Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 08-08-2002, 08:47 PM   #1
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Question Anyone recommend an alignment shop in southern CT?
Need to get my new Kuhmo's mounted, balanced and an alignment, hopefully without getting scratched rims, or a car that wants to pull off the road.
Any recommendations?
Thanks,
Paul
Snowphun is offline   Reply With Quote
Old 08-08-2002, 09:35 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It doesn't sound very sexy, but I just use my local Sears. I've trusted them with my 17" UK WRX wheels a few times, in addition to my Volk TE-37s. They showed me their equipment when I said I was worried about the Volks - good, modern mounting equipment, everything that touches the wheels is hard plastic, no metal-to-metal contact at all.
As for alignments, they've been willing to dial in whatever I ask them to. No warranty on my "special" alignments, but I don't really care about that.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-08-2002, 10:14 PM   #3
Joe Hogan
Member#: 699
2002 golf TDI
If you want to specify the settings on the alignment and want an excellent job call Modzeliski's Tire in Danbury on Federal Road. As for John or Ronnie. Say hi for me..
Joe Hogan
Joe Hogan is offline   Reply With Quote
Old 08-09-2002, 01:40 PM   #4
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Hey Paul,
I just got some kuhmo's mounted and balanced yesterday at New England Tire and Brake, across from Tommy-K's, they did a good job, it was $50. They have a nice looking alignment machine too. Before the tires they swapped out my rear lower control arms for me to. The owner (Jim) is a nice guy. You should check them out.
96Lconversion is offline   Reply With Quote
Old 08-09-2002, 01:50 PM   #5
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Paul, you don't want to join my club?
The other Paul <---installing rear camber bolts tonight, alignment maybe next week (again)..
paultg is offline   Reply With Quote
Old 08-09-2002, 03:39 PM   #6
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Paul, your problems are what motivated me to ask!
And I'll check out New England Tire and Brake on the way home tonight; that'd be great to find a local place.
Thanks.
Old 08-09-2002, 03:42 PM   #7
paultg
Member#: 437
'91 Miata MX5 (Red)
Paul,
If you don't mind, can you send me the spec they use on your car once it's done, and let me know if you car goes straight!
I'd appreciate it. Can't wait for Ice racing again. You going to have snow tires by then?
Paul G. <--selling his snow tires
Old 08-09-2002, 05:20 PM   #8
paultg
Member#: 437
'91 Miata MX5 (Red)
Paul,
I posted the specs and results from the last two alignments I had done:
http://forums.nasioc.com/forums/show...hreadid=227772
Just an FYI so you can compare/watch out..
Paul G.
Old 08-09-2002, 05:35 PM   #9
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Yep, I'm excited to get back out there, and am already adjusting my winter plans so I can make most/all of the events. I imagine I'll stick with re92's on the stock wheels for the winter. I have a problem driving 400+ highway miles each weekend on nice snows...
Paul
Old 08-09-2002, 07:05 PM   #10
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Paul,
I'm hoping to go with mostly stock specs:
f:
camber: -25' (or a bit more)
toe: ~0mm
r:
camber (w/ crash bolts): -1* (or a bit more)
toe: -1mm
According to the manual. those are about middle of the tolerances. Surprised that rear camber is anywhere from -.75* to -1.75*. Probably due to the fact that it's not adjustable from the factory.
The place in Oxford agreed to do it all tomorrow morning for $115 (mount, balance and align), and were OK with using my specs and recording them.
Paul
Old 08-10-2002, 12:08 AM   #11
paultg
Member#: 437
'91 Miata MX5 (Red)
Well good luck. Here is another nice set of settings if you interested:
Ravensblade Impreza Alignment Spec Page
They don't list anything for "castor" though. Does your shop manual say anything about the recommend settings for that?
Paul G.
Old 08-10-2002, 12:21 AM   #12
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Caster: 3*35' +/- 45'
Same for both the sedan and wagon. Not as worried about that one.
Thanks for the link, I like seeing other sources that go with no toe.
Old 08-10-2002, 12:25 AM   #13
paultg
Member#: 437
'91 Miata MX5 (Red)
Great. Now for the Noob questions, how do you read those numbers? The printouts I have list caster in degrees?
If you have a nice link that can explain it, that would be great. I'm going to search around myself too.
Glad you'll be able to make it to more Ice racing events this year. It should be fun.
Paul G.
Old 08-10-2002, 07:45 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Damn, Paul, I thought you were an engineer of some sort. That's degrees and minutes.
3*35' +/- 45' = 3.58* +/- 0.75*
Pat
Old 08-10-2002, 07:55 AM   #15
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Yeah the measurements are a bit much for me to get my head around. Plus it seems like a lot of shops do stuff like toe in inches instead of degrees. Tough to argue about a bad alignment if you're talking 2* and the wrench is saying .003"...
Recommend an alignment shop around Plano? SPEED6 Texas Impreza Club Forum -- TXIC 10 06-02-2008 09:52 AM
Recommend an Independent Mechanic in Southern California??? rmpsocal Southern California Impreza Club Forum -- SCIC 27 11-29-2007 03:00 AM
Recommendation for Alignment Shop in York, Pa vtbandit Tri-State Area Forum 1 06-06-2005 11:09 PM
Recommendation for Alignment Shop in York, Pa vtbandit Mid Atlantic Impreza Club -- MAIC 0 06-06-2005 03:14 PM
Recommendations for alignment shop in Tucson? ChrisL2 South West Impreza Club Forum -- SWIC 5 08-14-2004 04:32 PM
