Old 11-14-2011, 07:09 PM   #1
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Default Would these wheels fit my car?
Guys,
I have a MY98 JDM STI, currently using the OEM 16" wheels...
A friend of mine is selling the following 18" wheels:
Questions:
1-) Would those fit my car (bolt on)?
2-) Are these OEM BBS ones?
3-) They don't seem to have the OEM color, do they? I think they have a darker gold color. What do you think?
4-) How much is a reasonable price?
Thanks in advance for your answer!!
wrxstijdm is offline   Reply With Quote
Old 11-14-2011, 08:29 PM   #2
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I thought the OEM GDB BBS wheels were 17". I haven't seen the OEMs in 18", but will let others chime in. What is the wheel width? What is the lug pattern? We need a little more info in order to help.
If he's a friend then shouldn't he be able to tell you?
beaviscih is offline   Reply With Quote
Old 11-14-2011, 09:56 PM   #3
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Well, he's a friend but he's currently on a business trip for 3 weeks and wanted to close deal asap....
I don't know anything about these wheels, and probably he either LOL...
So those are not 18", but probably 17"?
Old 11-14-2011, 10:10 PM   #4
JPiddy
Member#: 56729
00 2.5RS/ 05' STI
Silver/GCM
Is his car on 04' or 05'. 05' switched to the 5x114.3 04' is 5x100 not sure about the MY98 STI. If you know that then you are good.
JPiddy is offline   Reply With Quote
Old 11-14-2011, 10:22 PM   #5
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
My friend's car is an 04 STI... Mine is 5x100..... So I guess wheels are interchangeable?
Old 11-17-2011, 12:26 AM   #6
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
you can only put on 04 STi with 5x100.
However, you probably have to roll the fenders to fit them without rubbing. I'm rubbing with 225/50/16 tires on 16x7.5 +48mm offset wheels with a low drop.
sizzflair is offline   Reply With Quote
Old 11-17-2011, 01:15 PM   #7
Aphex28
Member#: 11506
2015 WRX
Unless they took out the brembos, the car pictured does not look like an STI to me.
If that is the case. The only thing you have to worry about is the wheels not fitting over your 4pot brakes.
You won't really be able to find out until you get the stats on the wheels. They do not look like the OEM BBS that at least came with USDM STI's. These look like Rota tarmac II, Prodrive P1, or something close with BBS center caps in them.
Aphex28 is offline   Reply With Quote
Old 11-25-2011, 03:33 PM   #8
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
And all those will fit over your brakes, but depending on if/how much the car is lowered, and what size tyre is on the rims now you could get some rubbing.
If they are 18's a GC should have 215/35/18 tyres mounted, while these look like 215/40/18, so slightly higher, which could cause rubbing.
If thet are 17's the WRX fitment is 215/45/17, whereas the GC usually uses 215/40/17.
A higher tyre will also cost a little performance, as the larger circumference lengthens the gearing.
Dutch Scooby lover is offline   Reply With Quote
would these springs fit my car? harrisont Southern California Impreza Club Forum -- SCIC 2 04-06-2008 05:32 PM
Will these wheels fit my car? ConradG Tire & Wheel 1 02-29-2008 10:44 PM
Will these wheels fit my car? ConradG Tire & Wheel 1 02-28-2008 06:28 PM
Will these wheels fit my car? aifan27 Newbies & FAQs 31 04-27-2007 06:08 PM
would these wheels fit my 02wrx norcalboi114 Tire & Wheel 2 12-10-2005 12:03 PM
