Old 02-05-2012, 02:59 PM   #26
Carbibbles
Member#: 292996
02 wrx
Originally Posted by ride5000 View Post
today i verified this rom passed a RI OBD2 emissions control inspection...
with a disconnected maf sensor.
That's great, thanks for the verification
Carbibbles is offline   Reply With Quote
Old 02-05-2012, 03:04 PM   #27
Carbibbles
Member#: 292996
02 wrx
Originally Posted by Equilibrium Tuning View Post
Very nice! I have a customer car that could greatly benefit from this but we'll have to round up an 03 ECU. I wish this worked on an 04.
-- Ed
I hope to add the ability to flash this ROM to 04-05 ecus eventually. I know its possible, I just need to figure out the flash routines
Old 02-06-2012, 12:07 PM   #28
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^^^^YES i hope you too add the rom for 04 STis !!!!!!! I have a couple of twenties i could donate
Paidfor is offline   Reply With Quote
Old 02-08-2012, 10:34 PM   #29
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
This is definitely impressive stuff.
codesoccer is offline   Reply With Quote
Old 02-09-2012, 02:26 PM   #30
glaciuz
Member#: 222747
2002 STi v7 Wagon
Will run this rom on my PTE6262-B setup!! I will donate for SURE. Thank you.
glaciuz is offline   Reply With Quote
Old 02-09-2012, 09:07 PM   #31
Nuke209
Member#: 108089
2003 WRX
NF Performance
I really don't think there's a limit with this rom.
Tune it properly and you should be fine
Nuke209 is offline   Reply With Quote
Old 02-15-2012, 03:47 PM   #32
jdchmiel
Member#: 926
now when you say 16 bit ecu's you only mean WRX right? Not the 00 / 01 16 bit MAP based NA motor ecus? I would kill for a, 01 USDM reflash.
I mean, I have only been waiting for 12 years for it to happen....
jdchmiel is offline   Reply With Quote
Old 02-16-2012, 01:03 AM   #33
slinkyWRX
Member#: 280483
03 Bugeye WRX
i dont think it is tested for those ecus.
but you could try...
slinkyWRX is offline   Reply With Quote
Old 02-16-2012, 01:04 AM   #34
slinkyWRX
Member#: 280483
03 Bugeye WRX
you will probably need a bigger MAP sensor.
but with this rom you can do all the map sensor offsets and make it work perfectly smoovvvvv.
Old 02-16-2012, 01:06 AM   #35
glaciuz
Member#: 222747
2002 STi v7 Wagon
Yup, I bought a GM 3Bar map.
Old 02-16-2012, 01:46 AM   #36
Carbibbles
Member#: 292996
02 wrx
The STI(USDM) runs a 32bit ecu and this rom will not be compatible with it. There are a couple guys working on 32bit hacks though, speed density is out for a handful of models.
Definitely interested to see your results. It would be great to see some big power on this rom
Unfortunately it is only for the wrx(all markets), and certain STIs (JDM, EDM, ADM); with non-drive by wire ecus.
Old 05-09-2012, 08:53 PM   #37
03aksuby
Member#: 167827
2004 STi
Running the 32bit SD map now, oh how I would love the map switching features of Group-N!
03aksuby is offline   Reply With Quote
Old 05-10-2012, 09:59 AM   #38
jdchmiel
Member#: 926
I would still kill for an 01 USDM reflash. that or pay hundreds of dollars...
Old 05-16-2012, 01:16 AM   #39
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Wow, this is a massive project! I hope people are showing their appreciation by donating. If you are looking at doing the same for the 32bit ECUs I'm going to be all over this!
2010 WRX Limited is offline   Reply With Quote
Old 05-16-2012, 01:37 PM   #40
WRick
Member#: 86107
What is the pysical limit of the stock MAP ? I'm assuming 40 psig, and a practical 25 psi of boost. Therefor, the stock map should do the trick for a big proportion of SD users.. ?
My assumption is that people running 3 bar MAP sensors want to run crazy retarded boost, amiright?
just checkin'
secundo, we should be talking IAT's...
Clearance is not so great on cable wire throttles on the opposite side of the turbo.
Here's where I had to mount mine :
Dunno if I'm going to wrap it in something or whatever...
WRick is offline   Reply With Quote
Old 05-16-2012, 02:53 PM   #41
sorrowfulkiller
Member#: 170439
I <3 Lamp
just checkin'
23psig is about the ceiling for resolution on the stock map sensors, any more than that and you need a larger map sensor.
sorrowfulkiller is offline   Reply With Quote
Old 05-16-2012, 03:01 PM   #42
WRick
Member#: 86107
I see.
I'll be very limit with an 18g-td05... should I switch ?
Old 05-16-2012, 07:23 PM   #43
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
fwiw i've been running 25psig and fueling is spot on; MAP output is not flatlined.
Old 05-16-2012, 11:10 PM   #44
codesoccer
Member#: 179573
2002 MBP Bugeye
WRick more details on how you have the sensor configured please.
Old 05-17-2012, 10:11 AM   #45
WRick
Member#: 86107
well it isn't configured yet, but scaling on a GM IAT is pretty staight forward.
http://www.romraider.com/forum/viewt...hp?f=36&t=7841
we are just going to re-wire the IAT that is in the MAF sensor into the GM sensor so the ecu can get the data, and re-scale the IAT sensor in the ecu for accurate readings.
Old 05-18-2012, 10:55 AM   #46
Carbibbles
Member#: 292996
02 wrx
I would like to do some 32bit stuff. When I finish this project i'm going to start working with NSFW and Merp on 32bit hacks.
The IAT sensor is best placed in the intake manifold, this will allow for more accurate density compensation and will result in more consistent fuel trims at low airflow.
Here is where I mounted mine. 9/16" drill and 3/8" NPT tap, right next to the PCV valve under the throttle body.
Old 05-18-2012, 11:43 AM   #47
WRick
Member#: 86107
baller
Old 05-22-2012, 07:13 PM   #48
WRick
Member#: 86107
any imputs related to extreme temperature variations ?
aka canada
aka -30C winter / + 35C summer
Old 05-26-2012, 04:02 AM   #49
dub c
Member#: 145069
Keep It Sleazy
Is anybody removing or relocating the front O2 sensor?
I am curious as to how long it would last if the Anti lag is being used occasionally...
I am hoping to keep everything out of my exhaust manifold/uppipe to avoid potential break-up issues that could crap on the turbo compressor.
dub c is offline   Reply With Quote
Old 05-28-2012, 01:55 AM   #50
dux10
Member#: 235338
2002 Faggin Wagon
srp
Gear determination thresholds: how do you calculate them? I'm using an STI 6spd with not stock tire size....
dux10 is offline   Reply With Quote
Speed Density - OS 16bit Rom - Discuss Here JSarv Engine Management & Tuning 884 07-24-2013 02:39 AM
FS : NM : 05 Mits. Lancer EVO 8 - 2.3L Stroker & Speed density conv. scoobysti05 Private Vehicle 'For Sale' Classifieds 6 04-02-2011 06:18 PM
UTEC, DTEC and Speed Density SloRice UTEC 26 03-21-2007 02:26 PM
PCV on WRX with Speed Density Token-Negro Built Motor Discussion 3 07-21-2006 11:26 AM
please ASAP is the STI speed density or mass air bobturismo Off-Topic 12 04-25-2004 03:45 PM
