Old 11-22-2011, 01:32 PM   #1
lavid2002
Member#: 226864
Default 2005 WRX Evap canister purge valve location?
I have a code for a leak in my evap system. I have checked all around and can't spot any leaks. I bought a purge valve for my 2005 WRX. This one
http://www.am-autoparts.com/Subaru/I...tm_content=EMX
Now that I have the part, and I have dropped the canister down. I dont see any part back here that even resembles this. The only valve that is back here is a small valve with 3 small hoses going to and from it. The hose that goes to the canister that is the same diameter as this valve I purchased goes into my frame and opens there, it isn't connected to anything.
A little help?
I can snap pix if necessary.
Thanks!
-Dave
lavid2002 is offline   Reply With Quote
Old 11-25-2011, 06:28 PM   #2
lavid2002
Member#: 226864
Anyone? I can't seem to locate this little guy.
Thanks!
-Dave
Old 11-25-2011, 06:46 PM   #3
dish5
Member#: 290600
stage 2
I have a 2002.
I'm not sure what you are looking for but i could look at my car and take a pic if it would help you.
dish5 is offline   Reply With Quote
Old 11-26-2011, 09:54 AM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Typically the PCSV is located on/under the the intake manifold. One end of the solenoid goes to the intake and the other to the fuel pipe vent line. It's simply an on/off valve, at idle the valve is closed, under load it opens and vents back to the carbon canister.
beaviscih is offline   Reply With Quote
Old 11-26-2011, 10:46 PM   #5
lavid2002
Member#: 226864
What does PCSV stand for?
The closest write up I have found is this one.
http://cars.natemichals.com/subaru-2...ment-write-up/
This is the same part I have, the problem is, on my car that tube just vents right into the frame.
I also found a tube that goes from #2 to #3, it was unplugged. I dont know how! But it was. I suspect this is the culprit of my check engine light. I have put 30 miles on the car since I plugged it back in, but my CEL hasn't gone off. I think I am going to re set it and see if it comes back on instead of seeing if it goes away.
What do you think?
-Dave
Old 11-27-2011, 11:48 PM   #6
lavid2002
Member#: 226864
Went to the parts store today and deleted the code with a scanner and it came back within 2 seconds of me turning the motor on literally. Ideas?
Thanks, help is appreciated!
Old 11-28-2011, 02:18 AM   #7
Member#: 301037
2004 Forester XT
Try checking the lines running to the evap purge and make sure they are all connected and routed correctly.
http://www.google.com/imgres?um=1&hl...:429,r:13,s:33
art@grimmspeed is offline   Reply With Quote
Old 12-01-2011, 02:30 PM   #8
lavid2002
Member#: 226864
All the lines are routed correctly, and are free of dry rotting or loose fitting connections that would cause a leak.
Should I replace the valve near the intake manifold?
I want to send this purge valve back. I dont think it fits anywhere on my car.
Old 12-04-2011, 07:30 PM   #9
lavid2002
Member#: 226864
No one ?
Old 12-04-2011, 10:53 PM   #10
brutus76
Member#: 15783
2008 Fozzy 2006 WRX
00 Cummins Ram, 87 CRX Si
I'm pretty sure a loose gas cap can cause this code. If I'm wrong sorry, but it's worth a shot and free.
brutus76 is offline   Reply With Quote
Old 12-05-2011, 04:08 PM   #11
lavid2002
Member#: 226864
I've had the code for a couple months now and have tried the gas cap a few times.
Old 12-05-2011, 05:26 PM   #12
brutus76
Member#: 15783
2008 Fozzy 2006 WRX
I tried.
Old 12-06-2011, 11:50 AM   #13
lavid2002
Member#: 226864
Thanks anyways.
Anyone?
Old 12-08-2011, 12:25 PM   #14
lavid2002
Member#: 226864
I want to fix this CEL so bad!
Old 12-08-2011, 03:46 PM   #15
NetHex
Member#: 303330
2006 wrx limited
red and black
I had it a couple of weeks ago i used the access port to clear it and repeat the gas cap and it never came back. Have clear the code and it come back?
