Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 08-28-2013, 07:26 PM   #401
JpLReX
Member#: 243628
05 WRX
CGM
Originally Posted by slowgenius View Post
Tuned with 87 octane?
Lol nice
JpLReX is online now   Reply With Quote
Old 09-02-2013, 06:53 PM   #402
JpLReX
Member#: 243628
05 WRX
CGM
Originally Posted by JpLReX View Post
Lol nice
Anyone else have results with the 18g xtr?
Old 09-02-2013, 08:00 PM   #403
alakazoo22
Member#: 230730
05 FXT 18G -Xtr
black
I have post my number last page but i think nobody see them....
alakazoo22 is offline   Reply With Quote
Old 09-03-2013, 02:09 AM   #404
JpLReX
Member#: 243628
05 WRX
CGM
Sweet man nice numbers
How do you like the turbo?
Old 09-03-2013, 05:57 AM   #405
alakazoo22
Member#: 230730
05 FXT 18G -Xtr
black
I run this turbo since 24 000 km and i really like it. No regret on my choice.
Old 09-03-2013, 09:03 PM   #406
JpLReX
Member#: 243628
05 WRX
CGM
I totally agree I love this turbo plus cant go wrong with blouch
Old 09-07-2013, 10:55 AM   #407
JpLReX
Member#: 243628
05 WRX
CGM
Anyone else with dyno results for the Blouch 18g xtr turbo? Lets keep the thread going
Old 09-15-2013, 12:47 PM   #408
Dirtrace95
Member#: 231315
06 WRX Wgn
Default pipe step
Originally Posted by Maxwell Power View Post
turbine volume depends largely on your setup.
if you are on factory cams, I would not run a 10cm2 housing. I would run the 8cm2.
with the turbine housing you have to take into account the amount of flow it is going to see and then balance power, spool and backpressure to get the right one.
In general:
2L with factory cams: 7cm2 for faster spool, 8cm2 for more top end.
2L with large cams: 8cm2
2.5L with factory cams: 8cm2
2.5L with large aftermarket cams:10cm2
The displacement and the amount of overlap are a general base for how much turbine housing flow you need to sustain. However, if the max a turbo can produce isn't enough to outflow the 8cm2 housing, there isn't much point going to a 10cm2 housing. With that in mind, I would have to see maps for the compressor and turbine for the 18G, but I can't imagine a 10cm2 housing would ever be necessary on it. 10cm2 is a big housing and if you need that big of a housing, you should probably be on a bigger turbo in the first place.
So what about the big mismatch step where the up pipe meets the turbine housing ??? Leave the miss match ??? or ??? and what about just porting inside the turbine housing right where the waste gate opening is ??? Its always ruff n ugly and somewhat restricted there...
Dirtrace95 is offline   Reply With Quote
Old 09-16-2013, 03:54 PM   #409
Maxwell Power
Member#: 190729
The mismatch has nothing to do with the volume.
I would leave it alone honestly. Adding a funnel shape to the turbo housing isn't going to help as it's going to create a high pressure region at the funnel when you want the highest pressure to be at the nozzle. With the step up you'll get a separated bubble of stagnant air.
Also The flow limit of the housing isn't dictated by the inlet size.
Maxwell Power is offline   Reply With Quote
Old 09-16-2013, 07:46 PM   #410
Dirtrace95
Member#: 231315
06 WRX Wgn
So it should be ok to clean up, mild port where the waste gate opens.
very sharp machining edges and a pretty big hump in there narrowing the path
Old 09-16-2013, 09:26 PM   #411
Maxwell Power
Member#: 190729
as I said, the housings are designed with the restriction being the nozzles. A hump isn't going to hurt flow in a properly designed housing. Remember, the designers of these parts have way more budget than you and I. They use all sorts of modeling programs and have years upon years of experience.
Do you really think they would make a housing where a casted hump would impede flow? No. You're fooling yourself if you think they would and you're fooling yourself if you really think that porting it is going to make a difference. I have never, I'll repeat NEVER EVER seen an instance where a ported turbo made a difference. The ONLY type of porting I've ever seen do anything was a ported wastegate transition to help with boost creep.
One example would be in the Mitsu EVO head they have a bump in the port. This bump would appear to impede flow, but it actually helps quite a bit.
Old 09-18-2013, 01:28 AM   #412
Dirtrace95
Member#: 231315
06 WRX Wgn
Gotcha thanks
Old 09-23-2013, 09:09 PM   #413
wrbwrx03
Member#: 220516
'03 WRX
EJ207 :)
nice numbers and great power band!
wrbwrx03 is online now   Reply With Quote
Old 10-01-2013, 01:22 PM   #414
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /07 STI IS SOLD
Subscribed
tekfoc is online now   Reply With Quote
Old 11-18-2013, 04:10 PM   #415
Sti_Dom
Member#: 332996
18G xtr 10 cm
Mustang dyno results:
S# = 19.5 psi 323whp/338wtq (peak boost@3200 rpm-peak trq@3700rpm)
S = 17 psi 295whp/310wtq
Feels a bit more laggy than vf48 between 2000-3000 rpm (about 25 trq less at 2500 rpm according to both virtual dyno plots) in 4th gear and up. Above 3500 rpm the pull is just awesome and all the way up to redline (no drop in power like vf48).
