| View Poll Results: Top Scoob 026 ... TARMAC Final Round !! | |||
| Turn in Concepts |
220 | 37.23% |
| bhhamblin |
195 | 32.99% |
| LIC Motorsports |
176 | 29.78% |
| Voters: 591. You may not vote on this poll | |||
#1 | |
"Tekeli-li! Tekeli-li!"
Moderator Member#: 14145
NWIC
Vehicle:'02 WRX Cars? Stupid! |
![]() Top Scoob is looking for the ultimate Tarmac Race Car. To be eligible for this round your car must be a Proper Race Car. Time attack, Touring Cars, and Grand Touring GT cars only please. Drivers or Teams can enter their respective machines. If you have a question about the eligibility of your car please just ask me! Racing is tough business. I remember a hardcore bracket racer once telling me that a great season for him was breaking even. Most racers I'm sure have heard a variation of the joke about how to make a small fortune in motor racing...by starting with a large one. With that in mind I'm allowing a two year bubble for cars that still have some fight left in them but are currently in recovery. ![]() Quote:
So if you think your car has what it takes enter right here and good luck! ![]()
#2 |
n00b Moderator
Moderator Member#: 99397
RMIC
Vehicle:'13 BRZ, '13 STi SRs13 '83 Skyline '93 GTR |
Alright, I purchased my 2006 WRX in August of 2006 with thoughts of it being my daily driver. I wanted an STi but it just wasn't feasible at the time. From day one I had started modding the car, first started with the normal exhaust and intake which had been swapped over from my previously modified 2005 4EAT WRX. So here it is today. Trailer queen non streetable track car. I've put every time into making this car where I want it and I am not sure if it will ever get there haha.
After a couple turbo upgrades: 18g, Dominator 3 and lots of beating the living hell out of it the stock engine finally got tired and fell asleep as well as a couple stock 5spds. This is when the larger modifications started to come into play. A Cosworth longblock was purchased along with the APS TSR70 turbo kit and other needed bolt ons. I was power hungry, but who isn't. After I did all this I started getting sick of the car and sold it to a local friend. Then bought it back because of regret aaand then sold it again and bought it back. After a few months of giving the guy I sold it to hell. I finally decided I would keep the car seeing how I owned it there was really no good reason to sell it. After a couple more years I had the car featured in Modified magazine, not only a feature but cover and a cheesy one at that. Not sure how it made cover but I couldnt be happier ![]() After purchasing my 2008 STi dumping some money into it then making my WRX into a full time race car it was finally time to call it quits as a super fast, caged, fun street car. I'm not too good at telling stories about it but here is my 2006 WRX. The car is raced in a local series here at Miller Motorsports Park called Lap Battle. I am still learning the car as I have built it beyond my ability to drive it, it scares me but it's still really fun and has been decently reliable and does well at the race track I'm not too good at telling stories about it but here is my 2006 WRX. ![]() ![]() ![]() ![]() [IMG] ![]() Here is a list of the few current modifications. Engine/Power Cosworth EJ25 long block Cosworth Pistons, rods, bearings w/ factory crankshaft Cosworth cams, valves, dual valve springs, cnc heads APS TSR70 turbo kit (Twinscroll T3 GT35R) APS Twin scroll exhaust manifold equal length APS 80mm intake APS DR525 fmic APS fuel rail APS TGVs APS 3.5 inch exhaust Tial 44mm external waste gate Forge BPV Deatschwerks 1150cc injectors