Old 11-08-2011, 12:50 AM   #1
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Default Jdm cv axles
Does anyone know off the top of their head if the axle length of the jdm gc8 / gf8 is the same as usdm gc8 /gf8 axles? Could i replace my gf8 wrx axles with usdm axles such as for an rs2.5?
I am starting to experience some cv knock when turning and since so many jdm usdm parts are lego mix and match it seems important to ask right away so i can start sourcing parts for this project asap. Finding parts here in canada can be a pita on occasion.
TommyAtomic is offline   Reply With Quote
Old 11-08-2011, 12:58 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
yes they are the same length. just get axles for a 1993 impreza and they will fit...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 11-08-2011, 01:32 AM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Thanks. Next and hopefully final quick question. Axle Splines. Outer splines are consistantly listed as 27. And the shaft lengths seem to be within 1/8th of an inch but the inner splines concern me. I have a '93 jdm rhd wrx that regretably has an atx. I see impreza axles for the usdm 93 model year with 23 inner splines or 25 inner splines. Any ideas?
Old 11-08-2011, 12:36 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
pretty much all AWD front axles are the same (93-01 impreza, 90-99 legacy)
if you have a mechanical rear diff, with different L vs R axles in the rear, then 1 axle is a regular 93-97 impreza rear axle and the other axle is super rare JDM/EDM only
if you have a regular open/VLSD rear diff, then you need axles from any 93-97 (phase 1-ish) Impreza. for phase 2-ish (updated interior, "RS" style basically 98+) the diff splines changed but the hub splines stayed the same. (in related news, the 3rd gen legacy 00+ the splines changed on the hub side too)
elislider is offline   Reply With Quote
Old 11-09-2011, 01:14 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
if you are talking about front axles. then almost all EJ tranys both 5 speed and 6 speed had 25 inner splines, the only EJ trans with 23 was the FWD 5 speed in the early 90's.
-=Suberdave=-
Old 11-09-2011, 11:14 AM   #6
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
-=Suberdave=-
Perfect. That just what i needed to know to make sure they give me the right parts. Thanks loads.
Old 01-08-2012, 01:37 PM   #7
Driveshaft shop
Member#: 306253
great info, the axles have about 1" of compression and extension from the center or ride height so any axle that is close will almost always work as long as its not more then .250 to .500 off.
Driveshaft shop is offline   Reply With Quote
Old 01-20-2012, 09:07 PM   #8
LoneDubR
Member#: 253337
Here's a question...
I have a jdm v5 4.11 trans and it came paired with a jdm r160 rear diff and axles. I was told the rear diff was non lsd. This was put in my bugeye. Now i believe i am having rear diff issues and i have a spare 4.11 rear diff from an 97 auto brighton impreza. can i used the axles that came with my jdm rear end?
LoneDubR is offline   Reply With Quote
Old 01-20-2012, 09:08 PM   #9
LoneDubR
Member#: 253337
Old 01-22-2012, 05:56 PM   #10
LoneDubR
Member#: 253337
anyone?
Old 01-22-2012, 07:29 PM   #11
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I'm curious too. I have a Version 4 STi drivetrain (with the DCCD; so does that make the rear diff R180?). Can I use my current hubs to connect the STi axles it came with?
Smoke is offline   Reply With Quote
Old 10-26-2012, 07:22 PM   #12
rsgarage
Member#: 336232
Most of the jdm cars have abs while the na ones do not.
Does it matter? Are the abs rings easy to move over?
rsgarage is offline   Reply With Quote
Old 10-28-2012, 02:46 AM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
give us the trans code. im not the best at 5/6 but i can't think of anything 4.11 from that era, unless its a plane jane wrx.
eg33GC is offline   Reply With Quote
Old 10-28-2012, 02:47 AM   #14
eg33GC
Member#: 206851
56 Belair
Pro Street
sti/wrx- abs
ra/r- non abs
p1- abs
if it has dccd, it does not have abs.
Old 01-30-2014, 10:48 AM   #15
Shakes
Member#: 44396
2001 RSTi
AW
so just to clarify from those of you smarter than me; I've got a 2001 rs with a v2 sti trans and I need a new front passenger axle. Am I understanding this correctly that I can just go to autozone and purchase an axle for an 01 rs and it will work with the v2 sti trans?
Shakes is offline   Reply With Quote
Old 01-30-2014, 05:41 PM   #16
Wannabe WRX
Member#: 130623
1998 Legacy L
Green
Short answer, yes.
Wannabe WRX is offline   Reply With Quote
Old 11-26-2014, 02:15 PM   #17
mr.robot
Member#: 407207
98 gt-b wagon
blurple
Anyone know about a 3rd Gen legacy I need to replace my rear axle. It's a 98 jdm legacy wagon.
mr.robot is offline   Reply With Quote
Old 11-28-2014, 09:35 PM   #18
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Same as GC/gf/BC/bd/bf/BG.
i_c_the_light is offline   Reply With Quote
Old 11-28-2014, 09:39 PM   #19
mr.robot
Member#: 407207
98 gt-b wagon
blurple
Awesomeness thanks mang
Old 06-14-2015, 06:01 PM   #20
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Gotta new question for you guys. I currently have a V2 Sti RA trans with dccd in a 96 impreza. I recently broke it and will be swapping in an 04 wrx 5spd while my ra trans gets rebuilt. Does anyone know if my current axles will fit the wrx trans or if the wrx axles will fit my hubs? Not sure which axles I need to use.
fxt05 is offline   Reply With Quote
Old 06-19-2015, 12:02 AM   #21
elislider
Member#: 133923
03 Legacy GT wagon
you can reuse the axles in your car.
however the rear diff ratio is different and you'll have to swap that out to use that transmission
Old 06-19-2015, 01:40 AM   #22
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Already planned on swapping the diff too, forgot to mention that. Just needed to know about the axles. Thanks for the help!
Old 09-12-2015, 06:44 PM   #23
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Update, my axles will not fit the 04 wrx trans. The axles to the trans is male on 04+. Will the 04 wrx axles with abs fit my non abs hub?
Old 09-14-2015, 08:30 PM   #24
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need 05-07 impreza wagon 5 speed front axles.
Old 09-14-2015, 08:41 PM   #25
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
And those with abs will fit my non abs hubs? From the sound of this, the sedans are too long?
CV Axle boot replacement? Axle rebuild place? ProdriveRex North West Impreza Club Forum -- NWIC 1 10-23-2011 04:55 AM
WTB: outter cv boot for v8 jdm sti axle akcel Private 'Wanted' Classifieds 0 07-26-2007 01:49 AM
is it hard to rebuild cv axles yourself turbocolin Transmission (AT/MT) & Driveline 3 08-21-2004 04:13 PM
Will the front CV Axles from a 2.5RS fit my 95 L? marcus12 Transmission (AT/MT) & Driveline 4 07-30-2004 10:01 PM
CV Axle question for the gurus marcus12 New England Impreza Club Forum -- NESIC 3 07-30-2004 07:38 AM
