Old 03-13-2012, 05:06 PM   #151
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
im pretty sure if you get a 6blade hx40, that might make your goal as its a 69lb min turbo.
em1bugeye is offline   Reply With Quote
Old 03-13-2012, 06:25 PM   #152
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
Originally Posted by teamelim View Post
Oh sorry about that. I have a 2002 wrx with ej25 swap. Have a built 5 speed. Now I am running a precision sc3431e that is putting 330 who. I wanna go from this or up to 400 who for now until the next tax refund comes in and then I will to a full sti drivetrain swap. Then I want to push around 600whp. Not sure if i should go with a precision 6152 ball bearing or holset hx52. All this will be e85 with 1000 or 1300cc DS injectors. Thanks all for you assistance If anyone wants to email me at [email protected] please do so. I actually put the order for the precision Turbo but I have till Monday morning to cancel and get the holder.
If you've already researched the Precision, I'd stick with it.
You'll prob need bigger injectors once you start shooting for 600whp
gotsugg is offline   Reply With Quote
Old 03-13-2012, 07:22 PM   #153
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
if hes trying to shoot for 600, then hes going to need something way larger than a 6152. that turbine is too small. he might have to go with a BB 6765 if hes going to really hit 600whp. and on e85. theres a lot of factors you have to consider when your aiming for that high of HP. he can use 1300s, but his fuel pressure has to be sky high for it to work. i.e his basepressure would have to be 60psi minimum.
Old 03-13-2012, 07:45 PM   #154
spintheground
Member#: 239638
2007 WRX TR UGM
Subscribed.
spintheground is offline   Reply With Quote
Old 03-30-2012, 01:05 AM   #155
gotsugg
Member#: 204014
02 02 WRB Bugeye
Holset update!!!!!!!!!!!!!!
I have my rotated kit installed as well as my reversed LGT intake. The car is running but I'm still working out a few bugs. I should be able to post up some data very soon.
Old 03-30-2012, 11:19 AM   #156
kakarot09
Member#: 182375
08 Sti
Wrbm
awesome can't wait to see
kakarot09 is offline   Reply With Quote
Old 03-31-2012, 12:18 AM   #157
dukeduster
Member#: 95789
2002 WRX PTE
6262, hydra, 1100 FIC
Very cool!
dukeduster is offline   Reply With Quote
Old 04-09-2012, 01:30 AM   #158
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
in the process of gathering everything i need for a he351ve swap, what is recommended for EM? could i do it with my stock ecu? or should i go blow through and get at least a piggyback unit? sorry not very familiar with the tuning side of building cars, more with the building and fabricating. is there anyone will to let me shoot them some pm's to pick their brain with questions about problems they ran into, etc?
thanks for any and all help, this thread has been a great source of info
dirtbikeridr12 is offline   Reply With Quote
Old 04-09-2012, 05:23 PM   #159
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
man mocking up takes a while :/
Old 04-09-2012, 06:46 PM   #160
sorrowfulkiller
Member#: 170439
I <3 Lamp
A 6262 is more than enough for 600 awhp
sorrowfulkiller is offline   Reply With Quote
Old 04-09-2012, 08:32 PM   #161
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
depending on boost level and fueling my dude, but on pump gas, not really ( for subarus ), evo's, another area, but I dont think ive seen a 6262 make 600 on pump gas. usually it takes a lot on e85 to make that happen like (27-30 psi id say) just from experience. The new 6466 looks beast though. but thats off subject, hows everyones Holset mockup, fabs going. i forgot how physically large this turbo was so mockup is taking atad longer to do.
Old 04-09-2012, 08:42 PM   #162
sorrowfulkiller
Member#: 170439
I <3 Lamp
I agree with you there, e85 would definetely be needed.
Old 04-30-2012, 03:35 AM   #163
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
well im at the finish line i guess. about 90% done.
Old 04-30-2012, 08:54 AM   #164
gotsugg
Member#: 204014
02 02 WRB Bugeye
Looking good!!!
Old 05-02-2012, 03:21 PM   #165
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
Originally Posted by gotsugg View Post
Looking good!!!
thanks, hopefully this weekend it will be REAL NICE. hows your car running? is it tuned yet?
Old 05-02-2012, 03:24 PM   #166
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Looking forward to results. Me likey HOLSET but there results are sometimes a bit mixed on gasoline engines. Will be following your results. Pics DO look good!
Cheers,
Jasper.
jkopinga is offline   Reply With Quote
Old 05-02-2012, 08:36 PM   #167
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
HOW COME NO ONE IN THIS THREAD HAS BEEN TUNED YET!!>!!>>! also the mixed results come from which holset you get, since there are a total of 6 versions for the "HX" series. so some flow better than others so they will produce more power, but thats all relevant to the fuel, engine displacement, ports, cams, etc etc....so they should still produce about 400whp+ on 21+psi.
Old 05-02-2012, 09:40 PM   #168
albersondh
Member#: 196882
08 WRX
Page 1 post 11. Your numbers look right on. I had suspesions about my crap boost gauge so I just checked a bunch of logs and they are never showing me breaking 22psi. So airboy puts me just a tad over 420 at 22 psi. This is a stock motor, 255lph, and 910cc's maxed out.
