Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 11-12-2011, 09:15 PM   #1
Tglazed
Member#: 231216
Default Cold start issues
My car won't start when it's parked in cold weather for long periods of time. I have a red top battery and just replaced the starter. I had my alternator, starter (the new one) and battery all tested and they were good. Also cleaned all the connections, grounds etc... I read that the inhibit switch or crank position sensor can have something to do with this but before throwing money at this problem I wanted to hear your guys opinions-evaluations. Thanks for the help
Tglazed is offline   Reply With Quote
Old 11-12-2011, 09:18 PM   #2
Tglazed
Member#: 231216
Also when it won't start there's a clicking coming from under the steering wheel and all my accessories work when it won't start
Old 11-13-2011, 12:03 AM   #3
wrex_wagon
Member#: 204690
1992 Turbo Wagon
dead red
Did you pull your starter and have it bench tested? If you just had autozone put that machine on your battery, that just tests the current going to your starter. Its just a couple bolts, pull it out and have them test it before you throw money at anything else.
wrex_wagon is offline   Reply With Quote
Old 11-13-2011, 12:04 AM   #4
08WhiteRex
Member#: 187453
2012 Mulletmobile
Injectors? What mods do you have done? I would look into the tune.
08WhiteRex is offline   Reply With Quote
Old 11-13-2011, 12:37 AM   #5
Mush04
Member#: 191705
2007 Limited STi
Swp
is the clicking for sure from under the steering wheel or is it maybe from under the hood? my buddy's 02 had a clicking sound but I'm pretty sure it was coming from the starter, but a clicking would make me think of a loose wire connection or something...?? Good luck finding out though!
Mush04 is offline   Reply With Quote
Old 11-13-2011, 12:52 AM   #6
08WhiteRex
Member#: 187453
2012 Mulletmobile
No, it's the relays in the dash.
Old 11-13-2011, 12:55 AM   #7
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
yup relays sound like the issue
907Bum is offline   Reply With Quote
Old 11-13-2011, 01:20 AM   #8
08WhiteRex
Member#: 187453
2012 Mulletmobile
Lol i own an e85 vehicle in Colorado with no possibility for block heaters. Cold start is just a part of life. The Accessport now has a cold start adjustment feature which is cool. If you're using gasoline then you either have massive problems with your tune, or there's something wrong with the injectors (not atomizing correctly).
Old 11-13-2011, 01:53 AM   #9
Tglazed
Member#: 231216
Starters a brand new oem starter. Can someone tell me about the relay
Old 11-13-2011, 01:36 PM   #10
TiM801
Member#: 289115
I've been having issues, as well.. not exactly same but same balk field, good luck man... hope you get it fixed
TiM801 is offline   Reply With Quote
Old 11-13-2011, 01:38 PM   #11
axleon2
Member#: 154117
2003 Forester
Balk?
axleon2 is offline   Reply With Quote
Old 11-13-2011, 01:55 PM   #12
TiM801
Member#: 289115
Ball** haha dick!
Old 11-13-2011, 02:03 PM   #13
Tglazed
Member#: 231216
what are your symptoms tim801 maybe we can help eachother out
Old 11-13-2011, 04:30 PM   #14
TiM801
Member#: 289115
Well, I replaced my alternator, because my battery wasn't holding a charge. But got that fixex. But then my starter took multiple turns to start, and when I first turned the key my starter would make a squealing noise, so I replaced it. Now it still won't start unless I turn the key and push in clutch at the exact same time. And when it Does start it kinda chugs for a sec than idles fine.. It's pretty annoying...
Old 11-13-2011, 04:32 PM   #15
TiM801
Member#: 289115
It seems to be just one thing after another bro. I just want a reliable scoobie
Old 11-13-2011, 04:48 PM   #16
Tglazed
Member#: 231216
That sucks sorry man. Can I get someone to tell me more about the relay
Strange cold start issue mxboy15u UTEC 7 04-30-2007 04:55 PM
Cold Start Issues SubaruCO Forester Forum 6 12-03-2004 01:31 PM
Cold Start Issues seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 8 11-13-2003 12:26 PM
Elusive Cold Start Issue Sam_P Normally Aspirated Powertrain 10 05-15-2003 05:36 PM
WRX manual cold start issue ort5 Transmission (AT/MT) & Driveline 10 12-17-2001 03:54 PM
