Old 06-28-2012, 09:09 AM   #301
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Fully installed Stoptech system in all its glory ... Can not wait to feel the remarkable improvement on the street and track. I fell the wrx brake system was one of its weakest points, as it did not inspire confidence or predictability under aggressive driving. The stoptech system will provide large performance gains with proper brake bias, increased thermal capacity, better cooling, larger calipers and more brake torque, better pads and fluid, stiffer and larger caliper, etc. Very eager to bed in the brakes and test them out on the road and track.
Uploaded with ImageShack.us
soccer05 is offline   Reply With Quote
Old 06-28-2012, 09:12 AM   #302
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is a little teaser pic of part of the dash as the adhessive dries. I took the dash all apart and coated seprerately to ensure clean lines and a professional result. This is of the passenger side airbag, and I must say it loks quite stunning. I will post up pics of the dash tonight, I think this should be a mod many track cars should seriously consider.
Old 06-29-2012, 11:47 AM   #303
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Dash completely flocked and curing. The install of the product was very simple, most of the work is actually done while removing the dash and prepping. I built a mini booth out of some old boxes to help contain the product, as it does make a mess. I used a 3 inch rolled with a 2/8 inch nap to cover the majority of the dash with the adhessive, and used a brush to hit all the more technical areas. The adhessive gives a 10-15 minute working time, so I didn't stop to take pictures. After the entire dash was covered adequately and smoothly, I ran the roller over everything once more to ensure a fresh coat was everywhere and give me the maximum working time. I then used the applicators to flock the dash. The instructions said to use extra, as whatever doesn't adhere to the the dash can be reused, I think I definitely used extra, and had to rotate the dash to ensure complete and proper coverage of all areas receiving the flocking. After the dash cures the remaining flocking material simply falls off, and can be reused. I think it came out rather well
Old 06-29-2012, 11:48 AM   #304
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is a close up of what the driver will see. I ensured adequate coverage of the underside of the display for a professional looking product. This came out exactly as I had hoped.
Old 06-29-2012, 11:58 AM   #305
JordenP
Member#: 305041
2013 STOCK WRXSDN
That looks awesome for a non-professional job. Keep up the great work!
JordenP is offline   Reply With Quote
Old 07-09-2012, 01:53 PM   #306
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Thanks man, I was definitely apprehensive about doing the dash, as everything on my car has been done to a high quality, I didn't want the dash to come out anything short of professional. It definitely came out well, so well that a local friend doing a gc swap is doing it to his dash while it is out. Thanks for the support. When I get back from vacation I will reinstall the dash to show the complete end result, but definitely happy so far.
Old 07-09-2012, 02:23 PM   #307
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
How do you clean it?
BeBop86 is offline   Reply With Quote
Old 07-09-2012, 09:18 PM   #308
Mr. Me
Member#: 193598
2002 Bugeye Wagon
Vaccuum I assume? It shouldnt be an issue after the adhesive has dried. Obviously for a little while there will be some shedding but it should go away after a while.
I have thought about doing it for a while now but im not sure I wanna tackle it by myself and dont wanna pay to have it done
Mr. Me is offline   Reply With Quote
Old 07-10-2012, 01:39 PM   #309
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
There are a number of ways to clean the dash, but I believe the most effective is wih the vacuum. I have an extension with soft bristles I will be using. You're correct, once the adhesive is set and you clear off the excess you are good to go. I heard of a couple other ways to clean it but the vacuum seemed the most effective to me.
Don't pay to have this done, this is definitely attainable for the home enthusiast. If you can take off the dash you can do this modification. Take your time and prep the dash properly and have more flocking fibers than you think you will need because you want to ensure everything possible sticks to the adhesive and there isnt any thin spots. I was nervous as well because it would require a new dash if I messed up, and the end results are phenomenal, definitely met my expectations. The steps I showed in the thread is exactly how I did my dash, no surprises just prep, spread on adhesive and flock.
