#1 |
Member#: 244748
Vehicle:2002 WRB Impreza WRX 2.1 Stroker w/ VF39 |
Hey guys, got a quick question. I know that I can fit the older EJ20G motor into my transmission, but what would I need to make it work properly?? Since I will be using my transmission, I wouldn't need a new clutch assembly, rear differential, master slave cylinder, etc. right? Glad if someone could give me some insight.
#2 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
....sigh... tranny always follows the rear.
If you're just changing the engine.... the rest will fit. Subaru didn't change clutch types till the v8. ... so you're fine. |
#3 |
Member#: 244748
Really? That's probably the route I'll go then. I know some people say that the long block won't fit because the 02 wrx intake manifold doesnt work with the ej20g, but that's why I just want to get a motor with the wiring harness. Anyone else got some insight?
#4 |
Member#: 16819
SCIC
Vehicle:2002 MBP WRX, '98 OB Three Gen 1 Legacy Turbos |
There will be a missing bolt hole on the motor for the second starter bolt.
Early tranmissions had stud on the trans and no hole on the motor. Later transmissions used a long bolt through the bellhousing and a matching threaded hole on the block. So some fabrication will be involved....a search should turn up what others have done. Not quite sure of your plan, but USDM WRX wiring and ECU will not control an early EJ20G. You should be able swap the cylinder heads and intake manifold and the crank sensor to the older motor. Basically just use the shortblock, but double check compression ratios and head gasket thickness to be sure. |
#5 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
you do know that a 02 ecu will NOT run an ej20G right?
#6 | |
Member#: 244748
Yes I'm aware of this. The engine I was looking at did come with an ECU. I think I'm just going to stay USDM for now. |
| Thread Tools | |
| Display Modes | |
| 3500rpm cut out - EJ20G with USDM WRX Ignition Coils | BoostAddictPL | Pre-2002 Factory Turbo Powertrain | 17 | 11-24-2010 03:18 PM |
| FS: USDM WRX Transmission | LegendaryHarry | Private 'For Sale' Classifieds | 43 | 07-17-2006 09:41 PM |
| Feeler- EJ20G motor with complete harness | imprezdgc8 | MAIC Private Classifieds | 10 | 04-19-2006 11:42 PM |
| WRX with STi side splitter or STi with USDM WRX fogs | subUrbanAuthority | Member's Car Gallery | 13 | 02-19-2005 02:53 AM |
| Can I run V7 motor with USDM WRX ecu? | PRODRIVEN | Subaru Conversions | 30 | 11-14-2004 03:33 PM |
