Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-15-2012, 04:56 PM   #76
yeahdudebrown
Member#: 72345
Sold 05' CGM Wrx &
08' AW FXT :(
Originally Posted by V8 GTFO Lesbic WGN View Post
^ what's the 0-60 per APV2 now? 1/4?
I am not sure, never measured it and probably won't because I don't drag the car. This is my daily, don't need a broken transmission.
yeahdudebrown is offline   Reply With Quote
Old 02-15-2012, 09:33 PM   #77
djc1827
Member#: 238618
2011 WRX
11.82 stock 5sp/eng vf52
why would u buy an 18g if you don't even plan on beating on your car? Why would u even buy a wrx? 6 speeds are bulletproof, 09+ 5 speeds are almost bulletproof. I could see it if you had an old bug eye with 150k miles on it but damn...
I launched my 09 and my 11 at 5500 rpms with an ACT HD clutch, never skips a beat
djc1827 is offline   Reply With Quote
Old 02-15-2012, 10:37 PM   #78
2011boostdwrx
Member#: 263470
And im scared to beat my11 HTA68, go figure for every story i hear about i beat my car and no problems, I read one i babby my car beat it once and it broke???? I waited 8-months for my11 WRX, installed the upgraded turbo package and now wondering why i didnt buy an EVO. Im scared to drive the damn thing hard.
2011boostdwrx is offline   Reply With Quote
Old 02-16-2012, 09:05 AM   #79
yeahdudebrown
Member#: 72345
Sold 05' CGM Wrx &
08' AW FXT :(
Slow down buddy, just because I'm not going to drag the car, that doesn't mean I'm not going to be involved in other types of racing. I plan on road racing the car once or twice a year. And why would I want to beat the **** out of my only means of transportation? You can still have fun with an 18G without abusing it. I have faith the Forester transmission could hold up to a beating, but at the end of the day I drive a Forester, not a WRX. Not everyone has the same driving style.
Old 02-16-2012, 09:16 AM   #80
Badler
Member#: 133597
Dip****, we get it. You love your vf52. Shut the **** up and stay out of this guys thread.
Badler is offline   Reply With Quote
Old 02-16-2012, 09:28 AM   #81
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
My Fox is my DD, stock trans, 85K miles, there is nothing wrong with hooking up the APV2 and measure 0-60 and 1/4 mile. Just find a flat straight road, it is always useful to take before and after readings before an upgrade.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 02-16-2012, 09:35 AM   #82
GT35RHybrid
Member#: 223237
18g seems to show great results on dyno charts but nobody goes fast with em.
Learn to drive. My old 18g setup (my former s/n is CoolRex btw) ran 11.7 @ 122mph. Don't mind the 11.7 but the 122mph was nothing to sneeze at. And all of that was on a bone stock EJ205 engine.
GT35RHybrid is offline   Reply With Quote
Old 02-16-2012, 09:43 AM   #83
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Amen...
wrxlaunch is offline   Reply With Quote
Old 02-16-2012, 02:02 PM   #84
yeahdudebrown
Member#: 72345
Sold 05' CGM Wrx &
08' AW FXT :(
My 18G Forester vs. typical stock sti on the same dyno:
My 18G vs. My stage 2
I would be making a good amount more power with an aftermarket intake and catback.
Old 02-16-2012, 02:10 PM   #85
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Thanks for posting, your original plot was hard to read.
Old 02-16-2012, 03:01 PM   #86
yeahdudebrown
Member#: 72345
Sold 05' CGM Wrx &
08' AW FXT :(
Here's a thought...
You need to just buy the 18G-XTR and post in this thread to make fun of me when you make more power and spool faster
Old 02-16-2012, 03:18 PM   #87
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^that is exactly my intentions but you gave it away.
Old 02-16-2012, 04:41 PM   #88
bigpelo
Member#: 296532
2002 WRX EJ207 swap
Good numbers! I am still not decided if I go XT or XTR though... Neither if will go 8 or 10 cm. And Blouch did not reply to my PM, tweet nor e-mail
bigpelo is offline   Reply With Quote
Old 02-16-2012, 04:47 PM   #89
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Call M-TH, 8-12pm and ask for Mike.
