Closed Thread
Old 11-22-2011, 07:49 PM   #1
Rudy1111
Member#: 228042
Default 2004 STI A/C Compressor Failed
Had a whining going on in my engine. Checked it out visually, nothing obvious. Set an appointment few days later, whining got worse before that. Took another look, belt to AC comp was all jacked.
Took it apart, lower wheel was fubar, belt mangled. Cut it out, then went to check out the ac compressor wheel.
It is frozen up and very difficult to rotate. I'm not positive but thinking that it should be free spinning. Called a guy and he said I need to replace the entire compressor setup.
Anyone have any experience to the contrary? Maybe just parts of the setup need to be replaced?
Any insight or experience appreciated.
Rudy1111 is offline
Old 01-24-2012, 01:25 PM   #2
shekshishekki
Member#: 208584
2004 Subaru WRX
Rally Blue
it needs to be replaced...just buy a used one and either install yourself or get the mechanic to do it..I'm on my second right now...
shekshishekki is offline
Old 01-24-2012, 09:37 PM   #3
NA STI
Member#: 285083
2006 STi
i have one fs if you need it
NA STI is offline
Closed Thread
FS : CO-1 Owner 2004 WRX Sedan w/ New Motor wrx-boy Private Vehicle 'For Sale' Classifieds 3 11-16-2011 11:43 AM
AC compressor fail CuervoVT Service & Maintenance 2 06-16-2011 04:38 PM
('08-'10) AC Compressor Clutch Failed goalie_pilot Impreza Forum 13 08-08-2010 08:05 PM
A/C compressor fails to kick in with HOT weather dadu007 Normally Aspirated Powertrain 1 06-28-2010 10:00 AM
No A/C -- failed compressor? Kantalias Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-20-2007 07:50 PM
