Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-10-2011, 12:13 PM   #1
Performance Race Solutions
Vendor Sales Rating: (2)
Member#: 248291
2005 Your Dream Car
Default Motor Builds - Turbo's - Exhaust - Intercooler's - Engine Internals + Much More!
Performance Race Solutions knows how to make your car fast, and we want to help you achieve that goal! We provide everything from engine internals, to complete short and long blocks. We can also install everything and tune it before it leaves!
PRS Stage 1 2.5L Short Block Includes: All blocks are machined in-house and hand assembled
Wiseco, Manley, or CP Pistons
EJ25 connecting rods
ACL Race Series Rod & Main Bearings
All freshly bored and honed to each specific piston with a torque plate
Freshly Resurfaced
Available options include: balanced assembly, & Custom piston options
$2450 no core pm for pricing
PRS Stage 2 2.5L Short Block Includes: All blocks are machined in-house and hand assembled
Wiseco or Manley Pistons
Manley H-Beam Rods
Freshly Resurfaced
Build sheet Specs
Available options include: balanced assembly, & Custom rod or piston options
$2800 no core pm for pricing
PRS 2.0 & 2.5 Heads available pm for specs and pricing
AMR Turbo's
(Click Image For Pricing)
The factory Subaru turbochargers are known for the lack of top-end. Most enthusiast want to upgrade there turbocharger but are not willing to sacrifice turbo response for big power. AMR's C70 Bolt-On Turbo for the Subaru is the perfect upgrade for the spool conscious modder looking for an efficient power increase. The C70 comes with a 7cm exhaust housing and a custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no more grinding or busting out a BFH to make something fit). The C70 has a flow rate of 52 lb/min. This seemingly small increase in airflow over OEM VF series allows the C70 to pull hard on top end of the rev-range without any loss of power on low and mid range. The C70 will produce 275-350whp when fully tuned with all supporting modifications. AMR backs their C70 with a 90-day limited warranty.
Specs:
  • 52lb/min Compressor Wheel (turbo flows 52lbs/min)
  • 7cm2 Exhaust Housing
  • 2.4" Compressor Inlet
  • AMR Billet actuator w/ 14.5psi Wastegate Spring
  • TD05H Turbine Wheel
  • Oil & Water Cooled
  • Includes all oil and water lines & all gaskets
AMS Catback Exhaust Systems
The AMS Subaru Impreza WRX/STI Stainless Steel Cat-Back Exhaust uses only the finest components and provides the best fit and finish in the industry. Our exhaust features only mandrel bent piping for the best exhaust flow and does not have any restrictions like other popular exhaust systems that "neck down" and hurt performance. Like all other AMS exhaust products this Cat-Back is TIG welded with 100% 304 stainless components including the flanges and hangers. The system utilizes only factory exhaust hangers and includes a high quality 4" tip muffler.
3" throughout entire system. Does not "neck down" like other popular systems
100% Stainless Steel construction. No mild steel flanges or hangers
All flanged connections. No band clamps or slip fits to come loose
14.6 lb. weight savings (38.2 lbs. compared to stock at 52.8)
Includes gaskets and hardware
Unrivaled fit and finish Specifications
304 Stainless Steel
3” piping .049” wall thickness
Polished Muffler w/ 4” Straight Tip
GTSPEC Headers
The new GTSPEC Equal Length Header for the 02-07 WRX & STI is crafted from 14 Gauge SUS-304 stainless steel, GTSPEC's headers are TIG welded inside and out to ensure a perfect flow and fit. Compared to the factory exhaust manifold, GTSPEC's manifold extracts the most power from your Subaru by incorporating a long-tube, equal length design that truly provides improved heat dissipation and noticeable horsepower. Combining an industry leading mandrel-bent 45mm stainless steel piping, .5-inch thick CNC machined SUS304 wax-cut flanges mean a performance part with the quality and craftsmanship you deserve. GTSPEC products are an upgrade exclusively for those seeking the ultimate in engine performance. This header is a direct bolt on for 2.5L WRX & STI models and will work for 2.0 WRX models that have installed the 2.5L oil pan, available separately below.
