Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 11-07-2011, 03:19 PM   #1
Thacrudd
Member#: 254012
Default alternator tensioner bolt - will you look at yours?
Been meaning to ask this for a while. The bolt to secure the tensioner just under the alternator belt is really close to the belt. To tension the belt enough it pretty much runs that securing bolt up to almost touching the belt, literally less than a 1/4". This is with a brand new belt as well. It's an 05 automatic. Is yours like that? I've examined and looked at it a ton and I don't see any other way of doing it. I may be just having a moron moment...
Thacrudd is offline   Reply With Quote
Old 11-07-2011, 09:43 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
1/4" isn't bad. Did you get the right size belt? You may be able to get a shorter belt if it makes you feel better. They're usually pretty close though.
CosmoTheCat is offline   Reply With Quote
Old 11-08-2011, 12:44 PM   #3
Thacrudd
Member#: 254012
It's closer than.1/4" tbh. I have it tightened enough to where it just barely doesn't rub. If I don't then it squeals. I didn't know if anyone else's was like that or not.
Old 11-08-2011, 05:52 PM   #4
hocrest
Member#: 40687
I changed belts today with this post in mind.
With the old belt the clamp bolt was about 3/4 inch below the belt. With the new belt the bolt is just about in contact with the belt. I want to check the belt size listed in different catalogs and see if there is any variance.
hocrest is offline   Reply With Quote
Old 11-08-2011, 08:57 PM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Are all of your belts OEM? If so, there will be a number printed on them, it's the length in MM.
Old 11-09-2011, 08:53 AM   #6
Thacrudd
Member#: 254012
Nope, I've changed them. I'll swing by the auto store and see if I can get a shorter one and update here.
WTB : 02 02 WRX Coin Tray and Alternator Tensioner Bolt fokai Private 'Wanted' Classifieds 1 02-26-2011 02:36 PM
If you look at her long enough, you will get an STD GodWhomIsMike Off-Topic 193 03-31-2010 09:14 AM
WTB: Alternator tensioning Bolt and Nut Jus Blaze Private 'Wanted' Classifieds 7 04-16-2009 10:40 AM
Semi-Emergency: Need an alternator tensioner bolt for 02 WRX or place to find it gryph Texas Impreza Club Forum -- TXIC 10 10-30-2005 01:05 PM
Alternator tension bolt and block that it screws into subiekid Private 'Wanted' Classifieds 0 09-04-2004 08:30 PM