Just went through my fuel system with -8 sending, aeromotive rails, -6 return, and a 400lph. Got some 1650's standing-by but not tempting fate with the stock motor as Im pretty sure I have already started lifting the heads. Did a EL header and built a revised/improved (321) up-pipe while I was at it; yea up-pipe mock-up takes forever..... Getting motor parts together now and Ill be pushing the built motor to 30+ on the 351. I hope to find out what this thing can realy do pretty soon.
albersondh is online now   Reply With Quote
Old 05-02-2012, 11:10 PM   #169
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
are you running e85? just guessing since you are maxing 910s and moving to 1650s haha
Old 05-03-2012, 12:05 AM   #170
johnt2k7
Member#: 194151
2008 WRX 5 Door
RED
the reason is most people doing Holsets are DIY'ers like myself and are ongoing/never-ending projects. mine is self tuned and never been on a dyno. airboy shows consistently in the 380's on nearly maxed out modded injectors & 18 lbs of boost.
i was using a UTEC for speed density tuning for a while but really didnt like it. very crude and a pain to tune. seemed like the ecu was fighting what the UTEC was trying to do?
now im back on a stock ecu with a 32bit Speed density rom thanks to the guys over on Rom Raider forums. its dialed in perfectly, but still only on 18lbs and still needing bigger injectors. prolly going with a set of 1200's very soon, iv just been lazy recently. but im hoping to get on the Dyno @ OCAWD meet in June.
like albersondh im also looking into building the motor. most likely a long rod build this fall/winter so i can rev it out to 8K+. so im not trying to make any huge numbers right now because its inevitable whats going to happen. im just trying to get it through another summer with a set of heads and a block that are still re-buildable
PS: im still on a OEM clutch with near 60K
johnt2k7 is offline   Reply With Quote
Old 05-03-2012, 03:59 AM   #171
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
this is true. i am also not tuned as well and i had to DIY my whole turbo kit to get this DAMN TURBO TO FFIT!!!! the adapter flange and the downpipe. i just got a set of 1000s, so i might trade those and another set of stock modded 860s for some bigger injectors. my motor is a 2.1l though and its ready to spin 9,000, just need the fueling to back it up. but just as you, i am not looking for large power, just a nice long powerband haha. Im also on the carberry SD rom, thanks to the many people on romraider your lucky you have a 32bit ecu considering you have options. us 16bit people have it worse haha. but im also at a standstill like you guys as my stock 5speed has 200k on it but still going strong. hopefully the recent plate i just purchased and the fact i have a lower displacement motor (thus less trq) will keep the tranny alive at least until it gets off the dyno :/ but yes i agree, its a never ending story. but hopefully by the end of may, my car will be on a dyno
Old 05-03-2012, 09:43 AM   #172
albersondh
Member#: 196882
08 WRX
My tranny dramas; I busted my OE 5mt, rebuilt it, then sourced a 07 6mt and R180. So all that is installed now, one less thing to worry about......
SD for 32-bit?!?!? Last time I was on RR it was in the works but man that happened wayyy faster than I thought it would. I figured AEM would release for 08+ before we got open source SD.
John how is the SD working out for you? Any noticable drivability issues? Seems like a lot of my drivability issues can be attributed to my MAF or lack of enough time fine tuning the scaling. I did not/do not tune for reference but I need to start.....
Old 05-03-2012, 10:22 AM   #173
gotsugg
Member#: 204014
02 02 WRB Bugeye
Nice to see some activity on this thread
I'm self tuning this time and I am taking my time. Really just trying to get my fueling back in check. I turned up the boost on Tuesday and the car feels good. With the .63 housing I am seeing 17/18 by 4000 rpms and 21 by 4200...... 3rd.
I'm headed out to do a few more data logs, I'll post a dyno plot soon.
Old 05-03-2012, 12:52 PM   #174
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
16bit SD is great.
Purpose_Built is offline   Reply With Quote
Old 05-03-2012, 01:09 PM   #175
johnt2k7
Member#: 194151
2008 WRX 5 Door
RED
yea im surprised as well, i had been trolling over their for a while then got fed up with the Utec. so i started talking to TD-D and Merp. luckily Merp had just finished the code for his 06-07sti and TD-D was already porting it to his car 08 edm STI, once he finished his i send him my rom and we went back and forth for a couple days finding all the needed ram holes and such then he sent me a finished rom & definitions. ran if for a few weeks no problem then got in contact with merp and sent him everything TD-D had done he added in all of his new code plus NSFW patches
now we have a 08+ WRX 32bit SD rom with LC/FFS and CEL flash for knock. and ignition Cut coming very soon im told
but dont get me wrong their was some scary times where i thought i had bricked the ecu, because i would flash and then car wouldn't start and you could here the ecu clicking
also merp made a spreadsheet to make it easy to tune. it helps convert your MAF to VE to help setup a general VE table for first start up. then you can log ve and wideband and it will make adjustments to the VE table based on AFR.
Borg Warner Turbos. Who is running them? DemiSlayer Built Motor Discussion 48 03-22-2010 11:50 PM
Air oil coolers; Who is running them and What Size line? cueballsi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-25-2009 11:37 PM
True twin scroll headers who sells them and are anyone running them tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 03-09-2007 12:57 PM
WRX Koni inserts: Who has them, where did you get them, and who has them in stock? Cosworth Brakes, Steering & Suspension 4 09-13-2002 03:18 PM
Headers/Exhaust/Cams who has them and dyno'd them Silky Normally Aspirated Powertrain 14 04-13-2001 09:07 AM