Old 07-12-2012, 02:54 PM   #310
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
I was planning to do a full how to install of the flocking and dash when I got back and remounted the dash, but judging from the interest I have received both locally as well as via pm's I want to let people know about the flocking. I purchased the flocking kit through donjer products (www.donjer.com). I just used the regular hand applicator but if you have access to an air compressor they have an applicator that uses the compressed air. I was definitely apprehensive about prepping and flocking my dash, as once you start prepping there is no going back, and if I messed up I would be forced to purchase a new dash ... Not the direction I wanted my money to go. Judging from the responses of those that have seen the final result, it came out amazingly well, and exceeded my expectations. The customer service was top notch, I called up donjer and they spent twenty minutes on the phone answering my every question and coming up with a package to meet my needs. The flocking materials shipped out that day and donjer emailed me links to various how to articles for pictures of the process. Definitely the customer service and expertise that makes the modification process enjoyable. Of course, that all means nothing if the product is inferior, or goes on unevenly, but judging from my results and pictures this was clearly not the case.
I was very apprehensive about this part as I had never done flocking before, and my standards for parts and quality is enormously high, and I am glad to tell those that have emailed me that the product and company met my expectations.
The best way for me to describe this product and results is what I have been telling local friends and those who requested by pm, if you have the dash off the car I see absolutely no reason not to do this modification. Low purchase price, good quality of product, excellent technical support, ease of application with a fantastic end result, what more can you want. Plus the lack of glare off the dash will ease hardcore driving and let you focus on the road, plus it looks amazing (in my opinion) and hardcore/functional as hell.
A detailed write up will come when I return from vacation, I will throw the link up on my build thread for those interested.
Old 08-07-2012, 12:38 PM   #311
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Sorry about the delays, I know it has been a while since I posted updates to this project on this forum. I have been working a ton of overtime (have to work it when you can get it) to help pay for fun stuff, as well as moving into a house, it took me a while to find where the computer was
packed. Here are some updates of the progress.
Dashboard ducting reinstalled after flocking. I removed all the ducting as the flocking powder is very fine and I didn't want to deal with any getting into the vents and ducts. Aslo by removing the ducts and associated trim panels, I am assured a professional looking end product with crisp lines.
Old 08-07-2012, 12:57 PM   #312
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
These are the clean lines that I am referring to. By removing all the trim panels you are able to get complete coverage and crisp lines which gives a clean professional appearance. As the dash is a highly visible item, and you will be staring at it every time you get behind the wheel, I highly recommend you take the time to prep properly.
Old 08-07-2012, 01:01 PM   #313
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Flocked dash reinstalled..
Old 08-07-2012, 01:05 PM   #314
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
View of reinstalled dash from other side. Very happy with the end result. Was disappointed, during initial curing one little .5 inch scrape left a bare spot right on top of the gauge cluster right in front of my face, but I reapplied adhessive with a q tip and reapplied adhessive, and was able to achieve a very good blend job. I am really impressed with the quality of the end product, should really set off the interior as well as prove highly functional, all for $50.
Old 08-07-2012, 01:39 PM   #315
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
I'm impressed
MOBBiN is offline   Reply With Quote
Old 08-07-2012, 04:55 PM   #316
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Originally Posted by MOBBiN View Post
I'm impressed
Thanks glad you like it. Should be a fun little street car when I'm finished with it.
Old 08-07-2012, 05:06 PM   #317
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Minor update, I am really behind on this build thread since I couldn't find thre computer. Just did an initial fire up to remove all air bubbles from the coolant today, and the little blue subie sounds downright mean. Perrin headers, APS up pipe, OEM TD-04 turbo, APS 3 inch down pipe, and APS 3 inch cat back exhaust sound downright vicious at idle, not near race car volume levels but definitely an aggressive street car idle. Even though I am running Perrin equal length headers, I was very impressed with the sound at idle. As per Cobb's recommendations, I am using their OTS Stage 2 91 octane map for initial start up and break in. Obviously, this is not a perfect match for my modifications as I am running the equal length headers, but they felt it was perfectly safe as long as I didn't go out and beat on the car. As this is just break in, I think this will be safe for break in. Can't wait to hear what this parts combination will sound like at redline ... and what this car will sound like with a gtx 3071 and a plumbed into my exhaust. Really excited to start the car up for the first time in 8 months ... great feeling, only had to chase a couple little gremlins preventing startup (forgot 2 connectors when reinstalling dash and 1 clip to the starter solenoid).
