Old 04-04-2012, 06:17 AM   #76
Layvon
Member#: 195711
STi 04/05/06/07
Originally Posted by Bariga View Post
why are you trying to **** with design that 100's of engineers come up with?
Thats the pot calling the kettle black
Who are you talking to Bariga?
As for capping them, ( I think thats what Bariga is referring to) I could do that, but if they are for equalizing pressure between the heads and the crank case, then it might be a good idea to keep them. HOWEVER if having a catch can on the heads and PCV ventilates enough, then I could see being able to cap them, because there shouldn't be much difference in pressure anyways.
Long ways from that dilemma. Hoping to get my gasket kit this week so I can start bolting things down.
Layvon
Layvon is offline   Reply With Quote
Old 04-04-2012, 10:55 AM   #77
joshuaj
Member#: 216249
2011 STI Sedan
LMAO, I was going to say the same thing...
joshuaj is offline   Reply With Quote
Old 04-04-2012, 11:45 AM   #78
CorneliusRox
Member#: 315555
08 A4 Quattro 6MT
Yes - He has never done anything to a subaru just knows about them. Audi people :LOL:
I dont know about Subi's really, just engines and the idea behind a PCV system. I still think we have more to talk about in PM.
And the 'merely connections', I see your idea but isnt it all equalized inside the engine/heads, or are you just saying for some extra help?
PS - I still think of myself as a dodge diesel person more than an Audi person!
CorneliusRox is offline   Reply With Quote
Old 04-05-2012, 12:15 AM   #79
DSM Nexus
Member#: 196985
2004 EVO VIII
More power means more crank case pressure. I would not suggest capping off vents for the power you are looking for.
DSM Nexus is offline   Reply With Quote
Old 04-05-2012, 12:53 AM   #80
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
What's the point of routing that case pressure through the heads and into a different catch can?
I mean, if you're concerned about case pressure, why not just connect each catch can to a 4-way connector that connects to a crank vent and two head vents? That way you get basically a straight shot from two head vents into two catch cans when case pressure is high.
Old 04-05-2012, 01:40 AM   #81
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Bariga is offline   Reply With Quote
Old 04-10-2012, 02:53 PM   #82
CorneliusRox
Member#: 315555
08 A4 Quattro 6MT
Parker makes a 90deg PTC (push to connect) fitting with a 320micron filter built in. I think I am going to try it out on my PCV setup. It is made to hold back oil and oil bubbles so it sounds perfect.
just a heads up.
Old 04-10-2012, 05:05 PM   #83
Layvon
Member#: 195711
STi 04/05/06/07
Thanks for help. Going with setup in picture above. I'm trying enough new things on this build. I've already got everything to route and make my catch can setup.
Old 04-11-2012, 10:46 AM   #84
CorneliusRox
Member#: 315555
08 A4 Quattro 6MT
ha ha I figured. I just found it so I thought I would share.
Old 04-11-2012, 08:14 PM   #85
Layvon
Member#: 195711
STi 04/05/06/07
One head is on!
Been cleaning up the sealing surfaces for valve cover and getting oil pan on tonight.
When I was torquing down the head studs, it was the absolute most nervous I've ever been working on a car. ... And no matter how many times I read the instructions... I still missed the friggen bold statement right in the instructions..."If protruding into the waterjacket, use ARP thread sealer"
My dumbass didn't catch it even though Ive seriously read them like 4-5 times since this morning, trying to avoid something like this. Any tips on what to do?
Old 04-11-2012, 09:17 PM   #86
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
The head studs do not protruded into the water jacket. You didn't forget anything.
Old 04-11-2012, 10:22 PM   #87
Layvon
Member#: 195711
STi 04/05/06/07
I put ultra torque on that end too though.
got it cleaned out. Out of spite to my self, I'm putting them on again now though. Thanks Kelly! I owe you!
Old 04-11-2012, 11:04 PM   #88
Layvon
Member#: 195711
STi 04/05/06/07
Well they thumbed in till the bottom without a hitch ... so I backed them off the bottom and reinstalled, went 4 stages to get to torque 40,60,80,90 put valve covers on and covered cause tomorrow is a new day.
Other head and external accessories are tomorrows goal
Old 04-12-2012, 09:26 AM   #89
CorneliusRox
Member#: 315555
08 A4 Quattro 6MT
the heads are only meant to torque to 90ftlb?
And what are you waiting for or is it just a matter of throwing it all together now?
