Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 11-15-2012, 06:19 PM   #276
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Nice dude! I got your TM. Glad to hear the latest break in map is working better! It just comes down to scaling those big injectors regarding the idle and low speed drive-ability. Can you bump up the idle speed to prevent stalling?
Old 11-15-2012, 06:25 PM   #277
Layvon
Member#: 195711
STi 04/05/06/07
Meant to post this too
Layvon is online now   Reply With Quote
Old 11-15-2012, 06:27 PM   #278
Layvon
Member#: 195711
STi 04/05/06/07
I thought about that myself but Dom said the opposite is true. Since the motor runs more efficiently at higher idle it takes less fuel, so its even harder that way. Woildnt hurt to try though.
Old 11-15-2012, 07:34 PM   #279
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
That's nice. You have any updated engine bay pics?
Old 11-15-2012, 08:53 PM   #280
Layvon
Member#: 195711
STi 04/05/06/07
Thanks Kelly - That front end was a lot of work. I took a little bit more bumper than I needed to, but I don't think it will be noticed by many.
I haven't had the camera out much lately. . . but I should here soon. Here is what I do have from my cell phone. Once I get done on the dyno, I plan on making things look a little prettier. If I wait long enough for the dyno, the Tee fitting that people are going to say is a problem will become a Y. If I wait a really long time, I'll run both to the FPR. I'm just tired of spending money right now
To anybody curious about the knock block questions I was asking, Simon from link said that if I hooked it up to the stock knock wire, it'd work great. since it is only a one wire knock sensor he said that you don't need to hook the negative side of the knock block up to anything. I plan on using one of the TGV auxiliary ports, and DI 6, which was one of the cruise control inputs. as long as I don't cut the wrong wire, it shouldn't be too hard to wire that in.
I think that I will be hooking up oil pressure to the another TGV input AN4 or 5, I'm in the process of tinkering with my map that I've "made" seeing what link can do. I think we all know that Bariga voices his opinion, but I do think I have to side with him on this software structure. everything is so intuitive it makes me feel dangerous.
Levon
Old 11-15-2012, 09:41 PM   #281
kellygnsd
Member#: 32669
LINK G4 hybrid STi
If you can pick up a spare harness do it and hack the **** out of one and make a custom harness. It'll make going back to the stock engine/ECU much easier.
I have IAT on ANTemp 2, IC inlet temp on ANTemp 4, EGT on ANVolt 4, Oil pressure on ANVolt 5, Oil temp on ANVolt 7, Fuel pressure on ANVolt 8, and wideband on ANVolt 11
My harness has been raped and I'm all out of analog ins
Old 11-15-2012, 10:04 PM   #282
Layvon
Member#: 195711
STi 04/05/06/07
Holy sensors Batman! I know they are all helpful but I'm not smart enough (yet) to know what to do with them all.
Do you have safety's setup with pretty much everyone of them?
How often do you swap back and forth between hacked harness and stock harness?
Old 11-15-2012, 10:36 PM   #283
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm putting together a stock motor for smog next year so I'll tell you how the switch goes then but it must be easier than having to solder all the plugs back on the stock harness.
I really just want to log that data so I know exactly what went wrong when stuff really goes wrong with the motor... that and I'm a geek and I want to actually calculate IC efficiency instead of just speculating. I also got the turbo speed sensor that I need to wire in for compressor map info.
In the end I definitely will have safeties setup for low oil and fuel pressures and probably rpm limits tied to oil temp
I'm going to set a target date as the first of the year to get my car on the road.
Old 11-16-2012, 06:14 AM   #284
Layvon
Member#: 195711
STi 04/05/06/07
Ahh, okay. Michigan has absolutely no smog rules whatsoever, so I don't have to worry about that. That'd be a pain.
I wondered if that was what you were doing since you had both IAT sensors
That speed sensor will be fun to log. I hope you do, it's been sitting for far too long!
Old 11-28-2012, 08:17 PM   #285
Layvon
Member#: 195711
STi 04/05/06/07
I found a great deal on a haltec tlethanol sensor ... —6 fittings on each side. 5v sensor. I think so.
Old 11-28-2012, 08:38 PM   #286
kellygnsd
Member#: 32669
LINK G4 hybrid STi
The E85 sensor puts out a digital pulse output. Check out your digital input help file in Vipec.
Old 11-28-2012, 10:51 PM   #287
Layvon
Member#: 195711
STi 04/05/06/07
I will do that, just hopped into bed though. Off the top of my head I think I have DI7 and DI8 available still. ... also think That there wasn't an explicitly defined "fuel type" in there. I'm drawing a blank from the drop down menus but I remember seeing it somewhere.
Old 11-29-2012, 02:30 AM   #288
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Select E85 sensor from the drop down menu on any digital input. It digitally reads E85 temp and % from the sensor.
Old 11-29-2012, 06:27 AM   #289
Layvon
Member#: 195711
STi 04/05/06/07
I see the E85 SEnsor in the Help menu, referencing a Siemens part, however, I don't see it in either of my cruise control windows, but I do see it in the Air Con Request, which is DI3. Now the Next issue I've seen... DI3 is not available on the 2004 - 2006 ECU, according to the Link provided Pin out.
So the next option, Would be DI5, Which is the brake switch. Guessing to Cancel the cruise control only or is that for all the brake light controls?
If only to do the cruise control - I think that would work, because there is a pin dedicated to that on the Link ECU, otherwise I am not sure what to do.
Old 11-29-2012, 08:51 AM   #290
CatfaceType-R
Member#: 81102
Originally Posted by Layvon View Post
Michigan has absolutely no smog rules whatsoever.
High five! I might dread the move back to Cali, for this.
