Old 05-03-2012, 01:17 PM   #176
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
Originally Posted by gotsugg View Post
Nice to see some activity on this thread
I'm self tuning this time and I am taking my time. Really just trying to get my fueling back in check. I turned up the boost on Tuesday and the car feels good. With the .63 housing I am seeing 17/18 by 4000 rpms and 21 by 4200...... 3rd.
I'm headed out to do a few more data logs, I'll post a dyno plot soon.
Correction. I had been doing all my logging in 3rd gear while I dialed in the OL fueling. This morning I did 2 data logs in 4th and I am pleasantly surprised. I saw full boost (22 psi) at 3600 and 3800 rpms. I saw 18 psi at 3400 and 3600 rpms. This is very comparable to my old Dom 3 but should be able to push a ****load more air once I get a block to support it. Me happy
gotsugg is offline   Reply With Quote
Old 05-03-2012, 03:08 PM   #177
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
psshshhhh your dom3 efficiency isnt in the 30psi range like this turbo bahaha. yea once you can get a block thats capable of pushing more power, crank the boost up. you have a 7blade version right? but 36-3800rpms? thats amazing spool for the turbo size
em1bugeye is offline   Reply With Quote
Old 05-03-2012, 04:32 PM   #178
gotsugg
Member#: 204014
02 02 WRB Bugeye
^^^^ True, very true. I can't wait to see how it does with more boost.
Yep, 7 blade. I'll do some more testing this weekend but as of right now I am damn pleased with they way it performs.
Old 05-03-2012, 07:42 PM   #179
albersondh
Member#: 196882
08 WRX
Originally Posted by johnt2k7 View Post
yea im surprised as well, i had been trolling over their for a while then got fed up with the Utec. so i started talking to TD-D and Merp. luckily Merp had just finished the code for his 06-07sti and TD-D was already porting it to his car 08 edm STI, once he finished his i send him my rom and we went back and forth for a couple days finding all the needed ram holes and such then he sent me a finished rom & definitions. ran if for a few weeks no problem then got in contact with merp and sent him everything TD-D had done he added in all of his new code plus NSFW patches
now we have a 08+ WRX 32bit SD rom with LC/FFS and CEL flash for knock. and ignition Cut coming very soon im told
but dont get me wrong their was some scary times where i thought i had bricked the ecu, because i would flash and then car wouldn't start and you could here the ecu clicking
also merp made a spreadsheet to make it easy to tune. it helps convert your MAF to VE to help setup a general VE table for first start up. then you can log ve and wideband and it will make adjustments to the VE table based on AFR.
Sick, Im sold, must have! Thanks for the reply. Looks like I need to get back on RR and start doing some home work. CEL flash for knock is , and VE adjust via wb02 log is pretty impressive.
albersondh is offline   Reply With Quote
Old 05-05-2012, 08:24 PM   #180
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
ANDDDDDDDDDDDDDDDDDDDDDDDDDD...................... .DONE forreal this time. im not touching this ***** again!!!!!
Old 05-05-2012, 11:57 PM   #181
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Looks like your fuel lines in to the fuel rail block are backwards? Supply comes from the filter and return comes from fpr/
scby rex is offline   Reply With Quote
Old 05-06-2012, 12:23 AM   #182
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
opps...................................
Old 05-06-2012, 10:20 AM   #183
Storm
Member#: 5218
96L Most Over-
Developed Beater
If anyone else is looking to go with a 7 blade HX35W, I've got a good one sitting on the shelf. I was going to upgrade my Suburban, but have decided the racecar needs parts more than the tow vehicle.....
Jay
Old 05-06-2012, 01:04 PM   #184
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
im running a 7 blade hx35 on my car now. as shown in pic above
Old 05-07-2012, 11:00 AM   #185
207STi
Member#: 197062
1998 Swapped Impreza
black
I am looking to run one of these on a stock V7 ej207. I have read through this thread a couple times now and come to the conclusion I most definitely be running a holset. I was thinking of using an HX35 with an 8 blade inducer (52 lb per min) and one of the tim's turbos exhaust housings. I am looking to hit full boost somewhere around ~4000 rpm. What exhaust housing would fit my goals the best? Looking to make 350-375 whp.