Old 04-12-2012, 10:44 AM   #90
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Depending on what studs you go with and what type of boost you run I've seen people torque the head studs to as much as 110 ft-lbs but for the standard ARP's they recommend 90 ft-lbs.
Old 04-12-2012, 11:04 AM   #91
Layvon
Member#: 195711
STi 04/05/06/07
Motor just needs to be assembled; should be this weekend.
Waiting for transmission funds yet. Waiting for Turbo funds
Waiting for exhaust funds
Waiting for ecu funds
Waiting for tune funds.
That's "it".
Old 04-13-2012, 08:12 PM   #92
DSM Nexus
Member#: 196985
2004 EVO VIII
You sure you only want 90lbs for 32psi?
Old 04-14-2012, 09:10 AM   #93
Layvon
Member#: 195711
STi 04/05/06/07
Ive never heard it was acceptable to go higher on those studs
Old 04-15-2012, 09:02 PM   #94
Layvon
Member#: 195711
STi 04/05/06/07
Well - waiting on getting some camshaft seals for exhaust. Kit came with 4 AVCS sized seals. . . Bummer. Other than that, I might throw on the Intake Manifold tomorrow just to take a sneak peak. Ultimately waiting on money for my transmission right now. I'm struggling not to buy the little things right now so I can get gtasti his money for the trans.
Battery relocation to trunk completed. Thought that it would have to be moved 100% for sure to run reversed IM. Well... Guess it is just easier to remove it now. Might put that Catch can in that location instead.
Interior cleaned up from all the bull**** that has accumulated since September '03. Found a previous owners pocket knife under the carpet
Along with the battery relocation being done, I think that I got the electrical portion of my fuel system complete. Taps into the relay for fuel controller so that it primes then shuts off like oem, though once the AEM is installed this will be gone anyways. Should be all good to throw the carpet in once I get my walbro (another small thing) and set the system up.
Can anyone else comment on the Stud torque? I'm sure that before I get my final tune that I will have the motor out again to fix the inevitable leak out of a seal or something else. This would fit in line with retorquing once heat cycled anyways.
Old 04-17-2012, 12:16 PM   #95
Cfack
Member#: 178605
'08 2.5i
Subscribed.
Thats right Layvon I actually posted in a thread! What do you KNOW about that
~knowy
Cfack is offline   Reply With Quote
Old 04-24-2012, 08:35 PM   #96
Layvon
Member#: 195711
STi 04/05/06/07
Little update for tonight. Fittings came in that I needed to complete everything so here it is put together (Minus the 6-7 foot piece w/ the filter)
Old 04-25-2012, 09:40 PM   #97
Layvon
Member#: 195711
STi 04/05/06/07
Question time - On the bottom of my heads, there is a location that looks like it is for a cam position sensor or something, but it doesn't protrude into the head, just is a inverted boss so to speak. Only thing that I can think of is maybe that it was for the casting on the V8 heads or V7 WRX heads? I really have no idea. I see there is a cam position sensor on 08+ STi, but Im assuming that is for dual AVCS
Heres a picture.
Old 04-26-2012, 12:52 AM   #98
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Yea looks like that. More than likely there was either a model that had both ( I don't know of one, what year are those??? If 07 sti would make sense they were preparing for dual avcs ) or they were just preparing I know my jdm ver8 don't have those , or none that I remember, I only have the larger cam cap on the intake cams exhaust cam is a standard cap
seanathanq83 is offline   Reply With Quote
Old 04-26-2012, 02:03 AM   #99
B.R.E.D
Member#: 289606
06 WRX
white
Looks like a awesome build man.
Looks like you have a T in your fuel line, its on the return side so it probably won't be an issue but I've always prefered Ys when ever its possible.
B.R.E.D is offline   Reply With Quote
Old 04-26-2012, 06:06 AM   #100
Layvon
Member#: 195711
STi 04/05/06/07
Thanks Sean. They are 07 Heads.
Thanks for the compliment man, hoping it comes together smoothly. As for the fuel line - I can't take credit for building the rest, but I can't take the blame for using a T, as I bought the system. I could look into a Y I suppose. . . The other two merged connections are Ys, so that is good.
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps wrx. NWIC Private Classifieds 0 11-13-2011 06:49 PM
FS : NJ: 2004 STI Race Build dsds711 Private Vehicle 'For Sale' Classifieds 22 03-19-2011 11:39 AM
2004 sti build questions GA_STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-09-2009 03:31 PM
2004 STI Parts from Racecar Build TxSpeed1 Complete Car Part-Out 36 03-21-2009 03:00 PM
