Old 11-03-2012, 12:49 AM   #426
fuelMuncher
Member#: 301554
2002 WRX Wagon
Good thread - subscribed.
fuelMuncher is offline   Reply With Quote
Old 11-03-2012, 11:17 AM   #427
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Originally Posted by GuamKid View Post
Hope the cars coming along well!
This is like waiting for the last episode to your favorite show..
Thanks, the car is coming along, mainly just waiting for the body shop to finish moving into their new facility. Good news, they finish this weekend and I will be dropping off the wrx on Tuesday. Just been finishing a few minor projects, arp wheel studs, wheeladapter.com 10 mm hubcentric spacers, and cusco front subframe brace. Just waiting to send it off for some cutting, welding, and painting by the pros.
soccer05 is offline   Reply With Quote
Old 11-04-2012, 09:27 AM   #428
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Originally Posted by mitchbugeyerex143 View Post
did a great job document the process and looks very well put together, now post moar PICS! sub'd
Glad you're liking it, progress should go a lot quicker once it goes in to the body shop on Tuesday.
Old 11-07-2012, 12:55 PM   #429
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Finally some serious progress. The bodyshop finished moving into their new upgraded facility. Better spray booth, much larger work/mock up/fabrication area, etc. Just dropped the car off yesterday afternoon. I am very excited, as this is a top notch body shop that has done numerous work featured in numerous magazines. It is refreshing, after all the struggles and search finding a shop, to have a shop recommended that knew exactly how to do what I wanted and didn't make any excuses. Should be about a week and a half to two weeks for the car to be done. Front bumper will be mounted with a quick release setup, hood louvers mounted and hood sprayed, side skirts sprayed, fender flares installed and cut for maximum clearance, with rear bumper trimmed for maximum tire clearance. Very excited, once this is done the car will be taken to gst to get its final tune and then enjoyed and driven hard.
Old 11-07-2012, 02:51 PM   #430
bruiser63
Member#: 109366
06 STI
Can't wait to see this thing done!
bruiser63 is offline   Reply With Quote
Old 11-08-2012, 02:25 PM   #431
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is a picture of my hubadapter.com wheel spacers. Very impressed with the quality of these parts, even though they are simple hub spacers. I have seen some less than excellent wheel spacers on the market, and am very unhappy with their use as it is a safety related part for you and others that share the road with you. I provided my measurements of my inner bore for my rota rims, and the stock wrx hub, and they machined all four wheel spacers to fit perfectly and be hubcentric. All parts fit perfectly, and the 10mm spacer widens my track width just a little under a half inch per corner. With my 15mm of scrub without the spacers, the spacers increase my scrub to 25mm, or about 1 inch of scrub per corner, still way under my 2 inch limit I was originally shooting for. I haven't done it yet, but I have the option to elongate the lower strut mounting bolt hole to increase negative camber. As I increase the negative camber at the lower bolt hole, I can lessen the amount of negative camber used at the camber plate, this will move the line out through the strut top and lower ball joint, and lessen the KPA that I currently have. The downside to this will be that it will increasethe scrub a little bit, and will only be done if I decide I need additional negative camber gain and less self centering steering (caster increases negative camber, KPA increases self steering characteristics/on center steering feel).
Uploaded with ImageShack.us
Old 11-08-2012, 02:27 PM   #432
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is the hubcentric part of the spacer, machined to fit perfectly inside my Rota rims center bore.
Old 11-08-2012, 02:29 PM   #433
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Wheel spacer mounted on the rear of the car.
Old 11-15-2012, 02:13 PM   #434
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Hood louvers installed at body shop. Don't worry they will not be staying brushed aluminum, but the whole hood will be resprayed wrb along with the fender flares.
