Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Drivetrain
Old 11-08-2011, 01:52 AM   #1
glhs377
Member Sales Rating: (4)
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
Default PA 1997 4wd 5spd drivetrain, starter, trans, clutch, axles diff, pedals, etc etc etc
swapped out to a hydraulic pull clutch transaxle and diff. so this is basically most of the drivetrain parts you'd need to swap an auto fwd car to awd 5spd
~160k miles on everything. from my 1997L with a built NA engine. was going to use it forever. only swapped it out cause after buying a new clutch for this i got a smoking deal on a ver4 RA trans.. it wasn't slipping too bad, fully driveable, but the clutch was going out and i didn't want it to go out on me and have to change it in the winter. anyway:
everything for $400 +ship
the new clutch and flywheel were $240 alone. i just want it gone. i have other projects and need the space.
i will put on a pallet and ship from my industrial shop, so that saves you some on shipping. shipping on my trans from texas to PA was ~$140. I'm in zip 15219, Pittsburgh, PA if that helps. i urge you to pick it up for free! i'll buy you a beer!
includes:
brand new unused stage1 clutch(rated 280 ft lbs) cover and disc
brand new unused exedy flywheel with pilot bearing
brand new unused throwout bearing
3.9:1 open rear diff(housing and all, studs on rear removed)
3.9:1 1997 L 5speed w/ JDM sensors(same sensors as USDM with different plugs)
trans has a new subaru dust boot that stops the clutch from squeaking. ~100 miles old
2 rear axles for GC
clutch cable
cable clutch pedal box for GC (has all sensors on it)
starter
spedo cable(for LHD!?)
things you will probably need:
5mt driveshaft
front axles($40 ea at all foreign)
crossmembers
shifter linkage
glhs377 is offline   Reply With Quote
Old 11-10-2011, 03:49 PM   #2
glhs377
Member#: 125388
97 240hp NA GF6
somebody needs to swap from a 1.8l fwd?
04 STi complete trans swap, axles, diff, driveshaft tealturbotwo Drivetrain 48 02-09-2010 03:14 PM
FS MA: L trans, clutch, axles, flywheel, caliper paint greddy18 1993 - 2001 Impreza Specific Parts 1 09-01-2009 08:08 PM
FS NY: JDM Ver. 7 6 speed swap parts, axles, diff, starter, clutch, hubs, shaft, etc garface Drivetrain 48 02-10-2009 10:29 AM
FS: Complete 2000 RS Part Out (Complete drivetrain, brakes, axles, diff, dash, etc.) sanovichleo 1993 - 2001 Impreza Specific Parts 69 01-09-2008 12:22 PM
FS: So CA 02 WRX Clutch, axles, diffs subiebreadman Drivetrain 5 02-21-2007 09:33 PM
