Old 11-20-2011, 05:11 PM   #1
cueball89
Member#: 90513
2003 wrx wagon
black
Default knocking/ pinging when cold?
It was about 30 degrees f this morning, I had audible pinging when driving. I thought it was just my ears playing tricks on me but later when the car was warm I plugged in my accessport and had learned value of -9 flkc. The dam was still at 16 somehow... These values zeroed out immediately once I held the specific load and rpm.
The drive was about half a mile in a 30mph then on to a 55mph road that had 1 hill and one mountain. I accelerated gently and shifted at 3000rpm.
Is this something mechanical or with my map? My map is an ots stage 2 from cobb with modified wgdc, turbo dynamics and intake temperature compensations tables to work with a 3 port boost controller.
cueball89 is offline   Reply With Quote
Old 11-21-2011, 09:41 AM   #2
Cobb Tuning
Member#: 4803
This is a 03 WRX? What are all your mods? Do you have any logs?
Bill
Old 11-21-2011, 09:56 AM   #3
cueball89
Member#: 90513
2003 wrx wagon
black
Bill
Yes, 03 wrx. Tbe, gutted up pipe, k&n panel filter and a GP Moto Intake Elbow. I don't have any logs when it happened.
My dad has also said he heard his car making similar noises on the same road when cold.
07 wrx vf39, tbe and k&n panel filter. 130kmiles and ringlands on #4 died.
Old 11-21-2011, 11:05 AM   #4
Cobb Tuning
Member#: 4803
When you start to see extreme corrections like that, it is either something rattling in the engine bay that the knock sensor is picking up (i.e. false knock) or you have a major mechanical issue. If it only does it when cold, it is more likely that it is false knock and you are hearing whatever is making the noise. Typical problem areas are loose turbo heatshield, factory uppipe with broken heatshield welds, and tranny dipstick touching turbo heatshield. But, it could be anything (esp. metallic) that is rattling.
Beyond that, I would try to get a data log of the knock, as long as you don't have to put the car under too much load to do it. Then we can go from there.
Bill
knocking when cold... (not pinging) POSBUTAWD Normally Aspirated Powertrain 11 01-05-2008 09:43 PM
Heavy knocking sound when motors cold nitrohuffer Legacy Forum 12 11-12-2003 10:37 AM
Knocking when cold normal? RoadRashed Service & Maintenance 12 03-02-2003 09:09 PM
UTEC engine knocking when cold WRXOwner7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-29-2002 08:10 PM
Engine knocking when cold fixed 7nth_Son Warranty Issues & SOA Problems 18 07-14-2002 09:36 PM