NetHex is offline   Reply With Quote
Old 12-08-2011, 10:19 PM   #16
lavid2002
Member#: 226864
Twice so far, it stayed away for 3 or 4 days the first time, the second time it came back within seconds of clearing the CEL and starting the car again.
Thanks for the try : (
Anything else?
Old 12-08-2011, 10:30 PM   #17
NetHex
Member#: 303330
2006 wrx limited
red and black
Anything else?
They say sometimes it tank sediment clogging the valve other than that you might have to the smoke leak to rule a seal or picked hose
Old 12-08-2011, 11:22 PM   #18
lavid2002
Member#: 226864
Is my evap and charcoal canister supposed to look like this?
This is from a 2004.
[IMG]file:///Users/davidbrandt/Desktop/part%20list.jpg[/IMG]
My canister is very similar to this, but hose #33 just curves up, back, and into the frame of the car. It doesn't connect to anything. I dont have #8, or #23 or any of those pieces. I am about to make a video to show everyone what my car looks like. I want to fix this so0o0o bad!
Thank you everyone for your help so far
Old 12-08-2011, 11:29 PM   #19
srcjrs
Member#: 246839
2004 Impreza WRX
Purge valve is under the front of the intake manifold. The piece above the evap canister is the pressure control valve. When that one fails, it becomes very hard to fill your gas tank. Usually when there is a code related to the purge valve, you will find that the vacuum hose pushing onto the front has popped off. At least that was the problem on two subarus I have fixed because of this code, when it was a small evap leak code that was thrown. Typically when a bad gas cap is the cause the code will be for a gross (big) evap leak. Good luck and let us know what you find...
srcjrs is offline   Reply With Quote
Old 12-08-2011, 11:31 PM   #20
srcjrs
Member#: 246839
2004 Impreza WRX
Also, the system performs a self test for evap leaks when you cruise at steady engine load on the freeway for 30 seconds or more. After you make a change and reset the computer, do this to test to see if you are clear.
Old 12-08-2011, 11:37 PM   #21
lavid2002
Member#: 226864
That valve on the front under the intake manifold did have a hose that had popped off of it! There was a small blue connector and one of the rubber hoses was disconnected. I thought for sure that I had found my problem, but after re- setting the ECU and driving for several days my CEL was still there.
What would cause that small tube to pop off? Should I replace the valve by the intake manifold?
Old 12-08-2011, 11:43 PM   #22
srcjrs
Member#: 246839
2004 Impreza WRX
Zip tie the hose on, or replace with a new not hardened 5/32 vacuum hose that won't come off easily. It may be that the hose is just not fitting properly causing the leak. My best guess as to what causes it to pop off is just a poorly fitted hose, and boost. Both cars I have fixed this on also had turbo inlet pipes (one of those cars mine) that pushed on the valve a bit, and added to the stress on the hose.
Old 12-08-2011, 11:51 PM   #23
lavid2002
Member#: 226864
I'll go check the hose tomorrow.
Thank you!
Old 12-25-2011, 10:39 PM   #24
lavid2002
Member#: 226864
Tube isn't still popping off and lines fit pretty snug. I replaced the gas cap for ****s and giggles and the code refuses to go away
Anything else?
Old 12-27-2011, 06:20 PM   #25
srcjrs
Member#: 246839
2004 Impreza WRX
All the usual suspects have checked out, take it to a repair shop with someone who understands emission system diagnostics and get it smoked. It'll turn up then. Good luck!
evap canister and drain valve tsi_guy619 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-04-2011 11:34 AM
Evap solenoid/Purge valve delete cubuff Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-14-2010 09:12 PM
Wanted: 98-01 2.5rs Evap canister and valve assm classics2go Private 'Wanted' Classifieds 0 03-06-2008 02:19 PM
Canister Purge Valve damaged?? alwrxwu Newbies & FAQs 1 02-22-2005 12:56 PM
Canister Purge Valve damaged? alwrxwu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-22-2005 12:29 PM