For those enthusiasts looking to add bit more power, GTSPEC also offers their equal length header and uppipe combo flanged for an external wastegate setup. This kit comes complete with the proper connections for any standard 44mm v-band style external wastegate and includes a v-band dump tube for that head turning EWG growl at full boost. External wastegate not included.
All necessary gaskets are included.
Invidia Large Diameter Header
So you have bolted on a big turbo and tuned your Subaru to the max but still aren't hitting the peak numbers you are after? Untangle your skirt and dry those tears. The Invidia large diameter header for the 02-07 WRX & STI maintains the all of the great features and design incorporated into all Invidia products, but takes performance one step further by widening each exhaust runner for a product specifically designed for but turbo applications only. Wider diameter runners provide exhaust flow unmatched by any other performance header or port job, supplying your turbo with the smoothest, turbulence free exhaust stream possible. This translates into faster spool, better response and most importantly, more power! If you are looking maximize peak power on your big turbo setup and don't know where else to turn, this is the answer.
AMR TMIC
The AMR Top Mount Intercooler (TMIC) puts the stock intercooler to shame. The AMR TMIC is designed to cool down the air charge to the engine which in turn gives the vehicle better response, more torque and more power. The AMR TMIC has been tested at over 30+ psi. The intercooler is upgraded with a 3" outlet rather than the 2.5" that comes standard on others. The larger outlet allows more room for air to travel out of the core into the engine. With upgraded turbochargers the upper coolant line usually hits the intercoolers, AMR has modified an inverted lip on the end tank to compensate for that. They also beefed up the material used on the flanges, making them practically unbendable. All flanges are made from 6061 aluminum.
PERRIN FMIC
The Perrin Front Mount Intercooler (FMIC) kits are massive upgrades. Designed for 500hp to 800hp applications, Perrin's enormous bar and plate intercooler core will not disappoint. Cast aluminum end tanks and a high-flow core ensure even airflow and an optimized intake charge. Perrin's FMIC kits mount to their powder coated boxed steel replacement bumper beam with 1/2" thick mounting plates, so there is no cutting of the stock structural components required. While exceptionally sturdy, this beam is designed for off-road use only. Perrin uses an OEM type of triangular BOV flange for a stock-style blow off valve and is positioned to reuse the stock recirculation tube.
Specs
  • Cores and piping kits are available separately. You MUST buy one of each to make a complete kit.
  • You will not be able to retain your foglights with this intercooler.
  • Trimming of some of the plastic in the front bumper is required.
  • Will not work with a stock airbox; an aftermarket short ram intake will be required.
  • Moving a hard fuel line is required, this is not something for an amateur mechanic.
  • Core size: 28" x 9.25"x 3.5"
__________________
[COLOR=Black]
[/COLOR]
[COLOR=DimGray]407.878.5870
[COLOR=DimGray]Check us out on[/COLOR]
[/COLOR][COLOR=DimGray]
[/COLOR]
Performance Race Solutions is offline
Old 11-14-2011, 12:00 PM   #2
Member#: 248291
2005 Your Dream Car
All weekend PM's replied to! Ready to get some parts out the door
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-15-2011, 01:35 PM   #3
Member#: 248291
2005 Your Dream Car
Need some port work done? we can do that to! Just call and ask us about what we can do to help your heads breathe a bit better
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-16-2011, 01:19 PM   #4
Member#: 248291
2005 Your Dream Car
the middle of the week is here. Get those orders in before the weekend!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-17-2011, 12:01 PM   #5
Member#: 248291
2005 Your Dream Car
Thank you for the orders! Please contact us if you need something and dont see it listed!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-18-2011, 09:36 AM   #6
Member#: 248291
2005 Your Dream Car
Last day before the weekend! Keep those PM's Coming and let me know what goodies i can get sent to you
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-22-2011, 03:20 PM   #7
Member#: 248291
2005 Your Dream Car
PM'd replied!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-28-2011, 01:30 PM   #8
Member#: 248291
2005 Your Dream Car
Back from stuffing our faces! Hope everyone had a good Thanksgiving!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-30-2011, 09:16 AM   #9
Member#: 248291
2005 Your Dream Car
PM's Replied. Thank you for your business!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-05-2011, 10:44 AM   #10
Member#: 248291
2005 Your Dream Car
Hope everyone had a great weekend!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-08-2011, 10:47 AM   #11
Member#: 248291
2005 Your Dream Car
Brian Crower Cams
The Brian Crower Stage 2 Street/Strip Specification Cams for the 02-05 WRX EJ205 and 04-07 STI EJ257 are Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose cars and daily drivers. The stock springs and retainers can be used but the BC spring and retainer kit is recommended.