CatfaceType-R is offline   Reply With Quote
Old 11-29-2012, 10:33 AM   #291
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I see the E85 Sensor in the Help menu, referencing a Siemens part, however, I don't see it in either of my cruise control windows, but I do see it in the Air Con Request, which is DI3. Now the Next issue I've seen... DI3 is not available on the 2004 - 2006 ECU, according to the Link provided Pin out.
The E85 sensor can only be wired into DI1 - DI6. The E85 sensor tab will only show up on those channels
Old 11-29-2012, 10:40 AM   #292
manitou
Member#: 193757
2006 XTI Limited
Bummer for the bad gas and smog laws. Might as well just run E85!
Old 11-29-2012, 11:49 AM   #293
Layvon
Member#: 195711
STi 04/05/06/07
Kelly was telling.me he has to keep.stock ecu so it's still OBD2 compliant. What a pisser.
Carmi when are you leaving? I was hoping.to.meet you down to Milan at some point
As far as the DI ports, I'm at lunch and will look again, but I think I can make it work.. I hope!
Old 11-29-2012, 01:00 PM   #294
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
If you didnt want to use the digital input, you can use a spare analog input but you need something like the zeitronix gauge to get an analog output for it.
Im looking at the inputs and outputs now, my v88 came in yesterday
slowgenius is offline   Reply With Quote
Old 11-29-2012, 06:23 PM   #295
manitou
Member#: 193757
2006 XTI Limited
That sucks for Kelly and after all the beta and work he has done towards that build!!
Hey Layvon and Carmi, Count me in on the Milan thing if that works out. Just keep me in the loop!! I'm thinking that maybe I can have the XTI ready for Junior around the 17th when he is back at pnl next, that's exciting
Old 11-29-2012, 06:53 PM   #296
Layvon
Member#: 195711
STi 04/05/06/07
That would be sweet! I need ti get off.my ass and figure out what the deal is with my car. My girlfriend graduates the 14th so idk about making it down there by then.
Old 12-02-2012, 01:16 PM   #297
Layvon
Member#: 195711
STi 04/05/06/07
Still no Dice.
AFRs are all over the place as soon as the computer switches over to the 02 sensors vs the map. Idles rock solid for the first 15-25 seconds I turn it on, then it goes back and forth from 12.5 - 17.7. This map previously had no problems, thats why I'm thinking it is a mechanical failure of sort vs the ECU / Sensor aspect. I was hoping for a vacuum line being off.. Didn't get that lucky.
What I've tried to do to diagnose:
1) tighten all fuel fittings, none were loose as a goose, so that wasn't it.
2) vacuum tested to 15psi. Everything checked out. No gaping holes Like I hoped there was.
3) disconnected the lines going from the Turbo nipple to the boost control solenoid and capped it to see if the leak was from that side of the
4) verified that the bov isn't leaking.
5) checked how much vacuum it is pulling. Appears to be similar to before before the sensors turn on.
I attached a log so you can see what I'm talking about.
Code:
AF C %	RPM	Manifold PSI	MAF g/s	MAF V	AFR
0	1328	-7.4	9.4	1.66	14
0	1327	-7.4	9.4	1.64	14
0	1307	-7.25	9.4	1.66	14
0	1316	-7.25	9.4	1.66	14.1
0	1325	-7.25	9.28	1.66	14.1
0	1315	-7.25	9.36	1.66	14.1
0	1306	-7.4	9.56	1.66	14.1
-0.78	1302	-7.4	9.28	1.64	14.1
-1.56	1321	-7.4	9.6	1.66	14.1
