Old 11-13-2011, 10:35 PM   #1
fenderpicks
Member#: 287694
2011 WRX
Default Anything wrong with my log list?
Can someone look at my logs and tell me if somethings wrong with my tune?
HTML Code:
http://www.mediafire.com/?t8p1t4t8yj4114b
HTML Code:
http://www.mediafire.com/?dzu86kx6ojd4c1e
HTML Code:
http://www.mediafire.com/?vtmp097ge1vtny0
Im running a OTS map with 93 octane from Cobb database
fenderpicks is offline   Reply With Quote
Old 11-14-2011, 06:43 PM   #2
fenderpicks
Member#: 287694
2011 WRX
Can someone tell me if somethings wrong with my log T_T
Old 11-14-2011, 07:00 PM   #3
Cobb Tuning
Member#: 4803
What are your mods? Which staged map do you have reflashed (stage 1, stage 2) and which intake map (AEM, Cobb SF, Stock)? I assume this is for a 2011 WRX?
For data logging, the best thing to do is to put the car under some load from low to high RPM. For example, a 3rd gear wide open throttle log from about 2000 RPM to near redline works best, if you can so safely. Random driving doesn't generally tell you a whole lot. Check out our AskCobb data logging video which describes this process and gives you an overview.
I would also put your logs up on google docs (you'll get more people to look at them that way). Make sure you set the permissions on the logs to public so anyone can view them.
Bill
Old 11-14-2011, 07:08 PM   #4
SoCal11Subie
Member#: 299942
Some shorter logs with more 100% throttle would be nice, and please post them up using Google Docs... its free and people will be more inclined to look since they dont have to risk downloading anything.
Im no expert at all:
It seems you have some knock of up to 1.4 during WOT, and the ECU is doing some things to correct it using the Fine Knock Learning. That is a low number tho, and i think you could choose to leave it alone. Dropping down to 91 octane map would do the trick, but lose several HP and TQ. You could find higher quality gas or some quality octane booster to just barely up the fuel quality and id assume it would get rid of the small problems while staying on the 93 map.
18.8PSI at some spikes seems a little high to me... i dunno.
SoCal11Subie is offline   Reply With Quote
Old 11-14-2011, 07:13 PM   #5
fenderpicks
Member#: 287694
2011 WRX
AskCOBB - Subaru Data Logging - YouTube
Bill
Yeah i saw the video yesterday and tried doing the logging, i only logged two times but for some reason i had 5.... i will try do it again tonight at a empty road or something lol.
And i will post it as google doc this time.
And im running Stage 2 93 Octane Map with stock intake, 2011 WRX
With full invidia turboback exhaust
My wife wants to know if you notice anything wrong with this video. BacDoc Off-Topic 56 11-09-2009 12:12 AM
Anything wrong with this Log? BlackFighter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 07-24-2009 03:34 PM
Would there be anything wrong with "pausing" my 401k investing? DrDRum Off-Topic 15 10-16-2008 12:02 AM
2006 WRX. Stage 2 + stock exhaust. Anything wrong with my reasoning? dak125 Newbies & FAQs 31 08-16-2006 12:56 AM
whats wrong with my logs? WrXwaBBit Engine Management & Tuning 3 10-05-2005 03:36 PM