Specs:
•Adv. Duration: 272/272
•Duration at .050: 222/222
•Lift: .400/.400(in) 10.16/10.16(mm)
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-15-2011, 09:34 AM   #12
Member#: 248291
2005 Your Dream Car
The weeks drawing to a close, so keep those PM's coming!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-20-2011, 10:47 AM   #13
Member#: 248291
2005 Your Dream Car
Who's ready for the holidays?!?!
Let us know what holiday cheer we can bring you in the form of Gofast Parts
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-22-2011, 04:41 PM   #14
Member#: 248291
2005 Your Dream Car
Enjoy the Holidays! We will be back in action after the weekend
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 01-03-2012, 10:37 AM   #15
Member#: 248291
2005 Your Dream Car
We are back in action!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 01-03-2012, 01:22 PM   #16
Member#: 248291
2005 Your Dream Car
Email or call for machine shop pricing details etc.
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 01-10-2012, 12:02 PM   #17
Member#: 248291
2005 Your Dream Car
New year engine builds. Tax money for parts?
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 01-12-2012, 11:55 PM   #18
Member#: 248291
2005 Your Dream Car
updated shortblock pricing
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 01-30-2012, 03:14 PM   #19
Member#: 248291
2005 Your Dream Car
Tax time! Who needs go-fast goodies?
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 02-01-2012, 04:43 PM   #20
Member#: 248291
2005 Your Dream Car
All pms returned
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 02-08-2012, 10:01 AM   #21
Member#: 248291
2005 Your Dream Car
Who's looking for a build?
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 02-12-2012, 12:22 PM   #22
Member#: 248291
2005 Your Dream Car
Just got in a 2.5 STI Core and 2.0 core for anyone looking to speed their builds up.
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 02-14-2012, 04:16 PM   #23
Member#: 248291
2005 Your Dream Car
Send us pms for best pricing
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 02-21-2012, 11:37 AM   #24
Member#: 248291
2005 Your Dream Car
Who's ready for a build???
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 03-07-2012, 12:33 PM   #25
Member#: 248291
2005 Your Dream Car
got a couple 257 cores that can be built
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Closed Thread
Ultimate Racing GT35R Kits, Fuel System Upgrades, Engine Internals and MORE!!! Innovative Tuning Engine/Power/Exhaust 62 02-11-2008 04:10 PM
Lot of parts, stock engine internals and more! Jpizzzle Engine/Power/Exhaust 14 01-06-2007 12:14 AM
GT35R Kits, Fuel Systems, Engine Internals and more! Innovative Tuning Engine/Power/Exhaust 43 11-27-2006 07:32 PM
Built Motors, Oil Coolers, Cams, Exhaust and Headers, Helix, Perrin and much more! Gruppe-S Engine/Power/Exhaust 21 03-13-2006 05:01 PM
WA: (FS) HUGE Part Out - EGR, TurboXS Exhaust, JDM HID's, STi, Rota, and much more. Rob02WRX Private 'For Sale' Classifieds 2 08-14-2005 04:11 AM