-2.34	1286	-7.25	9.32	1.66	14.2
-2.34	1274	-7.25	9.4	1.66	14.2
-2.34	1290	-7.25	9.68	1.66	14.4
-3.12	1282	-7.25	9.48	1.64	14.4
-3.91	1289	-7.25	9.36	1.64	14.4
-4.69	1296	-7.25	9.28	1.64	14.4
-4.69	1294	-7.25	9.44	1.64	14.3
-5.47	1291	-7.25	9.32	1.66	14.3
-5.47	1270	-7.25	9.28	1.64	14.5
-5.47	1266	-7.11	9.4	1.64	14.5
-5.47	1239	-7.11	9.32	1.66	14.7
-5.47	1240	-7.11	9.68	1.66	14.7
-6.25	1239	-6.96	9.68	1.66	14.7
-6.25	1230	-6.82	9.68	1.68	14.7
-6.25	1214	-6.82	9.72	1.68	14.7
-5.47	1256	-6.82	9.64	1.66	14.9
-5.47	1273	-6.82	9.8	1.68	14.9
-4.69	1282	-6.96	9.48	1.66	15.3
-3.91	1294	-6.96	9.52	1.66	15.3
-3.12	1298	-6.96	9.72	1.66	15.6
-2.34	1292	-6.96	9.68	1.66	15.6
-2.34	1313	-6.96	9.84	1.68	15.3
-3.91	1305	-7.11	9.84	1.68	15.3
-3.91	1305	-7.11	9.88	1.66	14.8
-4.69	1325	-7.11	9.84	1.68	14.8
-4.69	1328	-7.11	9.96	1.68	14.7
-6.25	1317	-7.11	9.8	1.68	14.7
-7.03	1300	-7.11	9.88	1.68	14.2
-8.59	1310	-6.96	9.64	1.68	14.2
-8.59	1298	-7.11	9.72	1.66	14
-9.38	1266	-6.96	9.92	1.68	14
-9.38	1257	-6.96	9.6	1.68	14.3
-9.38	1229	-6.82	9.64	1.66	14.3
-8.59	1223	-6.67	9.72	1.68	14.5
-8.59	1228	-6.67	9.52	1.68	14.5
-7.03	1213	-6.67	9.8	1.68	15.2
-5.47	1246	-6.67	9.96	1.7	15.2
-4.69	1258	-6.67	9.92	1.7	15.7
-3.12	1266	-6.67	9.92	1.7	15.7
-0.78	1297	-6.67	9.92	1.7	16
0	1319	-6.67	9.92	1.72	16
1.56	1309	-6.82	10.08	1.7	16
1.56	1304	-6.82	9.76	1.7	16
1.56	1313	-6.96	9.76	1.68	15.5
0.78	1326	-6.96	9.92	1.7	15.5
0	1348	-6.96	10.04	1.68	15
-1.56	1356	-6.96	9.96	1.7	15
-3.91	1338	-7.11	10.04	1.7	14.2
-4.69	1335	-7.11	10.08	1.7	14.2
-7.03	1332	-7.11	9.96	1.68	13.7
-7.81	1327	-7.11	10.04	1.7	13.7
-9.38	1324	-7.11	9.84	1.68	13.6
-10.16	1340	-7.11	9.72	1.68	13.6
-10.94	1350	-7.11	9.88	1.68	13.7
-10.94	1326	-7.11	9.92	1.68	13.7
-11.72	1274	-6.96	9.8	1.68	14.1
-10.94	1270	-6.96	9.84	1.7	14.1
-10.94	1260	-6.96	9.8	1.68	14.5
-10.94	1238	-6.82	9.84	1.7	14.5
-10.16	1248	-6.82	9.6	1.7	14.8
-8.59	1271	-6.82	9.76	1.68	14.8
-7.03	1296	-6.82	9.64	1.68	15.4
-5.47	1264	-6.82	9.88	1.72	15.4
-3.91	1283	-6.82	9.72	1.68	15.8
-3.12	1285	-6.96	9.92	1.7	15.9
-1.56	1310	-6.96	9.88	1.68	15.9
-0.78	1332	-6.96	9.76	1.68	15.7
-0.78	1320	-6.96	9.88	1.68	15.7
-0.78	1325	-6.96	9.84	1.68	15.7
-1.56	1320	-6.96	10.13	1.7	15.4
-1.56	1331	-6.96	9.92	1.7	15.4
-3.12	1332	-7.11	9.92	1.68	15
-3.91	1310	-7.11	9.76	1.7	14.4
-5.47	1318	-7.11	9.76	1.68	14.4
-6.25	1354	-7.11	9.68	1.7	14.1
-7.03	1329	-7.11	9.88	1.68	14.1
-7.03	1308	-7.11	9.76	1.7	14.1
-7.81	1284	-6.96	9.88	1.7	14.1
-7.81	1306	-6.96	9.84	1.68	14.2
-7.81	1290	-6.96	9.92	1.7	14.2
-7.81	1296	-7.11	9.84	1.68	14.6
-7.03	1312	-7.11	9.8	1.68	14.6
-6.25	1269	-6.96	9.88	1.66	15.2
-6.25	1247	-6.96	9.72	1.68	15.2
-6.25	1255	-6.82	9.68	1.68	15.2
-6.25	1244	-6.82	9.8	1.68	15.2
-5.47	1237	-6.82	9.8	1.68	15.2
-4.69	1256	-6.82	9.68	1.7	15.2
-3.91	1264	-6.82	9.84	1.68	15.3
-2.34	1285	-6.82	9.8	1.68	15.3
-0.78	1289	-6.82	9.88	1.68	15.7
0	1321	-6.82	9.88	1.66	15.7
0.78	1320	-6.96	9.96	1.68	15.7
0	1324	-6.96	9.8	1.66	15.7
0	1345	-7.11	9.72	1.68	15.3
-0.78	1354	-7.11	9.64	1.68	15.3
-2.34	1358	-7.11	9.8	1.7	14.5
-3.91	1355	-7.11	9.84	1.68	14.5
-4.69	1361	-7.11	9.8	1.68	14.1
-6.25	1375	-7.25	9.64	1.7	14.1
-7.81	1351	-7.25	9.6	1.68	13.8
-8.59	1322	-7.25	9.64	1.68	13.8
-9.38	1272	-7.25	9.8	1.68	13.8
-9.38	1302	-7.11	9.64	1.68	13.8
-9.38	1301	-7.11	9.88	1.7	14