Old 11-21-2012, 12:16 PM   #435
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is a pic illustrating the track width difference with the 10mm wheel spacers. Part of the reason for utilizing the spacers was I was getting a slight amount of rubbing in the front under compression and turning (slightly rubbing in the front inboard on the fender well right under where the oem airbox installs). Obviously, any rubbing is unacceptable, I am hoping this will be a cheap solution to the problem while I save to have the front wheel wells tubbed. Tubbing the front is the better solution, as you can substantially increase clearance both inboard and under compression, and while it would have been relatively simple to do prior, it is not in the budget at this time. I will be incorporating this into the budget at the earlliest opportunity, but I need to get this car back on the road. The increase in track width makes the fenders look back to like they were prior to pulling the fenders. Substantial increase in track width, keeps the scrub radius within reason, and will reduce rubbing under compression in the front, and help fill out those fender flares. The car is currently at the body shop getting cut up and painted, but upon return I will be removing the front springs and jacking the car through its suspension travel to ensure there is no rubbing of the tire under any conditions. There are other band aids that can be done right now instead of tubbing, caster can be adjusted, etc.
Old 11-21-2012, 12:18 PM   #436
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
View from the back shows a substantial increase in track width. As has been the theme with this build, I am doing everything possible within my budget to increase mechanical grip while keeping the proper suspension geometry, steering feel, and travel.
Old 11-21-2012, 12:21 PM   #437
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Comparison to the track width and fitment without the spacers.
Old 11-21-2012, 12:22 PM   #438
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Birds eye view without spacers installed
Old 11-26-2012, 03:03 PM   #439
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is the update from the body shop. Fender flares test fitted and look excellent on the car. Looking forward to getting full compression travel and wheel lock with some serious rubber. Getting excited....
Old 11-26-2012, 03:08 PM   #440
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Here is how the front of the car will look. Hopefully I won't have any more rubbing in the front with the spacers. Some minor clearancing might be required, but we will see when the car is back in my hands. Fronts look as good as the rear. Loving the progress.
Old 11-27-2012, 11:36 AM   #441
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Some more progress at the body shop.
Old 11-27-2012, 11:38 AM   #442
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
And another shot. Just gotta keep moving forward...
Old 11-27-2012, 02:03 PM   #443
JD06WRX
Member#: 200534
2006 WRX TR
That is gonna look so sexy.
JD06WRX is offline   Reply With Quote
Old 11-28-2012, 01:50 PM   #444
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Some more pics as the bodywork progresses. Bodywork is absolutely foreign to me, so I am pretty interested in how this progresses. The rears are the most involved in fitting, as it involves cutting the rear fenders and sealing multiple layers of metal. It is very involved to properly fit wide rubber on the rear of subaru's.
Old 11-28-2012, 01:56 PM   #445
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Pic of how the rear fenders match up to the oem bodywork. Very involved to make everything look both functional and proper. Fortunately, the flares from karlton are extremely well made (my bodyshop was literally blown away by them), making the amount of modifying for proper fitment very minimal as each car has minor differences to ensure proper match up.
Old 11-28-2012, 01:58 PM   #446
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Picture of cutting to the inner fender well for maximum compression travel. The panels will be all sealed together to prevent corrossion and ensure maximum chassis rigidity.
Old 11-28-2012, 01:59 PM   #447
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
If you ask me, its starting to look pretty mean....
Old 11-28-2012, 02:01 PM   #448
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
As you can tell, I'm pretty happy at how the bodywork is progressing.
Old 11-28-2012, 02:02 PM   #449
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
A lil pic showing off her backside..
Old 11-28-2012, 02:03 PM   #450
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Some more pictures of the rear.
It's about damn time: Smurftastic's Bugeye Build Thread Smurftastic Member's Car Gallery 255 04-12-2016 04:36 PM
My GT3076R Bugeye Build... CKxx Member's Car Gallery 166 08-24-2010 02:24 AM
WI Bugeye build thread/my first 'motor build' CrashTest Mid West Subaru Owners Club Forum -- MWSOC 1 05-11-2010 11:00 PM
MY20G Bugeye Build Thread white02_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-04-2010 08:02 PM
bugeye build.. Pike Alaskan Impreza Club Forum -- AKIC 55 04-03-2009 06:07 PM
