Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 11-17-2011, 07:31 PM   #1
ccrexer
Member#: 299371
Default 99 legacy outback swap?
Heres the deal, I have a 99 legacy outback ej25 phase ? with a blown head gasket. I'm trying to figure out which route to take with it; do I swap the engine for a USDM EJ25t, or fix both heads and put turbo in myself? (is this possible?)
from what research I have done it seems that I would have to replace the drivetrain if I go with the USDM EJ25t. is this true? any advice would be much appreciated.
ccrexer is offline   Reply With Quote
Old 11-17-2011, 08:33 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
No need to swap drivetrain. Yank the motor, pull the heads and take them to a machine shop to see if they are still flat. If they need a little machining no big deal. Just make sure to use the correct headgasket, you might have a phase II block under your EJ25D heads. You can only be sure once you pull the heads and see if the pistons pop out of the bore.
~Josh~
FS/FT : NC: 99 legacy outback, 98 f150, 93 legacy Confusedami Private Vehicle 'For Sale' Classifieds 1 04-05-2011 11:36 PM
will a 99 2.5rs engine bolt into a 99 legacy outback? IllNastyImpreza Subaru Conversions 18 06-27-2007 10:26 PM
WRX / 99 Legacy Outback parts compatibility? bdo Service & Maintenance 1 02-01-2003 09:29 PM
99 Legacy Outback - can't find light bulb bendorion General Community 0 11-06-2002 08:14 PM
Help - 99 Legacy Outback bendorion Newbies & FAQs 0 11-06-2002 08:11 PM