207STi is offline   Reply With Quote
Old 05-08-2012, 12:02 PM   #186
gotsugg
Member#: 204014
02 02 WRB Bugeye
It really depends on your Downpipe. Will you have a 4 bolt or Vband connection?
Old 05-08-2012, 04:47 PM   #187
207STi
Member#: 197062
black
Likely the 3" V-band. I'll also be winding it out to 8k, I'm sure that has some bearing on the exhuast housing A/R. I was thinking maybe I could get the .70 T3 housing from tim's turbos with the V-band connection.
Old 05-08-2012, 06:34 PM   #188
gotsugg
Member#: 204014
02 02 WRB Bugeye
^^ I'm really liking the .63. But I have not tested it at any higher then 22psi boost so it's hard to tell how it will do just yet. That said, I would like to try the .70 just to see if there is a difference.
Tim's is a .63 T3 to 4 bolt that he can convert to Vband, which is what I am running.
Bullseye power makes the .70 T3 to 3" Vband http://www.extremepsi.com/store/prod...roductid=23483
Both seem to be well made.
Old 05-08-2012, 06:48 PM   #189
gotsugg
Member#: 204014
02 02 WRB Bugeye
How is it running?
Old 05-08-2012, 08:19 PM   #190
207STi
Member#: 197062
black
I would be all for the .63 because response is pretty important too me, but judging by the exhaust housing chart posted previously in this thread:
and just to confuse you a little more this is the formula to convert a standard open T3 housing nozzle area (CM^2) to A/R
( ( CM^2 x 8 ) - 7 ) / 100 = AR
so i did some math
12cm = .89 A/R
10.38 = .76 A/R
9.63 = .70 A/R
8.75 = .63 A/R
7.75 = .55 A/R
i know the BEP Mitsu fitments wont apply to this because the area inside the housing is different then the T3 so this calculation will not apply. this is for T3 only
but it gives you a comparison where the aftermarket T3 Housings A/R (.55 .63 .70) fall in line with the OE/holsets CM^2 (9 12 16 18).
Seems like the .63 comes out to 8.75 cm while the .70 is equal to 9.63. People seem to be running a 10cm hot-side on the dom 3, which is also a 52 lb per min turbo. I guess I am just concerned that the .63 A/R won't hold boost all the way out to 8k. Thoughts?
Old 05-08-2012, 11:43 PM   #191
johnt2k7
Member#: 194151
2008 WRX
RED
^ i would go with the BEP .70A/R. mine on my 2.5 is spooling 18psi on a 8 blade HX35 before 3500 rpm in every gear. Id feel comfortable running it on a 2.0. i was expecting later spool myself but was very surprised with these holsets spool.
check out DSM Tuners Holset Thread alot of good info. they say that a 8 blade HX35 with Bep .70 T3 spools/flows similarly to a 7 blade Hx35 on a Mitsu .55. so around 3500 on 272 cams and faster with stockers. figure a little loss for thermal efficiency because of the head being farther away from the turbine due to the subaru/boxer design. maybe a couple hundered RPM but if you keep it wrapped/coated, im positive you could still spool 20psi before 4k. And with a 8k rev limit your looking at a 4k rpm 20Psi+ power band .
here is a stock longblock 2.0l DSM with 272 cams spooling a stock 12cm^2 housing Hx35 @ 3k rpm on a TS manifold
johnt2k7 is offline   Reply With Quote
Old 05-09-2012, 12:35 AM   #192
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
How is it running?
i havent gotten a chance to even start the motor because now ive descovered i have a short between the sbf-#5 (30amp fuse), the fuel pump relay and the controller. the motor wont prime so something isnt getting power to the pump. i just hope the relay is bad so i can just go to the autoparts store and get another one because ive already popped 2 fuses already. i dont need to do it with a 3rd fuse. and i dont feel like waiting for another fuel pump controller. or i could just cut the BS completely and bypass both of them and just power the pump directly.
