Old 11-09-2011, 04:09 PM   #1
BlackBeautysti
Member#: 299433
2008 Subaru STI
Black Paint Black Rims
Default Harman motive cai w ap aem map
I wondering if the harman motive cold air intake will fit w ots map aem accessport? Since hm using aem filter ....
BlackBeautysti is offline   Reply With Quote
Old 11-09-2011, 07:07 PM   #2
Cobb Tuning
Member#: 4803
Hi there. Unfortunately, the entire intake would have to be identical to the AEM in order to use one the AEM intake maps available for the later model WRX and STis. There are a lot of factors that impact how air behaves around the MAF sensor for a given intake in question including the cross-sectional area of the intake, bends in the piping, filter, etc. If the map is not calibrated for the intake you are using, load will not be calculated properly, which means you will have incorrect fueling and timing (which is obviously not good).
Bill
Old 11-10-2011, 02:37 AM   #3
BlackBeautysti
Member#: 299433
2008 Subaru STI
Bill
Bill..............
Silly Me,....................
I did it .... and i pulled up to 6000 and then check engine came out and all blinking.
i used the stage 1 +AEM. I tried to return to OTS stage one wit
h oct.93 but still check engine came up.
and then i decided to uninstall AP . and all seems normal.
.................................................. ......Sshhhiiihhhhh
WHAT SHOULD I DO NEXT ? JUST PULLED OUT THE HARMAN MOTIVE ?AEM ?
Old 11-10-2011, 07:28 AM   #4
Cobb Tuning
Member#: 4803
Bill..............
I would read the code and see what it was. May have been an overboost fuel cut. You can get a "system too lean" or "system to rich" DTC when using the incorrect intake, but it usually takes some driving for this to happen and it means things are really screwed up. However, you can still have dangerous fueling issues with the improper intake without any check engine light.
Your options are to:
1. Replace this intake with the stock intake, Cobb SF, or AEM and reflash the corresponding map. For AEM, this assumes you have an 08+ STi or WRX.
2. Get a custom tune from a Cobb protuner for your current intake.
3. Do the tune yourself with AccessTUNER Race which is free for AP v2 users. You'll need to buy and install a wideband o2 sensor to do this.
Bill
Old 11-14-2011, 12:51 AM   #5
BlackBeautysti
Member#: 299433
2008 Subaru STI
Hi bill i will try to contact local tuner, thank u much. By the way ... I am will shopping cobb tuning product. I probably get back to u.
FS : Harman Motive CAI 02-07 bue car Engine/Power/Exhaust 12 06-05-2011 02:10 AM
FS : 08+ STi dom 4 xtr, turbo inlet, darton sleeves, Harman motive cai im2ninja4u Engine/Power/Exhaust 78 02-24-2011 12:22 PM
FS : Harman Motive CAI for 08+ STI, TMIC to TB coupler $ickSTI TXIC Private Classifieds 3 07-30-2010 09:49 AM
FS : Harman Motive CAI for 08+ STI, TMIC to TB coupler $ickSTI Engine/Power/Exhaust 11 07-29-2010 09:50 PM
Ghetto ram-air Harman Motive CAI Butcherboy78 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-06-2008 09:31 PM
