Old 10-14-2012, 10:03 PM   #251
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
I have springs also dude.nice to see that on the road,I been following you for a while and keeping in touch,that is so nice to drive it once again.
EROCS04SBRUSTI is offline   Reply With Quote
Old 10-21-2012, 10:39 PM   #252
Layvon
Member#: 195711
STi 04/05/06/07
Gah! I'm getting stressed out. Between working 60+ hrs a week and middle of November only two weekends away I'm getting nervous.
Found a leak tonight under the throttle body, which means I have to take my FMIC pipes and alternator out to get in there.. thankfully Dom made me look into my MAP low voltage code, cause that thing was leaking like a sieve. I hope I didn't overlook a channel or something in the throttle body when I rotated it. I don't have much time to spare any more.
Things yet to do -
Find boost leak, address, and fix
Figure out which 02 sensor I have is bad.
Drive 900 miles
Yank motor
Tighten head studs
Confirm valve lash is correct
install motor
Test drive to verify nothing else went.
Debating on installing my computer here or down in Chicago... but that can go on the list too.
Layvon is offline   Reply With Quote
Old 10-23-2012, 08:29 PM   #253
Layvon
Member#: 195711
STi 04/05/06/07
Here's the culprit. The bottom side of the throttle body doesn't have enough metal to seal off the map sensor port. this is from rotating the throttle body 90
What modifications are required to get alternator into AC bracket? That appears to be the fastest bet at this point.
Old 10-23-2012, 09:06 PM   #254
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Is there a spacer on the back of the TB? I'm not getting what the problem is
Old 10-23-2012, 09:14 PM   #255
Layvon
Member#: 195711
STi 04/05/06/07
There wasn't enough.metal on the bottom side of the intake manifold to hold the gasket onto the flange tightly.
I just removed alternator, rotated throttle body 90 (stock location) and it is happy again. I called out to outfront motorsports and they are sending me a bracket for alternator. Knee jerk reaction? Yes.
Allows ne to get rid of a lot of pain in ass components. wish i would have done it sooner. I never use AC in my 2012 truck, why I thought to keep it in my car is a mind boggler.
Just held air to 25psi. I'm not boosting more than that, so I stopped.
Old 10-23-2012, 09:29 PM   #256
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Oh I see. I guess that's why Full Race supplies the spacer with there kit. It gives you a flat surface around the entire perimeter to seal against in any orientation you want top run.
Are you gonna delete A/C all together? Condensor and all?
Old 10-24-2012, 05:54 AM   #257
Layvon
Member#: 195711
STi 04/05/06/07
Are you gonna delete A/C all together? Condenser and all?
Yeah, must be. Oh well, this made life a lot easier and would have saved me a lot of heartache if i did it sooner. I got the compressor out last night, and the throttle body in the stock rotation. I'll wait and see about the Condenser, it would make things a lot cleaner looking if I did take it out, however, I'll probably wait till I pull the motor so that I dont have to fight it. Do you need some components or just curious?
Old 10-27-2012, 06:19 PM   #258
Layvon
Member#: 195711
STi 04/05/06/07
I'm about to say **** it.
For some reason, from the throttle body back wont hold any air now. I tested from the Throttle body going towards the turbo and was able to hold 5psi back with my hand, so that eliminates big huge gaping hole there. From the throttle body though it just sounds like air is just rushing though, yet I cannot find a hole that is making any noise. the little ****ing aircompressor that i have kicks on every 45 god damn seconds so as soon as you can make any progress that sonofabiutch kicks on.
Stupid question, but if the engine shut off just right could that affect why it wouldnt hold air? I apparently dont know **** about these motors, cause Im so fed up with chasing these gremlins. Pressure is ****ing on too to try to make it to Chicago in 3 weeks otherwise i'm going to look like a fool when i get down there.
Got my Alternator remount bracket and that installed fine also. Used the new bracket and an old timing belt pulley to make a tensioner in conjunction with the outfront bracket.
https://docs.google.com/open?id=0B79...Ww0cXYxaTJ0Mmc
Anyone willing to look at logs for some help would be much appreciated...
Old 10-27-2012, 08:15 PM   #259
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Rent a bigger compressor and a spray bottle of soapy water.
Old 10-27-2012, 09:35 PM   #260
Layvon
Member#: 195711
STi 04/05/06/07
I honestly think it is in the tune since it is still the first one.. when I first start up the car, it idles amazing. Once it gets warmed up is when I have trouble.
If I hold the accelerator down to 2500 it varies between 2250 and 2750 while keeping my foot at the same position
Old 10-28-2012, 12:33 PM   #261
manitou
Member#: 193757
2006 XTI Limited
So what do you think the fuel trims are too lean? I was thought that you said you had a leak still around the throttle body intake mani junction..
