Old 11-17-2011, 09:44 PM   #1
gf8love
Member#: 300591
Default lifter shims
Does anyone know if subaru makes lifted shims that are smaller than 2.22?
gf8love is offline   Reply With Quote
Old 11-18-2011, 05:54 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
For what engine and year?
Marnix is offline   Reply With Quote
Old 11-18-2011, 01:02 PM   #3
gf8love
Member#: 300591
For the ej20g ver4. I installed ej25d intake valves and when I went to measure for shim size I came up with a size of 2.16mm and as far as I know the smallest size shim subaru makes is a 2.22mm. I picked up the 2.22's and installed them the problem is that I am not with in spec for clearance. I was able to get a clearance of .13 mm but I have been told that for the intake side you need .20mm...what would happen if I ran it with the 2.22's?
Old 11-19-2011, 03:32 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
For the EJ20K (under bucket shims) the thinnest is 1.76. The one you need, shim over bucket, is available from 1.88 thickness. For 2.16 the part number is 13218AC200.
Old 11-19-2011, 10:54 AM   #5
gf8love
Member#: 300591
Hmmm well according to my local subaru parts department the thinest one they make is a 2.22
Old 11-20-2011, 12:45 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Is that an official dealer? Both my EUDM and JDM parts catalogues confirm the availability, and you can order the shim also through SubaruGuineParts.com making this part available world wide.
Old 11-20-2011, 12:59 AM   #7
theonlygreat
Member#: 65916
1996 Impreza WRX
Do you happen to have a list of the shim sizes with part numbers? I can't seem to locate them in the catalog without part numbers.
theonlygreat is offline   Reply With Quote
Old 11-20-2011, 11:15 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The part number for 2.16 is posted somewhere above. It's the same shim as used on the USDM EJ25D engine 1997-1998 so any dealer should really be able to help you. What thicknesses do you need?
Old 11-20-2011, 09:51 PM   #9
gf8love
Member#: 300591
Yea it was through the subaru dealership parts department and they said for sure subaru's smallest lifter shim is 2.22
Old 11-21-2011, 04:46 AM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Well they're wrong just ask them for the partnumber I gave you.
Old 11-21-2011, 08:55 PM   #11
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
dealers vary greatly in the information they provide, it depends heavily on the particular person you are talking to, and also the dealer as a whole regarding how much value they put on their parts departments. The only way for SURE to know if you can get something is to call the dealer with the part number and say "i want this part number" and they will tell you if they can get it. as long as you can personally verify the part number is the right one, then ignore any contradictory information they give you.
I generally test part numbers by putting them into subaruparts.com and seeing what comes up. The only trouble Ive ever had is when their database says something is available when in fact it WAS available but is sold out nationwide. popular OEM addon stuff like jdm sill plates and fog light kits, once the part numbers become known, everyone buys them all...
also Marnix is great.
elislider is offline   Reply With Quote
Rusty brake shims (Do I even NEED shims?) Strider Brakes, Steering & Suspension 6 07-15-2013 01:33 PM
Extremely novice query regarding shims and bovs NJ_wrx Newbies & FAQs 11 11-19-2011 07:55 PM
lifter buckets and shims acidrain088 Pre-2002 Factory Turbo Powertrain 3 07-11-2008 12:09 PM
hydraulic lifters or solid lifters??? keihacker Legacy Forum 0 02-11-2008 07:33 PM
Tech Works Shim Under Bucket Question-Where to get replacement shims? MY99 2.5GT Built Motor Discussion 14 04-19-2006 02:33 PM