Old 02-16-2012, 04:52 PM   #90
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
why would you go XT when XTR is now available, $150 differential is not an excuse when you are going to enjoy this turbo for several thousand miles with better spool and reliability due to ballbearing.
Old 02-16-2012, 04:58 PM   #91
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
agreed... cant stand that guy
FCmaniac is offline   Reply With Quote
Old 02-16-2012, 09:37 PM   #92
bigpelo
Member#: 296532
2002 WRX EJ207 swap
That was my minding before Yeahdudebrown raise the point about turbine housing size and spool up might be equal with XT and XTR. I might wait until you get the XTR tune
Old 02-16-2012, 10:03 PM   #93
Maxwell Power
Member#: 190729
If it spooled exactly the same, I'd still take the R over the other. There are many more things to turbocharger dynamics that just spool and power capacity.
The larger wheel means the opening in the housing is larger. This means less backpressure which means more reliable engine operation as well as the gain in turbocharger reliability.
Maxwell Power is offline   Reply With Quote
Old 02-17-2012, 06:54 AM   #94
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
I can't wait to see the thread when some names their turbo xx-RR lol
Old 02-17-2012, 08:02 AM   #95
bigpelo
Member#: 296532
2002 WRX EJ207 swap
So your suggestion would be 18G-XTR 10cm?
Old 02-17-2012, 01:06 PM   #96
Maxwell Power
Member#: 190729
turbine volume depends largely on your setup.
if you are on factory cams, I would not run a 10cm2 housing. I would run the 8cm2.
with the turbine housing you have to take into account the amount of flow it is going to see and then balance power, spool and backpressure to get the right one.
In general:
2L with factory cams: 7cm2 for faster spool, 8cm2 for more top end.
2L with large cams: 8cm2
2.5L with factory cams: 8cm2
2.5L with large aftermarket cams:10cm2
The displacement and the amount of overlap are a general base for how much turbine housing flow you need to sustain. However, if the max a turbo can produce isn't enough to outflow the 8cm2 housing, there isn't much point going to a 10cm2 housing. With that in mind, I would have to see maps for the compressor and turbine for the 18G, but I can't imagine a 10cm2 housing would ever be necessary on it. 10cm2 is a big housing and if you need that big of a housing, you should probably be on a bigger turbo in the first place.
Old 02-17-2012, 02:51 PM   #97
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
In general:
Information like this is exactly why people still have hope for Nasioc. That's the easiest to understand explination of that i have seen yet.
Good stuff...and agreed.
Squidz is online now   Reply With Quote
Old 02-17-2012, 02:56 PM   #98
bigpelo
Member#: 296532
2002 WRX EJ207 swap
In general:
Thank you so much! I can finally sleep and dream of my 18G-XTR 8cm^2. Can't hardly wait for my bonus and tax refund
Old 02-17-2012, 03:00 PM   #99
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
+1 for the great info Dom posted.
Bishop is offline   Reply With Quote
Old 02-17-2012, 03:54 PM   #100
FCmaniac
Member#: 142029
2013 Forester
A roaring round of applause for Dom/MPS... We're lucky to have guys like him still in here posting valuable info.
Dyno! DYNO! DYNO! (she's baaaack) Subaru Gwinnett South East Region Forum 46 12-13-2004 05:22 PM
New Dyno Day Thread... Dyno Day is 10AM on Sunday Bankheist Texas Impreza Club Forum -- TXIC 8 03-24-2002 04:15 PM
Who wants to do a SCIC dyno day on a real AWD dyno? p-car Southern California Impreza Club Forum -- SCIC 19 01-22-2002 01:22 AM
Dyno results posted from NW i-club Dyno Day! sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-04-2001 10:30 PM
Dyno Runs.. AWD car on a 2WD dyno... WTF Mike Moffa Technical Forum Archive 7 07-18-2000 08:31 PM