Aeromotive FPR Sard fuel collector tank w/ dual walbro pumps and Earls hardware Denso 280lph pump in tank Crawford air oil separator STi intake manifold Moroso aluminum oil pan/ pickup Koyo aluminum radiator w/ ducting Setrab oil cooler w/ Mocal thermostat adapter plate Deral power steering cooler w/ Earls lines and fittings Cobb Tuning lightweight crank pulley Power 517whp 475tq 27psi 100oct. Tuned by Harvey (The Boost Creep) In Longmont, CO. w/ Cobb AP Transmission/ drivetrain PPG 5spd straight cut gear set 1-4 PPG billet shift forks Cusco 1 way front LSD Cusco 1.5 way rear LSD Carbonetic twin place clutch Cusco engine/ trans mounts Kartboy short shifter w/ 3 inch extension Beatrush propellor shaft mounts Suspension/Chassis Tein Super racing coil overs STI trailing arms w/ spherical bearing Hotchkis lateral links Whiteline sway bars Cusco rear crossmember brace Kartboy lockdown bolts Numerous suspension bushings: steering rack, rear diff, rear diff crossmember, etc LIC motorsports modified front knuckles for roll center/ 5x114 bearings Autopower super race weld in roll cage w/ custom gusseting and added support bars GT spec 14pt subframe brace Custom frame rail brake ducts 100% gutted doors/ interior AC deleted Charcoal canister/ lines and sensors in engine all gone Oswald performance lightweight rear bumper beam Wheels/ Brakes CCW Classic 18x9.5 +35 Hoosier R6 275-35-18 Stoptech 332mm front brake kit w/ piece rotors OEM STi gold Brembo rear calipers and DBA conversion rotors Hawk DTC70 front brake pads and DTC60 rear Stoptech SS front lines Technafit SS rear lines Cusco master cylinder brace Interior Sparco Pro2000 seats Sparco Prodrive steering wheel Splash short hub w/ NRG slim quick release Beatrush divider plate w/ custom top section Defi gauges: oil temp, oil press, water temp, EGT, boost pressure Innovate wideband Apexi AVCR boost controller Apexi turbo timer Lexan back windows Exterior/ Aero Chargespeed carbon trunk Kaminari carbon hood modified for more cooling Kognition 68 inch chassis mounted spoiler Custom front splitter/ canards ARC winglets Nukabe tow hooks Voltex rear diffuser Thats most of the large modifications. There is lots more. Thanks for looking! Last edited by bhhamblin; 12-03-2011 at 10:20 AM. |
#3 |
Member#: 54890
BAIC
![]() ![]() Background Story: We are two brothers (Adam and Noah) who have hand built this car from the ground up without any financial influences from "sponsors", "trust funds", or "private capital investment from any sources". We have only used our hard earned money via our customer's gracious support of our business; which in turn has let us follow our dreams and constantly strive to do bigger and better things in this Subaru. Year: 2004 Make: Subaru Model: STi Boost: 25 psi - 33 psi Fuel: E85 Power Output: 550+ (Varies per dyno) Powertrain & Tuning -LIC Motorsports 2.5L Sleeved Short Block (Billet Crank, Billet Rods, Forged Pistons, Race Bearings) -LIC Motorsports TA Heads (Cosworth Cams, +1mm Valves, Spring Kit, P&P Castings) -LIC Motorsports IC Piping (Custom) -LIC Motorsports Adj. Timing Idlers (Custom) -LIC Motorsports T3 EWG Up-Pipe (Custom) -LIC Motorsports TGV Deletes (Custom) -LIC Motorsports CAI (Custom) -LIC Motorsports Radiator/Oil Cooler Combo v2 (Custom) -Cosworth Intake Manifold -Cosworth Head Gaskets -Cosworth Oil Pump -Cosworth Head Studs -Cosworth Timing Belt -Cosworth Timing Belt Guide -Tomei EL Headers -High Pressure Coolant Expansion Tank (Custom) -Garrett GTX35R Turbo (T3) -TiAL 44mm MVR EWG -Perrin FMIC (Modified) -Injector Dynamic 2,000cc -Moroso Aluminum Oil Pan + Pick Up -Fuel Safe 12 Gallon Fuel Cell -Turbo XS Surge Tank -Dual Bosch Motorsport 044 Pumps -Walbro In-Tank Fuel Pump -Aeromotive Fuel Rails + FPR -WORLD Racing TBC-1 Boost Controller -Cobb AP v2 with Speed Density (Tuned by Tim Bailey Cobb Tuning Surgeline) -USDM 6spd -Cusco 1.5way Rear LSD -Cusco Motor Mounts -Group-N Tranny Mount -ACT Extreme sprung 6 puck Clutch -ACT Streetlite Flywheel -Kartboy Short Shifter + SS Bushings -Beatrush Pitch Stop Suspension Tuning -LIC Motorsports Front/Rear Geometry Corrected Knuckles (Custom) -LIC Motorsports Front Control Arms (Custom) -Triple Adjustable JRZ (Custom) -Cusco Front/Rear Camber Plates -Cusco Adjustable Trailing Arms -Cusco Adjustable Lateral Links -Cusco H-Brace -Eibach or Swift Springs (rates confidential) -MSI Rear Subframe -Converted to 5x114.3 -COBB 25mm Front/Rear Swaybars -Whiteline Spherical Adj. Front/Rear Endlinks -Whiteline Steering Rack Bushings -Whiteline Rear Diff Bushings -STi Spec-C Titanium Strut Brace Wheels & Brakes -Brembo 6 Piston 350x34 Big Brake Kit (Custom) -Hawk DTC70 Front/Rear Pads -Girodisc Rear Rotors -ABS Removed -Tilton Proportioning Valve -STi SS Brake Lines -2002 Model Year Clutch Slave Cylinder -Cusco Master Cylinder Brace -STi SS Clutch Line -Rota T2R 18x9.5 e38 5x100/114.3 -Nitto NT01 275/35/18 Interior/Exterior/Misc. -LIC Motorsports Front Splitter (Custom) -LIC Motorsports Dry Carbon Fender Flares (Custom) -LIC Motorsports Dry Carbon Trunk (Custom) -LIC Motorsports Dry Carbon Front/Rear Doors (Custom) -LIC Motorsports Dry Carbon Roof (Custom) -LIC Motorsports Center Control Panel (Custom) -LIC Motorsports Livery -AIM MXL Pista Dash Display -Sparco 330mm Steering Wheel -Sparco EVO Seat -Custom Tig Welded Cage w/ driver NASCAR Bar -Sparco Competition Racing Harness -Seibon Carbon Fiber Hood -G-Stream Wing (67”) -Safecraft 10lbs Fire Suppression System (3 Nozzle) -WRX Side Skirts -STi Pedal Set (Gold) -Prova Shift Knob -Braille Lightweight Race Battery Racing Results over the years 2008 Season Standings 3rd Place - Redline Time Attack Street AWD (Buttonwillow, CA) 4th Place - Modified Magazine 2008 Tuner Shootout Unlimted AWD (Chandler, AZ) 2009 Season Standings 2nd Place - Super Lap Battle Qualifier Limited AWD(Fontana, CA) 3rd Place - Redline Time Attack Limited AWD (Pahrump, NV) 1st Place - Subiefest 2009 Unlimited AWD (Willow Springs, CA) 4th Place - Super Lap Battle 2009 Limited AWD (Buttonwillow, CA) 4th Place - Redline Time Attack Finals Limited AWD (Fontana, CA) 2010 Season Standings 2nd Place - Redline Time Attack Limited AWD (Buttonwillow Raceway, CA) 4th Place - Redline Time Attack Limited AWD (Las Vegas Motor Speedway, NV) 2nd Place - Redline Time Attack Limited AWD (Auto Club Speedway, CA) 4th Place - Redline Time Attack Limited AWD (Willow Springs International Raceway, CA) 3rd Place - Redline Time Attack Limited AWD (Spring Mountain, NV) 3rd Place - Redline Time Attack Limited AWD (Infineon Raceway, CA) 3rd Place - Redline Time Attack Limited AWD (Auto Club Speedway, CA) 2nd Place in Season Championship Points! 2011 Season Standings 2nd Place - NASA TTR Unlimited (Willow Springs International Raceway, CA - Saturday Race) 1st Place - NASA TTR Unlimited (Willow Springs International Raceway, CA - Sunday Race) 2nd Place - GTA Limited AWD (Willow Springs International Raceway, CA) 1st Place - GTA Limited AWD (Infineon Raceway, CA ) *Class Record* Video from a few weeks back at GTA Finals *I'm sure I forgot plenty of stuff but this is all that comes to mind at the top of my head. -Noah Last edited by LICmotorsports; 12-15-2011 at 01:49 AM. |
#4 |
NWIC
Well I think we've made the masses wait long enough to start voting!
