2011, 12:55 AM   #4
theonlygreat
Member#: 65916
1996 Impreza WRX
I'm not sure of the year range exactly (I know 96 uses a cable), but any Impreza or Legacy with a cable should work.
Old 11-07-2011, 01:24 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
All transmissions have the speedo gear on the RH side so USDM cable is longer, use that one.
Marnix is offline   Reply With Quote
speedometer help Jadakisz Interior & Exterior Modification 0 10-24-2011 01:48 PM
speedometer help 25rsESP Electrical & Lighting 2 01-10-2007 07:15 AM
speedometer help winorlose2221 Newbies & FAQs 3 08-04-2006 01:52 PM
speedometer help winorlose2221 Texas Impreza Club Forum -- TXIC 0 08-04-2006 01:54 AM
Speedometer Help Needed… xcntrk75 Subaru Conversions 4 04-18-2005 11:46 AM
