Old 11-19-2011, 03:36 PM   #1
joeytomatoes
Member#: 161657
02 wrx
wrb
Default two front injectors shut off when warm?
sup guy need some help . i have a 02 wrx and it is having some injection issues,its has injector pulse when cold but when she runs warm the two front injectors shut off, but they have 12v at the plugs is there a ground i should be looking for? ive tried another ecu and its doing the same thing. please help this is killing me
joeytomatoes is offline   Reply With Quote
Old 12-07-2011, 06:39 PM   #2
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
Disconect the plug and plug in a Christmas light and see if it flash. The ecu controls the ground not the the +.
gaby is offline   Reply With Quote
Old 12-17-2011, 11:06 PM   #3
joeytomatoes
Member#: 161657
02 wrx
wrb
finally figured out what was wrong found the iac valve was stuck open causing the two front injectors to shut off.now i just need to figure out why when its boosting she seem to be sputtering?
Do the injectors shut off when coasting? java04rexracr Factory 2.0L Turbo Powertrain 1 05-24-2011 08:52 AM
ProSport Gauges shut off when lights are off? xADAMx Electrical & Lighting 9 12-05-2010 01:16 PM
Speakers shut off when car starts and amps on gsxrmoto1 Car Audio, Video & Security 5 11-29-2006 04:12 PM
Maddad lectronic guages shut off when lights turned on Honest Bob Electrical & Lighting 5 07-02-2006 12:15 AM
Why would a car shut off when you lift off the gas? linux>windows Off-Topic 28 03-08-2006 08:38 PM
Message Board Statistics All times are GMT -4. The time now is 05:59 AM.
