Old 11-07-2011, 10:33 PM   #1
clegg318
Member#: 257378
2007 STI Limited
UGM
Default fine knock learn pulling timing
ive finished my 2.1 build and currently breaking it in. its running a vf39/pinks/sti tmic plus tgv deletes. im currently using the ots map for this setup with the timing pulled across the table by 4 large increments. ive been watching my knock feedback and the car is running happy reading 0 all the time unless i bog the car down in 4th or 5th. as such i keep the car out of those situations.
here is my issue. before i can get the car tuned i need to put mileage on it and drive it to and from work to work on it in my bay. the car drives fine with no knock feedback. after 100 or so miles the car starts to pull tons of timing(seen in fine knock learn) in the lower rpm's in every gear but with no knock feedback. if i drive the car with 15% or less throttle(barely enough to accelerate) it runs smooth but if i add any more throttle it pulls the timing and the car loses all power eventually leading to a bucking situation. when this is happening i still see no knock feedback. i thought fine knock learn was a learning based off of the knock feedback? unfortunately i dont have any logs at this time to post up, i will put them up as soon as it happens again and i log it. from you experienced guys, any ideas whats going on here? i know the power loss is from the 11+ degrees of timing being pulled but what im asking is why is it pulling timing if its seeing no knock? any help would be much appreciated, i just don't wanna do any damage before i get it tuned.
clegg318 is offline   Reply With Quote
Old 11-08-2011, 11:26 AM   #2
Cobb Tuning
Member#: 4803
I'm assuming that you are the same person who posted about the surging at the Cobb forums? Feedback knock has nothing to do with fine knock learning. They are two separate knock responses. Fine knock learning is a learned correction based on knock in and of itself. The ECU decides (based on conditions) whether to use feedback knock correction (the default) or changes to fine knock learning or changes to the DAM.
Your car needs a custom tune. With built motors you can sometimes see more false knock, but I wouldn't take a chance here. Get it tuned ASAP.
Bill
Old 11-08-2011, 01:37 PM   #3
clegg318
Member#: 257378
2007 STI Limited
UGM
yeah im planning on getting it tuned as a soon as i can, ive just been a little busy with the death of my mother in law so my wife is in pieces and im just trying to keep her together let alone devote any significant time to my car. actually i wasnt the guy who posted on the cobb forum, i was just wondering if there was any changes i could go in and make in the mean time for safety, i think im just gunna let her sit till i get her tuned, there should already be enough mileage on the engine to be considered broken in. thanks for the feedback
feedback knock and fine knock learning??? please explain. dudenhoeffer02wrx AccessPort 6 06-21-2016 01:10 PM
Fine Knock Learn & Feedback Knock. MakuseruSukotto AccessPort 18 04-26-2015 12:04 AM
i am getting the same fine knock learn at the same rpm everytime? dudenhoeffer02wrx Newbies & FAQs 2 08-08-2011 02:39 AM
constant fine knock learn? olazy AccessPort 5 05-24-2011 12:53 PM
Fine Knock Learning in ATR Tripintaz AccessPort 5 10-01-2010 10:31 AM
