Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 11-09-2011, 07:15 PM   #1
Scooby Snax
Member#: 100916
2007 STi
Default Downpipe Install, How Difficult?
I have most of the tools needed to install my Cobb downpipe on my '07, I already installed the catback. Is it no big thing or should I just save myself the time, swearing and frustration and have a shop install the downpipe?
Scooby Snax is offline   Reply With Quote
Old 11-09-2011, 07:24 PM   #2
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
It's easy look up the diy instructions.
car_cursed is offline   Reply With Quote
Old 11-09-2011, 07:45 PM   #3
Mush04
Member#: 191705
2007 Limited STi
Swp
Here's a quick run down, I just swaped a couple a few weeks ago.
take heat shield off, I believe there'e top and bottom (I never had the stock heat shield so I don't remember exactly) I sugguest replacing with an aftermarket one since the stock one has to be slightly bent or cut to fit the cobb bellmouth.
unbolt the DP from the turbo (not as difficult as you may have heard)
take out the couple support bolts, one is bolted to the transmission, the other just a bracket under the car (can't miss it) then unbolt from catback.
I unplug the O2 sensor cause it's angled up towards the driveshaft, plus they are usually on there pretty good.
then pull it out! haha I know it's not the most in depth instructions, but like car cursed said it's easy just a matter of finding all the bolts and crawling under the car. GL! I usually check nasioc fairly often so if you get stuck or anything PM me.
Or I can just install if for you for $50
Mush04 is offline   Reply With Quote
Old 11-09-2011, 08:07 PM   #4
TiM801
Member#: 289115
It's easy as pie, just takes some strength to get bolts out. and gotta get under car to unbolt turbo stock DP
TiM801 is offline   Reply With Quote
Old 11-09-2011, 09:03 PM   #5
Henriksen
Member#: 290178
2008 DGM STi-Ituned
2008 R6
Just did mine on my 08' took like 45 mins, wasnt bad at all. Waaaay easier than it was on my cramped MS3. Just make sure you put the replacement gasket from turbo to DP on before you bolt everything back on probably would have been 30 mins had I not forgot haha
Henriksen is offline   Reply With Quote
Old 11-09-2011, 10:50 PM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
about a 2.315*e^15
snowman4us is offline   Reply With Quote
Old 11-10-2011, 12:07 AM   #7
godfather2112
Papi Chulo
Member#: 53794
Originally Posted by snowman4us View Post
about a 2.315*e^15
Wrong! God your such a idiot sometimes. If we go according to Ezekial Mostaphod rule, its exactly 2.315*e^15-.241(1+niner foxtrot)
Stupid kiki.
godfather2112 is offline   Reply With Quote
Old 11-10-2011, 12:47 AM   #8
08WhiteRex
Member#: 187453
2012 Mulletmobile
about a 2.315*e^15
No units?!?!?!??! No wonder you got pwned by that PDE exam.....
08WhiteRex is offline   Reply With Quote
Old 11-10-2011, 01:24 AM   #9
hillsboro
Member#: 84823
14 Evo
00 Outback
Also, put the bottom bolt on the turbo first.
hillsboro is offline   Reply With Quote
Old 11-10-2011, 01:27 AM   #10
subiewrx001
Member#: 193591
04 WRX VF34
water/meth, spt intake
To get the o2 sensor out use a large crescent wrench. The sensor sockets seem to strip the sensor, at least mine did.
subiewrx001 is offline   Reply With Quote
Old 11-10-2011, 12:41 PM   #11
phattydrummer
Member#: 183070
2003 WRX
True Blue
Remove the 02 sensor with the downpipe still installed. Shoot the base of the senosr with some PB Blaster. And if you can get your hands on a quality 02 sensor wrench (Snap-On) and keep it level on the sensor, you will have a much better chance at not rounding the edges off the sensor base.
phattydrummer is offline   Reply With Quote
Old 11-10-2011, 02:13 PM   #12
Mush04
Member#: 191705
2007 Limited STi
Swp
I ended up picking up the socket style which is not the greatest, but I just had one of the guys hold the dp in one place so the socket wouldn't round the sensor, plus I couldn't find my pb blaster. Stuff works wonders sometimes.
Old 11-10-2011, 02:42 PM   #13
Henriksen
Member#: 290178
2008 DGM STi-Ituned
2008 R6
Pb blaster ftw, really is a life saver at times, just dont get it in your eye, kinda sucks haha
Old 11-10-2011, 02:52 PM   #14
Mush04
Member#: 191705
2007 Limited STi
Swp
I've learned the hard way that looking dorky and being slightly uncomfortable wearing safety glasses while under the car keeps all kinds of **** out of your eyes
Old 11-10-2011, 02:55 PM   #15
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
It's easy. Make appointment at Solid, drop car off or wait for an hour. Give money. WIN
bhhamblin is offline   Reply With Quote
Old 11-10-2011, 02:59 PM   #16
fircrest
Member#: 193852
2004 Forester XT
hahahhahha
The first time I did it the hardest thing was breaking the nuts loose (TWSS). PB Blaster is your friend.
fircrest is offline   Reply With Quote
Old 11-11-2011, 12:34 AM   #17
Scooby Snax
Member#: 100916
2007 STi
So tempting . . . .
Old 11-11-2011, 12:37 AM   #18
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Thats where I take my car.
Old 11-11-2011, 10:00 AM   #19
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
That's because you have more money that skills.
Old 11-11-2011, 10:39 AM   #20
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Or because I am there every day..
Old 11-11-2011, 06:13 PM   #21
Mush04
Member#: 191705
2007 Limited STi
Swp
what about both?
Old 11-14-2011, 06:31 PM   #22
Scooby Snax
Member#: 100916
2007 STi
Is changing out the gaskets from the DP and the donut gasket mandatory or optional?
Old 11-14-2011, 06:35 PM   #23
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
I've re used one, but only once, and get some copper gasket sales to help seal it up if you do reuse it
Old 11-14-2011, 06:36 PM   #24
Henriksen
Member#: 290178
2008 DGM STi-Ituned
2008 R6
I would highly recommend it, especially the donut one as it gets pretty fragile with age, unless the car is only a couple of years old you wont be able to reuse it.
Old 11-14-2011, 06:45 PM   #25
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Just hit up all bolt will some penatration oil like a day before. Before you do the deed, take it out to dinner first.
sackytar is offline   Reply With Quote
installing hks downpipe, how difficult? zachary.berrier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-10-2005 10:24 PM
WRX header install..how difficult?? 516_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-01-2003 09:56 PM
Boost problem after Perrin downpipe install, how can I fix it? JDWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-10-2003 12:58 PM
How difficult to install header? John2.5RS Normally Aspirated Powertrain 9 05-10-2001 10:29 AM
S-AFC Install. Who? How difficult? mav1c Normally Aspirated Powertrain 9 01-15-2001 10:38 AM
