Old 11-11-2011, 07:57 PM   #1
Meat Supply
Member#: 137902
---- so good
it sucks....
Default ej22t headgasket question
so i'm putting a new headgasket in my car (pass side) and the replacement one i got isn't exactly the same. a couple of the larger ports on the upper side of the gasket don't overlap just right. so i went to my parts guy, whom i trust, and he looked again and said that's the one, and something about an improved design.
so, does this sound right?
thank.
Meat Supply is offline   Reply With Quote
Old 11-12-2011, 05:24 PM   #2
Meat Supply
Member#: 137902
---- so good
it sucks....
well, i've done a little research, but pretty sure i just got the wrong one. not sure why, but between the ej22 and the T, i've seen like 3 different designs. i'm pretty sure the one i have is for an N/a though.
i'm ready to get going on putting everything back together, but i'd really like the correct headgasket is all.
Old 11-12-2011, 08:26 PM   #3
theonlygreat
Member#: 65916
1996 Impreza WRX
What part number do you have?
theonlygreat is offline   Reply With Quote
Old 11-12-2011, 09:07 PM   #4
Meat Supply
Member#: 137902
---- so good
it sucks....
lemme look it up. i'm not at home right now, the one i have is a victor reinz, but it's for an n/a ej22.
Old 11-12-2011, 10:38 PM   #5
RallyColtTurbo
Member#: 16819
EJ22T pistons clear the deck at TDC, so the head gasket is unique to that motor. It
's thicker than a N/A EJ22.
RallyColtTurbo is offline   Reply With Quote
Old 11-13-2011, 09:22 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
It's not thicker but it has different cooling passages.
Marnix is offline   Reply With Quote
Old 11-13-2011, 07:51 PM   #7
Meat Supply
Member#: 137902
---- so good
it sucks....
the one i have does definitely have room for the pistons to come out a little. if it is indeed a revised design, then it seems like it should work.
Old 11-14-2011, 06:49 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
There is no revised design and both pistons (NA and turbo) clear the deck by about 0.3 mm.
Old 11-14-2011, 08:57 AM   #9
Meat Supply
Member#: 137902
---- so good
it sucks....
well, i dunno then.
Old 11-14-2011, 04:15 PM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Have a camera?
You probably got a NA gasket. The turbo gasket has cooling passages which are symmetrical on the upper and lower part of the gasket whereas the NA gasket has differences between the upper and lower passages.
Old 11-14-2011, 11:18 PM   #11
Meat Supply
Member#: 137902
---- so good
it sucks....
i know the HG for the turbo is supposed to be symetrical, but on mine has 2 long ones on the top, and 3 holes on the bottom, but spaced wider than the bottom holes of an n/a gasket.
Old 11-15-2011, 12:17 AM   #12
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Well then you have the wrong gasket.
EJ22T headgaskets austria impreza Engine/Power/Exhaust 2 09-17-2007 06:25 AM
Hybrid compression headgasket question Starkiller Built Motor Discussion 14 06-13-2006 06:07 PM
Hybrid compression headgasket question Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-10-2006 05:38 PM
Quick Headgasket question Russell Rogers Normally Aspirated Powertrain 6 07-19-2005 11:17 AM
headgasket questions GotTurbo Legacy Forum 4 09-23-2004 02:18 PM