-9.38	1290	-7.11	9.72	1.68	14
-9.38	1278	-7.11	9.68	1.68	14.5
-8.59	1301	-7.11	9.72	1.66	14.5
-8.59	1280	-7.11	9.32	1.68	14.8
-8.59	1303	-7.11	9.64	1.68	14.8
-8.59	1289	-7.11	9.44	1.68	15
-7.81	1288	-7.11	9.52	1.68	15
-7.03	1282	-7.11	9.4	1.66	15.2
-6.25	1248	-6.96	9.48	1.66	15.2
-6.25	1254	-6.96	9.4	1.68	15.3
-5.47	1236	-6.96	9.48	1.66	15.4
-4.69	1249	-6.96	9.56	1.66	15.4
-3.12	1249	-6.82	9.64	1.68	15.5
-2.34	1278	-6.82	9.56	1.66	15.5
-1.56	1280	-6.96	9.44	1.66	15.5
0	1302	-6.96	9.48	1.68	15.6
1.56	1306	-7.11	9.4	1.66	15.7
1.56	1319	-7.11	9.64	1.68	15.7
1.56	1336	-7.11	9.64	1.68	15.4
0	1335	-7.11	9.64	1.68	15.4
-0.78	1335	-7.25	9.72	1.68	14.6
-1.56	1321	-7.11	9.8	1.68	14.6
-3.12	1316	-7.25	9.72	1.68	14.2
-4.69	1295	-7.25	9.56	1.68	14.2
-6.25	1278	-7.25	9.6	1.66	13.8
-7.03	1262	-7.11	9.6	1.68	13.8
-8.59	1279	-7.11	9.68	1.68	13.7
-8.59	1272	-7.11	9.6	1.66	13.7
-9.38	1283	-7.11	9.36	1.68	13.9
-9.38	1282	-7.11	9.48	1.66	13.9
-9.38	1266	-7.11	9.6	1.66	14.2
-9.38	1283	-7.11	9.28	1.66	14.2
-8.59	1275	-7.11	9.32	1.66	14.7
-8.59	1249	-7.11	9.36	1.66	14.7
-7.81	1259	-6.96	9.4	1.66	15.1
-7.81	1252	-6.96	9.52	1.66	15.1
-7.03	1244	-6.96	9.6	1.66	15.3
-6.25	1227	-6.96	9.52	1.68	15.3
-5.47	1248	-6.96	9.48	1.66	15.3
-3.91	1259	-6.96	9.56	1.66	15.3
-3.12	1278	-6.96	9.4	1.66	15.6
-1.56	1269	-6.96	9.48	1.66	15.6
0	1272	-7.11	9.52	1.66	15.7
0	1298	-7.11	9.52	1.66	15.7
0	1293	-7.11	9.6	1.66	15.5
-0.78	1310	-7.11	9.6	1.66	15.5
-1.56	1319	-7.11	9.52	1.66	15.1
-2.34	1320	-7.11	9.56	1.68	15.1
-3.12	1306	-7.11	9.64	1.66	14.5
-3.91	1306	-7.25	9.72	1.66	14.5
-5.47	1308	-7.25	9.72	1.66	14.1
-6.25	1306	-7.25	9.72	1.66	14.1
-7.03	1301	-7.25	9.4	1.66	14
-7.03	1294	-7.25	9.52	1.66	14
-7.81	1291	-7.25	9.36	1.66	14.1
-7.81	1284	-7.25	9.36	1.66	14.1
-7.81	1261	-7.25	9.32	1.66	14.3
-7.81	1296	-7.25	9.4	1.66	14.3
-7.81	1288	-7.25	9.2	1.66	14.6
-7.81	1260	-7.25	9.28	1.66	14.7
-7.81	1234	-7.11	9.16	1.66	14.7
-7.81	1250	-7.11	9.24	1.66	14.9
-7.03	1232	-7.11	9.28	1.66	14.9
-7.03	1245	-7.11	9.24	1.66	15
-6.25	1231	-6.96	9.2	1.66	15
-5.47	1248	-6.96	9.2	1.66	15
-4.69	1258	-6.96	9.16	1.66	15.3
-3.12	1239	-7.11	9.2	1.66	15.5
-2.34	1263	-7.11	9.04	1.64	15.5
-2.34	1270	-7.11	9.08	1.66	15.4
-2.34	1284	-7.25	9.16	1.66	15.4
-2.34	1284	-7.25	9.24	1.66	15.3
-1.56	1298	-7.25	9.32	1.66	15.3
-0.78	1286	-7.25	9.44	1.66	15.3
-1.56	1284	-7.25	9.4	1.66	15.3
-1.56	1290	-7.25	9.4	1.66	15.1
-1.56	1291	-7.25	9.4	1.68	15.1
-1.56	1280	-7.25	9.36	1.66	14.9
-2.34	1296	-7.25	9.28	1.66	14.9
-3.12	1273	-7.25	9.12	1.68	14.5
-4.69	1269	-7.25	9.44	1.66	14.5
-4.69	1292	-7.25	9.16	1.66	14.3
-4.69	1296	-7.25	9.28	1.66	14.3
-5.47	1272	-7.25	9.24	1.64	14.4
-5.47	1265	-7.25	9.24	1.66	14.4
-6.25	1267	-7.25	9.28	1.66	14.2
-7.03	1284	-7.25	9.04	1.64	14.2
-7.03	1274	-7.4	9.04	1.66	14.3
-7.03	1284	-7.4	9.12	1.64	14.3
-7.03	1282	-7.4	8.96	1.66	14.5
-7.03	1267	-7.25	8.96	1.64	14.5
-7.81	1257	-7.25	9.2	1.66	14.6
-8.59	1246	-7.25	9.08	1.64	14.6
-8.59	1214	-7.25	9.12	1.66	14.5
-8.59	1214	-7.11	9.16	1.66	14.5
-8.59	1212	-7.11	9.04	1.64	14.6
-7.81	1201	-6.96	9.12	1.64	14.6
-7.03	1207	-6.96	9	1.66	15.1
-6.25	1206	-6.96	8.84	1.66	15.1
-3.91	1213	-6.96	9.16	1.66	15.3
-2.34	1221	-6.96	9.04	1.64	15.3
-1.56	1228	-6.96	9	1.64	15.7
-1.56	1256	-6.96	9.08	1.66	15.7
-0.78	1255	-7.11	8.92	1.64	15.6
0	1267	-7.25	8.96	1.64	15.6