Old 05-09-2012, 03:10 AM   #193
johnt2k7
Member#: 194151
2008 WRX
RED
^ power the fuel pump directly, most pumps its a benefit, with extra flow @ bat voltage vs Fuel pump controller (12V).
Old 05-09-2012, 03:54 PM   #194
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
true. i can get 13volts instead of 12. but im going to replace the fpc with another one that works and see if that pops a fuse. if it does, im just bypassing EVERYTHING!!
Old 05-12-2012, 12:51 PM   #195
gotsugg
Member#: 204014
02 02 WRB Bugeye
So just for the sake of learning and testing I decided to get the OEM 12cm Holset housing ready to be installed.
I bought a flange ( http://www.ebay.com/itm/180668853821...84.m1439.l2649 ) and I'll have a Vband flange welded to it once it arrives.
Last night I spent some quality time porting the housing and it is ready to go.
I'm not sure how long it will take to actually get it installed, but at least it will be ready.
Old 05-12-2012, 01:30 PM   #196
gotsugg
Member#: 204014
02 02 WRB Bugeye
Here is my comparison between my stock location Dom3 and my rotated HX35. Before you comment, I am still tweaking the fueling, which includes the rich dip at spool up.
Dom3, MBC, 38mm EWG, Perrin ELH, DW 1100cc, 73mm SRI, on e85
HX35, MBC, 44mm EWG, rotated, Perrin ELH, DW 1100cc, 73mm SRI on e85
Same timing curve (12* to 20*) and same boost level 22ish
I think the Dom is a .55 ar and the HX35 is a .63
As mentioned earlier, the HX35 has a whole lot more headroom and probably doesn't even come-on until 25psi. I hope to test it someday soon.
Blue Dom3 and Red HX35
The smoothing on Virtual Dyno is 7, with no added weight
Old 05-20-2012, 03:00 AM   #197
albersondh
Member#: 196882
08 WRX
Some updates. Rebuilt my kit, got it all hooked up tonight, and the brackets that come with my Aeromotive rails are drilled wrong or not for 08+ TGV's anyways. The injectors are loose and leaked from the o-rings during boost test. Have to redrill the holes on the brackets that mount the rails to the TGV's. Anyways, not running yet but some money shots just because....
Old 05-21-2012, 12:02 AM   #198
albersondh
Member#: 196882
08 WRX
It lives again. This time with -8 sending, 400lph, Aeromotive rails / Weldon FPR, improved up/down pipes, and EL header. Shake down went well I need someone to check my logs though, I dont think Im hitting my target boost. Had to make a new intake and miscelanious IC tubes. Rotated the MAF around 180* from where it was and maybe moved it up/down 1". So my MAF scaling is suspect..... Also I dont think Im hitting target boost so maybe WGDC needs some fine tunning? Overall it seems to run good, knock is good, and AFR is on par with previous.
Old 05-21-2012, 08:29 AM   #199
gotsugg
Member#: 204014
02 02 WRB Bugeye
Looks great!
Did you upgrade your injectors? What ELH did you go with?
Old 05-21-2012, 03:02 PM   #200
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
Looks great!
x2 on that question sir.
Borg Warner Turbos. Who is running them? DemiSlayer Built Motor Discussion 48 03-22-2010 11:50 PM
Air oil coolers; Who is running them and What Size line? cueballsi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-25-2009 11:37 PM
True twin scroll headers who sells them and are anyone running them tino Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 03-09-2007 12:57 PM
WRX Koni inserts: Who has them, where did you get them, and who has them in stock? Cosworth Brakes, Steering & Suspension 4 09-13-2002 03:18 PM
Headers/Exhaust/Cams who has them and dyno'd them Silky Normally Aspirated Powertrain 14 04-13-2001 09:07 AM
