Old 11-22-2011, 05:35 PM   #1
vic-gc8
Member#: 298909
1995 STi VII type-RA
White, on white wheels
Default turbo choice 1995 JDM STi
hey guys, got a choice here, not going to be on my dime so not super concerned. my question is as follows, the replaced TD05-16g on my motor died the other week. The turbo builders who are warrenting the replacement are having issues tracking down the compressor and turbine wheels (for the td05), as such i have been offered the option of the shop buying a used VF28 or VF39. this is where my choice comes in. Having searched both on google and this website it has been hard for me to find concrete informatin on the specific differences between these three turbos.
my requirements are that 1.) it not require any tuning as i do not have the funds to change the factory tune of the car at the moment.
2.) no real i need xxx HP/Tq or i need to be able to run a xx.x second 1/4 3.) this is a daily driver. i do like how it drove before the turbo died on me.
vic-gc8 is offline   Reply With Quote
Old 11-22-2011, 09:24 PM   #2
theonlygreat
Member#: 65916
1996 Impreza WRX
Check out this LINK for lots of info on VF39 vs TD05-16G. I'd go with the VF39 simple because it is newer. The two turbos are very close in size and should flow fairly similar (probably slightly less overall, but at stock boost pressure it should be negligible) to your TD05, so no tuning will be required.
On a side note, a TD05 compressor and turbine should be very easy to find. They are very common turbos. If they are trying to warranty a newer turbo with a used unit, I'm not sure that is a business I'd like to deal with personally.
theonlygreat is offline   Reply With Quote
Old 11-23-2011, 03:18 AM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
youd be better off finding another used TD05 with the angle entry like yours. any IHI turbo will have direct entry and will require special piping and maybe modification just to angle up and meet your stock intake.
Also you can send out Mitsubishi turbos (TD series) for rebuilds, unlike IHI turbos which are generally know for being too costly to rebuild. I dont know what options there are in canada but my housemate just had his TD06-20G completely re-serviced and overhauled by G-Pop-Shop in Arkansas, USA for about $350 including shipping. I dont know if they can also service one of those older TD05 angle entry turbos, but I would guess they can. Try contacting them or any other place that does rebuilds of Mitsu turbos, and see what you can find.
elislider is offline   Reply With Quote
Old 11-24-2011, 01:19 AM   #4
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I'm running a TD05-20G with the 90deg inlet welded on. Making good boost and decent power
sizzflair is offline   Reply With Quote
Old 11-29-2011, 01:43 PM   #5
vic-gc8
Member#: 298909
the turbo is currently at the shop that did the previous work on the turbo for rebuild. unfortunately the shop is having issues sourcing the compressor and turbine wheels seems there are none in Canada, and they are currently checking US sources but due to thanksgiving this has been slower then desired.
Old 11-30-2011, 02:29 PM   #6
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
If you just need the parts you could call Kinetic in Langley BC
http://www.kineticmotorsport.com/pro...R-867-246.html
They sell TD0516G and TD0520G. It seems unlikely they wouldnt have the parts.
TommyAtomic is offline   Reply With Quote
Old 12-01-2011, 02:47 PM   #7
vic-gc8
Member#: 298909
yea, ADP distributors supplies kinetic, ADP are the guys that are doing the warranty rebuild on the turbo. but as i am heading back to the island end of the month i am having issues beleiving that the parts are that hard to come by.
FS : NH: 1995 JDM STi 5 speed transmission RedEvilWgn NESIC Private Classifieds 1 10-09-2011 05:39 PM
1995 JDM Sti RA... stereo help sizzflair Car Audio, Video & Security 7 02-28-2010 07:46 PM
BEST turbo for a jdm sti v7 motor? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 53 07-05-2006 06:31 PM
SoCal : JDM Turbo Back Exhaust, JDM STi V9 Spec C Suspension & much more outcast Private 'For Sale' Classifieds 14 10-31-2005 09:23 PM