0.78	1265	-7.25	8.92	1.64	15.6
0.78	1268	-7.25	9.16	1.66	15.6
0	1265	-7.25	9.2	1.64	15.3
-0.78	1288	-7.25	9	1.66	15.3
-2.34	1271	-7.25	9.12	1.66	14.9
-3.12	1272	-7.4	8.92	1.64	14.3
-3.91	1287	-7.4	8.84	1.64	14.3
-4.69	1291	-7.4	9	1.64	14.1
-5.47	1254	-7.25	9.16	1.64	14.1
-6.25	1256	-7.25	9	1.64	14.1
-7.81	1205	-7.25	9.04	1.64	13.9
-7.81	1218	-7.25	9	1.62	13.9
-8.59	1220	-7.11	9	1.64	14
-9.38	1224	-7.11	9.08	1.66	14.1
-8.59	1183	-6.96	8.96	1.62	14.1
-8.59	1195	-6.96	8.8	1.62	14.4
-7.81	1161	-6.82	9.16	1.64	14.4
-7.81	1186	-6.82	9.04	1.64	14.8
-7.03	1200	-6.82	9.16	1.64	14.8
-7.03	1192	-6.67	9.28	1.66	15.2
-4.69	1196	-6.82	9.28	1.66	15.2
-3.12	1226	-6.82	9.2	1.64	15.6
-1.56	1246	-6.82	9.48	1.66	15.6
-0.78	1254	-6.82	9.36	1.66	15.7
0	1266	-6.96	9.52	1.66	15.7
0	1269	-6.96	9.36	1.66	15.5
-0.78	1272	-7.11	9.24	1.66	15.5
-1.56	1283	-7.11	9.28	1.66	15
-2.34	1289	-7.25	9.32	1.66	15
-3.91	1273	-7.11	9.52	1.66	14.4
-4.69	1263	-7.11	9.44	1.66	14.4
-7.03	1269	-7.11	9.44	1.68	13.9
-8.59	1260	-7.11	9.52	1.66	13.9
-9.38	1235	-7.11	9.36	1.66	13.7
-10.16	1264	-7.11	9.24	1.66	13.7
-10.94	1268	-7.11	9.24	1.66	13.7
-10.94	1217	-7.11	9.2	1.66	13.7
-10.94	1235	-6.96	9.08	1.66	14
-10.94	1191	-6.96	9.2	1.66	14
-10.94	1211	-6.96	9.2	1.66	14.4
-9.38	1180	-6.82	9.28	1.66	14.4
-6.25	1158	-6.67	9.16	1.66	15.3
-4.69	1172	-6.67	9.16	1.64	15.3
-3.91	1198	-6.67	9.16	1.64	15.7
-3.12	1236	-6.82	9.12	1.66	15.7
-2.34	1240	-6.82	9.08	1.66	15.7
0	1256	-6.82	9.2	1.64	15.7
2.34	1247	-6.96	9.32	1.66	16
2.34	1254	-6.96	9.16	1.66	16
1.56	1291	-7.11	9.2	1.64	15.7
0	1297	-7.11	9.4	1.66	15.7
-0.78	1300	-7.11	9.36	1.66	15.1
-0.78	1292	-7.11	9.28	1.64	15.1
-1.56	1309	-7.25	9.4	1.64	14.5
-3.12	1289	-7.25	9.48	1.66	14.5
-5.47	1272	-7.25	9.36	1.66	14
-7.03	1283	-7.25	9.4	1.66	13.7
-7.81	1288	-7.25	9.44	1.66	13.7
-8.59	1267	-7.25	9.44	1.66	13.7
-9.38	1269	-7.11	9.16	1.66	13.7
-10.94	1245	-7.11	9.16	1.64	13.7
-10.94	1238	-7.11	9.16	1.64	13.8
-10.94	1250	-7.11	9.24	1.64	14.1
-11.72	1235	-7.11	9.24	1.64	14.1
-10.94	1219	-7.11	9.28	1.64	14.3
-10.94	1208	-6.96	9.36	1.64	14.3
-10.16	1198	-6.96	9.16	1.64	15
-8.59	1194	-6.96	9.24	1.64	15
-7.03	1168	-6.82	9.36	1.64	15.4
-5.47	1221	-6.82	9.32	1.64	15.4
-4.69	1233	-6.82	9.24	1.64	15.7
-2.34	1240	-6.96	9.16	1.66	15.7
0.78	1250	-6.96	9.12	1.64	16.2
4.69	1248	-7.11	9.16	1.64	16.2
6.25	1266	-7.11	9.12	1.66	16.6
6.25	1266	-7.11	9.24	1.66	16.6
6.25	1298	-7.11	9.12	1.64	15.9
6.25	1280	-7.25	9.24	1.66	15.9
4.69	1299	-7.25	9.2	1.64	15.3
3.91	1303	-7.4	9.24	1.66	15.3
1.56	1288	-7.25	9.24	1.66	14.3
-0.78	1308	-7.4	9.16	1.64	14.3
-3.12	1302	-7.4	9.16	1.66	13.5
-5.47	1304	-7.4	9.2	1.66	13.5
-7.81	1290	-7.4	8.92	1.66	13.2
-9.38	1293	-7.4	9.08	1.64	13.2
-11.72	1234	-7.4	9.12	1.66	13.1
-12.5	1225	-7.25	9.16	1.66	13.1
-13.28	1152	-7.11	8.76	1.66	13.3
-14.84	1142	-6.96	8.84	1.66	13.3
-14.06	1124	-6.82	8.76	1.64	13.5
-13.28	1092	-6.67	9.08	1.66	13.5
-12.5	1027	-6.53	9.56	1.66	14.1
-10.16	1046	-6.24	9.48	1.64	14.1
-5.47	1136	-6.09	9.56	1.66	15.9
0.78	1202	-6.24	9.56	1.66	15.9
2.34	1230	-6.38	9.4	1.66	17
6.25	1243	-6.53	9.24	1.66	17
9.38	1282	-6.82	9.4	1.66	17.4
10.16	1311	-6.96	9.28	1.66	17.4
8.59	1306	-6.96	9.28	1.66	16.5
6.25	1314	-7.11	9.2	1.66	16.5
3.12	1320	-7.11	9.28	1.64	14.7
1.56	1327	-7.25	9.24	1.66	14.7
-1.56	1313	-7.25	9.48	1.66	13.7