Old 10-28-2012, 03:08 PM   #262
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
sounds like avcs + big cams eating up bunch of air
Bariga is offline   Reply With Quote
Old 10-28-2012, 03:46 PM   #263
Layvon
Member#: 195711
STi 04/05/06/07
Leak has been fixed that you were talking about Manitou. I checked it this morning, and held to 22psi again. I think like bariga said, cams were holding valves open, and warm oil too, which I heard you're supposed to do it cold.
Old 10-28-2012, 04:12 PM   #264
manitou
Member#: 193757
2006 XTI Limited
What cams did you use in your MPS build, r199 b or c? Did you experience this on your build?
Old 10-28-2012, 04:14 PM   #265
manitou
Member#: 193757
2006 XTI Limited
So you guys are thinking the AVCS values are off?
Old 10-28-2012, 05:43 PM   #266
Layvon
Member#: 195711
STi 04/05/06/07
I don't know. Waiting for Dom to advise.
Old 11-06-2012, 09:59 PM   #267
Layvon
Member#: 195711
STi 04/05/06/07
Well glad I took the time to check.. valve lashes were less than perfect.
According to the documentation I have from Cosworth my cams should be .008 +-.001 and. 010 +- .001 for intake / exhaust respectively. Can anyone confirm for the 278/274 cams?
I took good notes and will be tightening head studs tomorrow, hopefully I can mix and match with what is on my car and the 15 extra buckets I have to make it work. Otherwise Jamie at SGP is getting a call!
Old 11-06-2012, 10:17 PM   #268
manitou
Member#: 193757
2006 XTI Limited
I have a set I'll email you the sizes.
Old 11-09-2012, 11:04 PM   #269
Layvon
Member#: 195711
STi 04/05/06/07
Got everything buttoned back up tonight. Got buckets from Angel down in detroit, and everything measured up right at .008 or .007 for intake, and .010 or .009 for exhaust.
Put roughly 15 psi worth of springs in the wastegates too, hopefully a good level for 22-25 psi with boost control.
Head studs are torqued to 98.6 ft pounds a piece, for a little added assurance.
First positive night I've had in the garage in a while. Hoping I can get a hold of Dominic tomorrow to get my base map, because with some luck, I'll have my car fired up again tomorrow afternoon and driving sunday would be nice. Dyno Thursday and only have 135 miles on motor.
Old 11-10-2012, 03:03 AM   #270
manitou
Member#: 193757
2006 XTI Limited
Good progress , now you know for sure what you have. Are you going to do a boost leak check again after its back together and running? Let thing heat cycle and then check for leaks. Did you install the 1 bar spring?
Old 11-10-2012, 08:29 AM   #271
Layvon
Member#: 195711
STi 04/05/06/07
Absolutely going to check. I did install those springs.. man that was a bitch. I don't have a big enough vice so I held it shut by clamping my hands over it and having a friend screw the **** in the effective spring rate is 15.7psi or something like that now. White and maroon what ever those add up to be
Old 11-11-2012, 02:26 AM   #272
Layvon
Member#: 195711
STi 04/05/06/07
Everything went well today! Took a little longer than expected but that's okay. Pressure tested to 25psi and everything held tight. Fired up and idles about the same as it did. Will start and idle fine till you hit the throttle then it bogs down and dies.
Have to blip the throttle to get it to turn on too..
Old 11-12-2012, 04:17 PM   #273
wrexsti123
Member#: 337684
great build keep working hard
wrexsti123 is offline   Reply With Quote
Old 11-12-2012, 06:32 PM   #274
Layvon
Member#: 195711
STi 04/05/06/07
Thanks dude. I see you just joined the forums, dont hesitate to ask for help. I don't know much, but I can steer you to who does!
Levon
Old 11-15-2012, 06:14 PM   #275
Layvon
Member#: 195711
STi 04/05/06/07
Well.. Shes running well. MAP error was taken care of by Dom, nothing major or leak based, just minimum voltage. 200 miles down. 800 to go.
Hitting roughly 10-12 psi for break in boost. Hit 15 once... that was a tempting oops. Kinda like having sex the first time without a condom. You know you shouldn't but it just feels so good!!!
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps wrx. NWIC Private Classifieds 0 11-13-2011 06:49 PM
FS : NJ: 2004 STI Race Build dsds711 Private Vehicle 'For Sale' Classifieds 22 03-19-2011 11:39 AM
2004 sti build questions GA_STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-09-2009 03:31 PM
2004 STI Parts from Racecar Build TxSpeed1 Complete Car Part-Out 36 03-21-2009 03:00 PM