12 proper race cars, okay, 11 and one 1 crazy Canadian, covering everything from club racing to hill climbs, GC to GR, almost sane to completely mental. Turn in Concepts and mpj_becks (GST Motorsports) still need to flush out their entries please ![]() Also since we're not at our usual 25 cars we're going to do only two rounds, the first to pick the Top Three, then the Top Scoob Finals as always. I'll open the polls at 1:00pm PST today ![]() Thanks to all our entrants and Good Luck! |
#5 |
NWIC
the poll is up for round one! 8 days to make the Top Three and move on! Good luck!
#6 |
Member#: 241492
NESIC
Vehicle:2006 Forester, RBP Tuned by M@ at WI! |
gotta give it to okiedude! best story IMO!
#7 |
Member#: 36154
Vehicle:2004 WRX Wagon White |
No GST?
#8 |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
toss up between okie and bikn. went okie.
#9 |
Member#: 289456
Vehicle:1993 240sx Coupe Concord Blue Effect |
Licftw!
#10 |
Member#: 36116
BAIC
Vehicle:2003 STi sedan Aspen White |
Waiting for GST!
#11 |
Member#: 43538
Vehicle:2006 impreza |
isnt mbj_becks GST??
#12 |
Member#: 232354
Damn! I need my 25 posts to vote for Yanos
#13 |
Member#: 268310
Vehicle:2011 SSM STI saloon Church! |
Voted for the underdog Leggie. Love that second pic!
#14 |
Member#: 127044
TXIC
Vehicle:2005 STi WRB w RPF1s DTC60s+BrakeDucts |
holy ****, so many great entries!
#15 |
NWIC
#16 |
Member#: 165578
Go TiC!
#17 |
Member#: 165578
Doh! Need 25 posts to vote!
Oh wait.... ![]() |
#18 |
Member#: 89233
South East
Vehicle:99 RS Aspen White 08 Outback SWP |
Had to vote for Tony and Clint. TIC!
#19 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Thanks Swede! You da best!
Tony |
#20 |
NWIC
Now that the voting has begun you guys are all free to start posting all the pictures you want!
#21 |
Member#: 127740
Vehicle:2006 FXT-Mine 2007 FXTi-Her's |
Go Clint and Tony B. And Tony W.
#22 |
Member#: 85932
Vehicle:2005 STi / 2013 STi 2005 Forester XTi |
Needs more pics!
Voted! ![]() Last edited by SplatWRX; 12-14-2011 at 10:37 PM. |
#23 |
Member#: 37736
Vehicle:2003 WRX Race Wagon Silver |
#24 |
Member#: 170010
SWIC
Vehicle:03 Mazdaspeed Titanium Gray |
go Dr Koby D!
#25 |
Member#: 168774
SWIC
| Thread Tools | |
| Display Modes | |
| Vote in Top Scoob 026 RACE CARS ONLY! DIRT !! | Ferg | Member's Car Gallery | 47 | 12-30-2011 09:52 PM |
| Top Scoob 026 - Tarmac & Dirt Edition! | Dena | North West Impreza Club Forum -- NWIC | 25 | 12-26-2011 07:48 PM |
| GC Love!!! Vote Vote Vote! - Top Scoob Round 2! | Subie Gal | North West Impreza Club Forum -- NWIC | 51 | 04-06-2009 08:22 PM |
| Come vote in Top Scoob | Kraziken | Legacy Forum | 36 | 05-16-2008 01:06 AM |