-3.91	1303	-7.25	9.6	1.66	12.8
-7.81	1302	-7.25	9.48	1.66	12.8
-10.94	1302	-7.25	9.48	1.66	12.6
-12.5	1267	-7.25	9.4	1.66	12.6
-14.84	1254	-7.11	9.32	1.66	12.6
-16.41	1185	-7.11	9.2	1.64	12.8
-16.41	1142	-6.96	9.28	1.64	12.8
-17.19	1132	-6.82	9.2	1.64	13.1
-17.19	1103	-6.67	9.12	1.64	13.5
-17.19	1063	-6.53	9.28	1.66	13.5
-16.41	1032	-6.09	9.52	1.68	14.1
-15.62	1038	-5.8	9.68	1.7	14.1
-12.5	1110	-5.66	10.08	1.68	15.7
-6.25	1134	-5.8	9.32	1.66	15.7
-3.12	1184	-5.95	9.52	1.66	16.9
1.56	1184	-6.09	9.48	1.68	16.9
5.47	1231	-6.24	9.48	1.66	17.7
6.25	1226	-6.38	9.48	1.66	17.7
7.03	1257	-6.53	9.56	1.66	16.5
6.25	1305	-6.67	9.68	1.68	16.5
6.25	1340	-6.82	9.8	1.68	15.6
3.91	1344	-6.96	9.72	1.68	15.6
0.78	1342	-6.96	9.68	1.68	14.1
-1.56	1340	-7.11	9.48	1.68	14.1
-3.91	1348	-7.11	9.68	1.68	13.3
-7.03	1327	-7.25	9.64	1.68	13.3
-10.16	1293	-7.11	9.64	1.66	12.9
-12.5	1293	-7.11	9.56	1.68	12.9
-14.06	1270	-7.11	9.76	1.66	12.9
-15.62	1251	-6.96	9.64	1.68	12.9
-15.62	1185	-6.96	9.52	1.66	13.2
-15.62	1125	-6.82	9.52	1.66	13.2
-15.62	1133	-6.53	9.4	1.66	13.6
-14.84	1107	-6.38	9.32	1.66	13.6
-14.06	1135	-6.24	9.6	1.68	14.3
-12.5	1154	-6.24	9.68	1.68	14.3
-8.59	1150	-6.24	9.64	1.68	15.4
-3.12	1180	-6.09	9.76	1.68	15.4
0	1164	-6.09	9.68	1.66	16.7
2.34	1222	-6.24	9.68	1.66	16.7
4.69	1269	-6.53	9.68	1.66	17
6.25	1292	-6.67	9.68	1.68	17
8.59	1330	-6.82	9.48	1.66	16.8
8.59	1356	-6.96	9.88	1.68	16.8
7.03	1353	-7.11	9.68	1.68	15.8
3.12	1363	-7.11	9.68	1.68	15.8
1.56	1368	-7.25	9.56	1.68	14.1
-0.78	1347	-7.25	9.56	1.68	14.1
-3.91	1342	-7.25	9.48	1.68	13.3
-7.03	1317	-7.25	9.44	1.68	13.3
-10.94	1321	-7.25	9.52	1.68	12.9
-12.5	1279	-7.25	9.4	1.66	12.9
-14.06	1288	-7.11	9.52	1.66	12.7
-15.62	1221	-7.11	9.24	1.66	12.9
-16.41	1232	-6.96	9.16	1.64	12.9
-17.97	1171	-6.96	9.32	1.64	13.4
-17.19	1111	-6.82	9.4	1.66	13.4
-17.19	1031	-6.53	9.2	1.64	13.8
-16.41	1096	-6.24	9.48	1.66	13.8
-14.06	1141	-6.24	9.44	1.66	15.3
-9.38	1134	-6.09	9.4	1.66	15.3
-3.12	1124	-6.09	9.44	1.66	16.6
5.47	1151	-6.24	9.4	1.66	16.6
9.38	1203	-6.24	9.64	1.66	18.2
10.16	1254	-6.53	9.44	1.66	18.2
10.16	1283	-6.53	9.6	1.68	17.1
9.38	1317	-6.82	9.44	1.66	17.1
9.38	1346	-6.96	9.44	1.66	16
7.81	1343	-7.11	9.36	1.66	16
4.69	1338	-7.11	9.48	1.66	14.1
2.34	1337	-7.25	9.48	1.66	14.1
0	1353	-7.25	9.52	1.66	13
-2.34	1350	-7.4	9.44	1.66	13
-6.25	1348	-7.4	9.4	1.66	12.5
-9.38	1319	-7.4	9.4	1.66	12.5
-11.72	1310	-7.4	9.4	1.64	12.4
-14.06	1264	-7.25	9.36	1.64	12.4
-15.62	1194	-7.25	9.4	1.64	12.6
-17.19	1146	-6.96	9.24	1.64	12.6
-17.97	1094	-6.67	9.32	1.62	13
-17.97	1016	-6.67	9.28	1.62	13
-17.97	1011	-6.24	9.6	1.64	13.4
-17.19	1052	-5.95	9.52	1.66	13.4
-16.41	1126	-5.95	9.48	1.68	14.3
-14.06	1079	-5.95	9.08	1.66	14.3
-8.59	1122	-5.95	9.28	1.66	16.2
-2.34	1153	-5.95	9.48	1.68	16.2
3.91	1206	-6.09	9.56	1.68	17.5
3.91	1221	-6.24	9.52	1.68	17.5
5.47	1267	-6.53	9.52	1.64	17.2
6.25	1297	-6.67	9.64	1.66	17.2
7.03	1342	-6.82	9.6	1.66	16.6
6.25	1362	-6.96	9.6	1.66	16.6
2.34	1366	-7.11	9.56	1.66	14.9
0	1356	-7.11	9.64	1.68	14.9
-1.56	1335	-7.25	9.44	1.66	13.5
-4.69	1329	-7.25	9.6	1.68	13.5
-7.03	1304	-7.25	9.36	1.66	12.9
-11.72	1317	-7.25	9.4	1.68	12.9
-13.28	1276	-7.25	9.24	1.66	12.8
-14.84	1243	-7.11	9.28	1.66	12.8
-15.62	1215	-7.11	9.12	1.66	12.9
-16.41	1155	-6.96	9.04	1.64	13.2
-17.19	1156	-6.82	9.16	1.64	13.2
-17.19	1111	-6.53	9.24	1.66	13.7