3 first gears pull very good, so the lag is only felt a bit on the highway when at low rpm.
Sorry... Graph picture didn't come out clear enough.
Mods:
2010 STI
Blouch 18G XTR-10 cm turbo
COBB CAI with airbox
Perrin inlet 2,4"
Stock TMIC
Stock headers
COBB uppipe
Custom 3" downpipe with cat
Stock Catback
Grimmspeed 3 port ECBS
Deatschwerks 750cc injectors
Deatschwerks dw65c fuel pump
IAP fuel regulator kit v2
Forged pistons/rods
Sti_Dom is offline   Reply With Quote
Old 11-18-2013, 04:12 PM   #416
Maxwell Power
Member#: 190729
the lag is because you went with a 10cm on a small turbo like the 18G. The 10cm should be reserved for the DOM4 and higher.
Old 11-18-2013, 05:14 PM   #417
EMS
Member#: 14116
Thumbs up
Best post I've seen on Nasioc concerning 10cm turbine housing on smaller turbo's (besides my own posts from quite some time ago)!
EMS is offline   Reply With Quote
Old 11-18-2013, 08:03 PM   #418
BroBroBroBroBro
Member#: 338211
2011 wrx ewg
equal headers+frontmount
whats the ideal hotside 8cm? im also wondering about this turbo on a 2.5l
i think ive been told this is too small like most people say but within the limits of the stock motor it could make decent power?
BroBroBroBroBro is offline   Reply With Quote
Old 11-19-2013, 01:06 AM   #419
Maxwell Power
Member#: 190729
7cm2 is too small for a 2.5L.
8 is just right for most applications
10 is for car with higher power and higher boost.
The higher the boost, the larger the housing you want. You will be forced to accept slower spool as a result.
Many people call the turbine size the volume, but it isn't really the volume. Since when was volume measured in square cm? Volume would be cubic cm. So while 7cm2 and 8cm2 are not measurements of volume, the volume does go up with the cross section of the housing.
Anyway, the point is that with the smaller housings the available nozzle area goes down. this means more back pressure for a given flow rate. So if you're not pushing a high flow rate, you'll have low velocity at the nozzle, which means slow boost response.
I use 8 for most application under 400whp. From 400-500whp, it can be a toss up. Above that 10cm2 only makes sense.
What you use is really up to you and what you want. On a DOM 4 for example, a 10cm2 housing would probably net you 30-40whp (or more) vs an 8cm2. However, on an 18G you'd probably only get 10-15whp with the 10cm2 housing while still taking a big hit on spool.
Old 11-19-2013, 02:51 AM   #420
subbi7
Member#: 241967
02 wrx
Dom how big the atp stock location housings?
subbi7 is online now   Reply With Quote
Old 11-19-2013, 02:58 AM   #421
Maxwell Power
Member#: 190729
I honestly don't know. Not a huge fan of those turbos honestly. Fitment is always so marginal and the compressor housings just don't seem to flow well enough.
Old 11-19-2013, 07:13 AM   #422
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I think they're .73AR so close to 10cm.
My build is a perfect example of what Dom was suggesting. I used the 8cm on my Dom3.5 for the spool but probably should have gone with the 10 as I'm seeing higher back pressure up top than I would like. I'm going to change housings his winter.
Old 11-19-2013, 12:11 PM   #423
BroBroBroBroBro
Member#: 338211
2011 wrx ewg
i just learned something new, rare these days with forums full of trolls and kids.
Old 11-19-2013, 12:23 PM   #424
tekfoc
Member#: 21392
2014 45 AMG MB
very true .
every time Maxwell post something up I read it as if i'm reading a repair manual .
he knows what he is talking about
Old 11-19-2013, 04:32 PM   #425
FCmaniac
Member#: 142029
2013 Forester
2004 STi, 1991 Miata BRG
Thanks for your input... it's valuable and appreciated.
FCmaniac is offline   Reply With Quote
Dyno! DYNO! DYNO! (she's baaaack) Subaru Gwinnett South East Region Forum 46 12-13-2004 05:22 PM
New Dyno Day Thread... Dyno Day is 10AM on Sunday Bankheist Texas Impreza Club Forum -- TXIC 8 03-24-2002 04:15 PM
Who wants to do a SCIC dyno day on a real AWD dyno? p-car Southern California Impreza Club Forum -- SCIC 19 01-22-2002 01:22 AM
Dyno results posted from NW i-club Dyno Day! sponaugle Factory 2.0L Turbo Powertrain 26 06-04-2001 10:30 PM
Dyno Runs.. AWD car on a 2WD dyno... WTF Mike Moffa Technical Forum Archive 7 07-18-2000 08:31 PM
