Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 11-16-2011, 07:57 PM   #1
shaman
Member#: 164259
Default PWI-1 pdf (asmeng900) input clarification
From the PWI-1 pdf
Locate Green 20awg wire and tap this to the negative side of any fuel injector. This wire is used to monitor injector pulse width, and is very important to solder this connection. If you are unsure about which wire is the negative injector wire, use factory service manual wiring diagrams. Note: This wire can also hook to a specified input on aftermarket ECU's to allow for full 3D mapping of water injection.
What input does the take? I am getting conflicting answers from aquamist and Perrin. Really want to buy one, but I need to know what I can hook up to it first.
shaman is offline   Reply With Quote
Old 11-17-2011, 12:12 PM   #2
PERRINJeff
NASIOC Manufacturer
Member#: 74110
The PWI-1 is not the current system so not sure if you are looking at that instruction sheet or the PWI-2. But if you are getting a PWI-2 system from us, the "Load" pick up wire can be hooked to the injector (pulsed signal) or 0-5V signal. In the control box there is a switch for this depending on how you are using it. We mention that it can be used on a stand alone type ECU where you can add different outputs and make its own mapping for those outputs. But in most situations, this is not needed.
In all situations that have normal injectors (like all Subarus), hook it to the negative side of the injector. This is always the best way to give you the correct amount of Water flow vs. fuel flow.
Hope that helps!
PERRINJeff is offline   Reply With Quote
Old 11-17-2011, 05:21 PM   #3
shaman
Member#: 164259
I am referring to the PWI-1, in specific the asmeng900.pdf. I found a good price on one, but in the searching I have done, and talking to a tech person and Richard, I am getting conflicting statements.
FS - Perrin (Aquamist) PWI-1 system LittleBlueGT Engine/Power/Exhaust 36 01-02-2008 06:42 PM
New PERRIN PWI-1........Rev3 PERRINJeff Water/Methanol Injection, Nitrous & Intercooler Cooling 49 12-15-2007 10:11 PM
FS: Perrin PWI-1 Water Injection System persian prince Engine/Power/Exhaust 4 10-14-2007 11:34 PM
Guaging Interest Perrin PWI-1 water injection pdxsilverwrx NWIC Private Classifieds 0 09-30-2007 07:38 PM
Perrin PWI-1 Kit--Working with Dyno plots??? MrTransAm Water/Methanol Injection, Nitrous & Intercooler Cooling 26 08-01-2007 10:59 AM