Minor hiccup though, I do have a serious oil leak that I will be diagnosing today. Overall though, for a project of this magnitude it was a very painless startup, just got to back to the garage and diagnose this oil leak, then its off to get the bodywork done so I can have complete suspension travel with my 275 series tires on my 18x9.5 inch rims.... Then off to GST Motorsports to get the final turbo installed, fuel system installed, tune, and drive it.
Old 08-07-2012, 06:55 PM   #318
Jellynuts
Member#: 305774
2007 STi
CGM
Oh man! Getting close!
Jellynuts is offline   Reply With Quote
Old 08-08-2012, 09:23 AM   #319
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
You're telling me .... It's been way too long since I've driven my subie. Oil leak has been diagnosed and fixed, hoping to get over to the garage tonight after work and reinstall all the parts that were taken off to diagnose and repair the problem. Very tentative startup date is tomorrow to bleed the coolant, then set up an appointment at the race shop for fender rolling, alignment, and corner balance, then off on the road for some break in miles. Very excited, can finally see the light at the end of the tunnel, it's been a long journey but looking forward to enjoying the car from track days to my daily commute. Updates to come, let's see if anything on this car can stick to a schedule.
Old 08-09-2012, 12:46 PM   #320
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Center console and electronics being reinstalled. Starting to make the interior feel like a car again. Progress is coming along nicely.
Old 08-09-2012, 12:50 PM   #321
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Passenger air bag and glove box reinstalled. I had no idea how much the air bags weigh, what an easy place to cut off approximately 20 pounds for a track car. This is a street car though, so some concessions ahd to come into play, and the air bag stay for passenger safety. Take note of the quality of the end product on the dash, clean crisp lines throughout, easy to clean with a vacuum, etc. I am very happy with the end product, in a market where so many products can fall short on quality or finish, I love it when products meet my high expectations.
Old 08-09-2012, 12:51 PM   #322
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
View of the interior nearing completion. Still need to flock my clock pod in the center of the dash as it had a small crack from removal (just brittle from the sun). So I need to put a light coat of bondo over the crack, sand flush, then flock. Shouldn't take long, but I am putting it off until I can get the car running (getting close).
Old 08-09-2012, 12:55 PM   #323
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Just noticed the last pic had some trim pieces missing on the drivers side. This is how the complete interior looks now, still missing the clock pod as described above. I am tired of covering pics of the interior, let's get back to the good stuff under the hood.
Old 08-10-2012, 12:46 AM   #324
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Originally Posted by CobbWRX View Post
is the flocking a soft feel or how does it feel? i am thinking about doing all of the plastic thats not black in my wrx now!
It is hard to explain how it feels, the flocking fibers are super fine, almost like a dust. It is soft to the touch, but not like a piece of fabric or anything. It's hard to say off the pictures, but it feels just like it looks. It is a soft layer of fibers glued to the dash, that is probably the best explanation.
Old 08-10-2012, 01:04 AM   #325
roof_rack
Member#: 257866
such a proper car, refreshing to see something along these lines instead of 215's on a 10 inch wheel and no power. racecars ftw!
roof_rack is offline   Reply With Quote
It's about damn time: Smurftastic's Bugeye Build Thread Smurftastic Member's Car Gallery 262 05-30-2016 09:08 AM
My GT3076R Bugeye Build... CKxx Member's Car Gallery 166 08-24-2010 02:24 AM
WI Bugeye build thread/my first 'motor build' CrashTest Mid West Subaru Owners Club Forum -- MWSOC 1 05-11-2010 11:00 PM
MY20G Bugeye Build Thread white02_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-04-2010 08:02 PM
bugeye build.. Pike Alaskan Impreza Club Forum -- AKIC 55 04-03-2009 06:07 PM
