Old 11-22-2011, 06:47 PM   #1
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Default Climbing FKLC possibly due to colder weather?
Hi all. I noticed over the past few weeks that my FKLC was steadily climbing as the temperature got colder (was seeing -5.x under low load conditions) I rest the ECU via the AP last week, and its doing much better now (-.35 to -1.4 maximum corrction values). Could this be due to the colder weather leaning out the AFR's and causing knock? I boost leak tested from the turbo inlet, and everything downstream showed no signs of leakage, and I checked for anything loose in the engine bay and found nothing. Just seeing what you guys think about this. I can grab a log for you guys if you need it. Just trying to figure out why its doing so well now, but it was looking unhealthy there for a while...
2Fast4U1DAY is offline   Reply With Quote
Old 11-23-2011, 10:23 AM   #2
Cobb Tuning
Member#: 4803
Cold temps will not cause you to run lean. Your correction may have been a fluke if it was at very low loads and not necessarily something to be concerned about. I would keep an eye on it and try to get a log. Some parts of the country get crappy winter gas, but you would expect that to impact high load as well.
Bill
Old 11-23-2011, 08:03 PM   #3
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Bill
Thanks Bill! I will get a log up Friday.
Gas Leak-Not due to cold weather. ChronicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-02-2009 09:37 PM
The worst thing you could possibly due to an IS300 JM530 Mid West Subaru Owners Club Forum -- MWSOC 11 12-03-2007 07:27 PM
Summit Point DEC 2 Rally moved to 8th due to weather jensscott Mid Atlantic Impreza Club -- MAIC 7 12-02-2007 12:29 AM
Question due to hot weather in SOCAL Nettalp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-23-2007 11:35 AM
Classes cancelled due to severe weather (TX haters welcome!) Gundoo Off-Topic 32 01-17-2007 01:55 PM