-16.41	1057	-6.38	9.24	1.66	13.7
-15.62	1020	-6.24	9.12	1.66	14.3
-13.28	1064	-5.95	9.24	1.66	14.3
-7.81	1127	-5.95	9.44	1.66	16.2
-1.56	1152	-5.95	9.56	1.68	16.2
7.03	1163	-6.09	9.52	1.66	17.7
8.59	1224	-6.24	9.52	1.66	17.7
10.16	1275	-6.38	9.16	1.66	17.5
10.94	1302	-6.67	9.32	1.66	17.5
10.94	1322	-6.82	9.56	1.66	16.6
11.72	1340	-6.96	9.56	1.66	16.6
9.38	1340	-7.11	9.68	1.68	15
6.25	1347	-7.25	9.48	1.68	15
3.12	1358	-7.25	9.36	1.66	13.4
1.56	1352	-7.25	9.36	1.68	13.4
-1.56	1349	-7.4	9.44	1.66	12.8
-4.69	1328	-7.4	9.28	1.64	12.8
-8.59	1326	-7.4	9.28	1.66	12.4
-10.16	1286	-7.4	9.04	1.64	12.4
-13.28	1243	-7.4	9.12	1.64	12.6
-14.06	1207	-7.25	8.96	1.64	12.6
-14.84	1180	-7.11	8.88	1.64	13
-15.62	1134	-6.96	9.04	1.64	13
-16.41	1112	-6.82	8.88	1.62	13.3
-16.41	1116	-6.67	9.08	1.64	13.3
-15.62	1072	-6.38	9	1.64	13.9
-14.84	1074	-6.24	9.04	1.66	13.9
-12.5	1090	-6.24	9.68	1.68	14.8
-7.81	1098	-6.09	9.36	1.66	14.8
-0.78	1137	-6.09	9.28	1.64	16.5
4.69	1202	-6.24	9.32	1.66	16.5
10.94	1222	-6.38	9.32	1.66	17.7
12.5	1252	-6.53	9.36	1.66	17.7
13.28	1293	-6.82	9.2	1.66	17.5
16.41	1288	-6.82	9.28	1.66	17.5
15.62	1310	-6.96	9.28	1.64	16.6
13.28	1314	-7.11	9.44	1.66	16.6
9.38	1323	-7.11	9.48	1.66	14.2
7.81	1312	-7.25	9.4	1.66	14.2
4.69	1318	-7.25	9.48	1.66	13
3.12	1341	-7.25	9.52	1.66	13
-0.78	1355	-7.4	9.44	1.66	12.2
-4.69	1342	-7.4	9.44	1.66	12.2
-7.03	1340	-7.4	9.24	1.66	11.9
-9.38	1322	-7.55	9.32	1.66	11.9
-11.72	1274	-7.4	9.32	1.66	12
-13.28	1216	-7.4	9	1.66	12
-16.41	1183	-7.25	8.96	1.64	12.5
-17.97	1101	-6.96	9.16	1.66	12.8
-19.53	1071	-6.67	9.28	1.66	12.8
-19.53	1110	-6.53	8.92	1.66	13.2
-19.53	1144	-6.53	9.28	1.66	13.2
-18.75	1080	-6.24	9	1.64	13.9
-17.19	1103	-6.24	8.92	1.64	13.9
-14.84	1068	-6.24	9.04	1.64	16.2
-9.38	1078	-6.09	9.04	1.62	16.2
-4.69	1123	-6.09	9.08	1.62	16.8
0	1139	-6.24	9.2	1.66	16.8
3.91	1176	-6.38	9.28	1.64	17.5
5.47	1235	-6.53	9.24	1.64	17.5
7.81	1262	-6.67	9.12	1.66	17.3
8.59	1289	-6.67	9.2	1.66	17.3
7.81	1312	-6.96	9.07	1.66	16.2
7.03	1304	-7.11	9.08	1.64	16.2
3.91	1316	-7.25	9.12	1.66	14.6
1.56	1331	-7.25	9.2	1.64	14.6
-0.78	1329	-7.4	9.28	1.64	13.6
-3.12	1313	-7.4	9.2	1.64	13.6
-6.25	1300	-7.4	9.2	1.64	13.1
-7.81	1306	-7.4	9.2	1.64	13.1
-10.16	1291	-7.4	9.03	1.64	12.9
-11.72	1247	-7.4	9.12	1.64	12.9
-12.5	1189	-7.25	9.04	1.64	13.1
-14.06	1133	-6.96	9.2	1.66	13.1
-14.06	1087	-6.82	9.04	1.66	13.4
-14.84	1128	-6.67	8.76	1.64	13.4
-14.84	1146	-6.67	8.68	1.64	13.7
-14.06	1096	-6.53	8.76	1.64	13.7
-11.72	1117	-6.53	8.68	1.64	14.6
-8.59	1087	-6.53	8.76	1.62	14.6
-5.47	1141	-6.53	8.84	1.62	15.8
-3.91	1166	-6.53	8.84	1.64	15.8
-2.34	1178	-6.53	9.04	1.64	16.2
0	1195	-6.67	9	1.64	16.2
3.91	1236	-6.82	9	1.64	16.5
5.47	1256	-6.96	9.15	1.64	16.5
7.81	1260	-6.96	8.96	1.64	16.7
8.59	1257	-7.11	9	1.64	16.7
7.81	1279	-7.11	8.84	1.62	16
6.25	1278	-7.25	8.88	1.64	16
3.12	1284	-7.4	9.04	1.64	15
1.56	1280	-7.4	9.12	1.64	15
-0.78	1284	-7.4	9.24	1.62	13.9
-3.12	1294	-7.4	9.15	1.64	13.9
-5.47	1300	-7.4	9	1.64	13.3
-8.59	1284	-7.55	8.96	1.64	13.3
-9.38	1265	-7.4	8.88	1.62	13
-11.72	1244	-7.4	9	1.66	13
-12.5	1174	-7.25	8.8	1.64	13
-13.28	1111	-7.11	8.64	1.64	13.3
-14.06	1097	-6.96	8.56	1.62	13.3
-14.06	1084	-6.82	8.64	1.62	13.6
-14.06	1030	-6.67	8.6	1.62	13.6
-13.28	1030	-6.53	8.72	1.6	14.2
-10.94	1057	-6.38	9	1.64	14.2
-8.59	1066	-6.24	9.04	1.64	15.5
-3.91	1102	-6.09	9.2	1.66	15.5
0	1131	-6.24	9.12	1.66	16.6
3.91	1206	-6.38	9.2	1.64	16.6
7.03	1237	-6.53	9	1.64	17.2
9.38	1257	-6.67	9.12	1.64	17.2
11.72	1282	-6.82	8.96	1.64	17
10.94	1285	-7.11	8.96	1.64	17
10.16	1289	-7.25	9.07	1.64	15.7
6.25	1311	-7.25	9.2	1.66	15.7
3.91	1317	-7.4	9.24	1.64	14
2.34	1315	-7.25	9.36	1.64	14
-0.78	1300	-7.4	9.2	1.62	13.1
-3.12	1308	-7.4	9.28	1.64	13.1
-7.03	1290	-7.4	9	1.6	12.5
-10.16	1271	-7.4	8.84	1.6	12.5
-11.72	1260	-7.4	8.96	1.64	12.5
-14.06	1180	-7.25	8.96	1.64	12.5
-16.41	1149	-7.11	8.92	1.62	12.7
-17.19	1077	-6.96	8.56	1.62	12.7
-17.97	1056	-6.67	8.88	1.64	13
-17.97	988	-6.53	8.88	1.62	13
-17.97	951	-6.24	8.72	1.68	13.4
-17.19	1022	-5.8	9.48	1.7	13.4
-14.84	1090	-5.66	9.72	1.68	14.3
-11.72	1106	-5.8	8.6	1.62	14.3
-6.25	1107	-5.95	8.92	1.62	16.9
1.56	1084	-5.95	8.96	1.64	16.9
8.59	1128	-5.95	9.04	1.64	18.4
10.16	1150	-6.24	9.08	1.64	18.4
7.81	1207	-6.38	9.32	1.66	17.7
7.81	1264	-6.53	9.32	1.66	17.7
7.81	1293	-6.67	9.44	1.66	16.5
7.03	1320	-6.96	9.32	1.66	16.5
4.69	1338	-7.11	9.4	1.66	15.2
1.56	1353	-7.25	9.32	1.66	15.2
-0.78	1329	-7.25	9.4	1.66	13.5
-3.12	1310	-7.4	9.56	1.66	13.5
-7.03	1314	-7.4	9.56	1.66	12.9
-10.16	1298	-7.4	9.44	1.66	12.9
-11.72	1268	-7.25	9.16	1.66	12.7
-13.28	1250	-7.25	9.08	1.64	12.7
-14.84	1178	-7.11	9.2	1.66	12.9
-15.62	1140	-7.11	9.04	1.62	13.2
-17.19	1108	-6.82	9.04	1.64	13.2
-17.97	1053	-6.67	9.16	1.64	13.3
-17.19	1072	-6.53	8.96	1.64	13.3
-16.41	1112	-6.53	8.76	1.64	13.9
-15.62	1077	-6.38	8.68	1.66	13.9
-12.5	1073	-6.38	8.84	1.64	15.5
-7.03	1105	-6.38	8.8	1.62	15.5
0	1135	-6.38	8.72	1.62	17
3.12	1116	-6.38	8.76	1.62	17
5.47	1212	-6.38	8.88	1.62	17.4
7.03	1214	-6.67	9	1.64	17.4
Old 12-02-2012, 06:16 PM   #298
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Idle never drops after warmup? When do you plan on putting in she Vipec?
Old 12-02-2012, 07:18 PM   #299
Layvon
Member#: 195711
STi 04/05/06/07
It will eventually get down ~8-900. I started logging the second the car was on. I bet I ended that log ~45 seconds after start up and it is 33 out here so it wasn't warmed up by any means. After the car has been driven, it doesn't idle without some convincing.
As for the link install. .. I was hoping to wait till 1,000 miles. I'm not to confident in my map making ability
Old 12-08-2012, 02:27 PM   #300
Layvon
Member#: 195711
STi 04/05/06/07
This is about to be somebody else's problem
I found a fuel leak again. Same place on the same injector as before one drip about every 2-3 seconds. Thankfully I had extra orings and the other jazz to fix it this time. I was all giddy getting ready to start it up and then the same problem happened.
Idles fine until the sensors get warmed up then all over the place. ...
Do I dare say a bad sensor? These sensors are appx 6 weeks old, and haven't been banged around at all.
PLEASE if anyone has any ideas let me know.
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps wrx. NWIC Private Classifieds 0 11-13-2011 06:49 PM
FS : NJ: 2004 STI Race Build dsds711 Private Vehicle 'For Sale' Classifieds 22 03-19-2011 11:39 AM
2004 sti build questions GA_STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-09-2009 03:31 PM
2004 STI Parts from Racecar Build TxSpeed1 Complete Car Part-Out 36 03-21-2009 03:00 PM
